Can't decide if i should grab this 1st gen Supercharger or wait for a 2nd.
Old May 13, 2008 | 07:41 AM
Texas_Ace's Avatar
Ok, i have found a 1st gen Supercharger (if you find it please don't buy it). Plus it is local so i could pick it up.
What i want to know is should i even worry about it? Or wait for a 2nd gen? If i wait for a 2nd gen it could be awhile/never that i get it though.
What are the differnces between the 1st gens and later gens Superchargers? Anything i should know?
And yes, i would be getting all the fuel mods to go with it, but i need the SC befor ei get those.
Old May 13, 2008 | 07:58 AM
Belize Off Road Team's Avatar
Why not get it. then you could sell it if you ever want a 2nd gen SC
Old May 13, 2008 | 08:13 AM
Man4God's Avatar
As far as I understand, the 1st gen ones are 2 pieces and gray while the 2nd gen superchargers are 1 piece and black.
Buy this one, spray paint it with engine paint, rebuild the nose cone, drive it like you stole it.
Old May 13, 2008 | 08:14 AM
BajaRunner's Avatar
Sounds good, where can I pick it up?
Old May 13, 2008 | 08:21 AM
Texas_Ace's Avatar
Thats kinda what i was thinking, i just don't have the $$$ to get it if there are problems i didn't know about with the 1st gens. I am so broke but so want to get a SC, this weekend i was driving severl hundred miles and had my truck loaded down real good, it was SOOOOOO SLOW! Just going 60mph would cause me to drop a gear if we even went up a slight grade (and in Texas where i am there is no such things as hills, much less mountans)
That about what i knew, didn't know if there was some evil secrete that the 1st gens had though.
Anyone know if they will work fine with the URD stuff like the 2nd gens? (I assume yes, but you never know)
LOL, I would already have to beg and pleade to get it right now. If i can't get it i will post a link and it will be open game.
But i just hope that no one gets it before i am able to.
Old May 13, 2008 | 08:30 AM
Man4God's Avatar
Sounds like you need to NOT get it if you can't afford it. Seriously, be smart with your money. A supercharger requires fuel mods and premium every tank. Are you ready for that financial commitment?
Old May 13, 2008 | 08:35 AM
Texas_Ace's Avatar
LOL, yeah i know all that, I have been planning to get one for awhile. The problem is that right now i am broke, i had planned on getting it in a month or 2 when i will have some more $$$. But this is such a good deal i could get thisnow and then wait for the rest until i get the $$.
After that then it is not a big dea. And since my truck is used for my work quite a bit i get about half my gas paid for me :-)
If ya'll want to help me have some spending $$$ then buy my stuff: http://search.ebay.com/_W0QQsassZiamso4cru
Lots of truck parts there as well as paintball. Thats where a lot of my spending $$$ for my SC is coming from.
Old May 13, 2008 | 08:36 AM
Djlarroc's Avatar
I just bought it.
JK. Whay is there a 1st gen and a 2nd gen? Is it split into production years?
Old May 13, 2008 | 08:37 AM
mastacox's Avatar
The first generation superchargers are functionally identical to the second gen superchargers.
As long as you are fine with the ugly grey beast bolted to your engine, get it!
Old May 13, 2008 | 08:40 AM
Texas_Ace's Avatar
Ah, see i was worried about something like this.
So can the 1st gen version have ll the corret fuel mods and such done to it and work fine and safe for my engine?
Also, is it as easy to setup and tune as the 2nd gen version?
Old May 13, 2008 | 08:43 AM
mastacox's Avatar
1st gen-
2nd gen-
Originally Posted by GadgetOnline.com
The newer or current supercharger kit uses a single casting for the supercharger housing and plenum. It is based on the newer 4th generation Eaton supercharger. It differs from the 3rd generation mostly in respect to the bypass valve. In the 4th generation the supercharger body has the bypass valve cast into the supercharger body where on the 3rd generation it was a separate part that had to be plumbed into the works some how. This saves space and allows a more compact installation so it can be fitted to more applications. Magnuson has taken this to the extreme and made the supercharger body, bypass valve, and plenum all one casting to make for a very compact installation. Some people get confused thinking that the new supercharger is a totally different supercharger. It really is not. It is still an Eaton M-62, 62 cubic inch supercharger. Magnuson has really done a fantastic job on the second version. The layout and casting is very well thought out and still uses all the factory connections and cables. The newer one is easier to install saving on installation time and confusion.
Old May 13, 2008 | 08:45 AM
Texas_Ace's Avatar
I see you edited the part about not being able to use the 7th kit witht eh 1st gen out, ddoes that mean it can be used with it?
Old May 13, 2008 | 08:53 AM
mastacox's Avatar
Tuning them will be exactly the same. Supposedly the 1st gen is very slightly more difficult to install, but I doubt it's THAT much harder since you're already taking your engine's entire intake off to install fuel injectors and stuff.
Old May 13, 2008 | 08:54 AM
mastacox's Avatar
The URD 7th injector kit is fully compatible with both first and second gen superchargers, according to their website. I'm not sure about the TRD, but if you're doing fuel mods you need to get the URD stuff anyway so that doesn't matter.
Tuning will be somewhat easier with the URD 7th injector kit rather than the URD 3.4l Supercharger Fuel upgrade kit, so if you don't plan on tuning your engine like a maniac and trying to go with much higher boost and/or mods, get the URD 7th injector kit.
Old May 13, 2008 | 08:55 AM
Texas_Ace's Avatar
Great thanks for the info!
Old May 13, 2008 | 09:05 AM
mastacox's Avatar
I've heard that the belt tensioner for the 1st gen is not as good as the one for the 2nd gen, so you might look into that... I think Toyota calls it the "Dynamic Tensioner" or something.
The tensioner is not attched to the supercharger itself so it would be possible to find the "better" belt tensioner later on and install it at your convenience.
Old May 13, 2008 | 09:06 AM
Texas_Ace's Avatar
I've heard that the best tensioner for the 1st gen is not as good as the one for the 2nd gen, so you might look into that... I think Toyota calls it the "Dynamic Tensioner" or something.
Thats kinda my thinking, is if i get this then i can slowly get all the other parts for a SC setup. Then down the road i can always just get a 2nd gen SC and swap it out should i want to.
Old May 14, 2008 | 08:55 AM
runner00's Avatar
Good thread, I was thinking about this myself.
I aslo have access to a first gen supercharger that just needs a nose cone rebuild that was removed (from a 99 tacoma) during warranty work from a nearby shop.
I have been putting it off, because I was told that the ports were different and would not line up properly since I have a 2000 4runner.
But wouldn't the light grey color run cooler and not soak up as much heat.
I for one do not care what color it is. My motto is: function over form.
After reading this thread, I might slap it on and see after I collect all the fuel mods and rebuild the nose cone.
Old May 14, 2008 | 08:57 AM
Texas_Ace's Avatar
Go for it, for me i was outbid due toa slip of the figners. I meant to bid $650 but entered 550 and was out bid by $5.
Oh well, wait for another one.
jasonty
41
Dec 23, 2018 01:00 PM
dumpster84
Apr 30, 2016 06:03 AM
anniesball
Jul 29, 2015 11:46 AM
noahstancik
Jul 17, 2015 05:38 PM
coryc85
Jul 6, 2015 04:07 AM
