- Addco Sway Bar: Front only or F&R?
- Can stock suspension items from an FJ Cruiser be installed on a 3d Gen 4R?
- Broken Wheel Stud
- P0171 again
- Aussie Locker for Toyota 8.0" V6 soon.
- Question about Yakima
- Rear brakes (Drums) are looking up... help!!
- 35s on 1.5" lift
- Hey whats up guys and Q's about propeller and vibration
- Still trouble with shocks!
- Release pressure for fuel filter replacement help
- OK, here is my CEL novel, please help.
- heater core or valve problems?
- Gearing Question
- Coolant Leak: What hose is this?
- Engaging Rear diff?
- '97 Limited vs. SR5
- Selling my running boards
- Cleaning body panels
- Manik Grill & '07 4Runner Question
- Adding Cimate Controls in an Sr5
- 2007 Yotatech calendar is ready
- Brake Light?
- My lift thread, Finally.
- Guess what I'm doing??
- New shoes for the dance
- Tacoma Engine Issues 96 3.4
- Noise from EVAP
- PreRunner 4Runner or 2wd Lifts
- p303 misfire detected
- Hesitation ( I searched )
- Diff lock disables abs?
- 4runner LED tail lights?
- what's this noise?
- Automatic Transmission Sealant Question
- Parts source
- '99 Radio issue?
- Tips on removing front coil assembly?
- wheel locks for FJ Cruiser can be used for 3rd gen 4Runners?
- Cold Weather Prep, Pronto
- putting 1995 nissan truck rims on a 1997 4runner: ok or not?
- Anyone with a 2002 Sr5 have the chrome package?
- Sr5
- new meats are on! *pics*
- Need help w/ 3.4 EVAP
- Throttle body problem
- LC springs: 80 vs. 100 series
- Proper belt tension '02 4Runner
- Deckplate Mod DONE!! W/Pics... I couldn't Wait...
- T4R Rear Drum Problem
- Interior Spare Tire Mount
- 96 4runner shift solenoid problem
- Intake "J" Tube, what is it?
- toyota keyless entry
- More endless suspension questions
- Question regarding fuel injector replacment
- Newly Designed ISR for 04 Double Cab
- My "re-introduction"
- Weird intermittent noise under the hood....
- confused about engaging 4x4
- 285's with a body lift?
- First mod, new tires, and the steering/vibration saga begins..
- problems with shock install
- Clutch job, and price. New idea as well
- Engine clatter
- Some weekend mods
- 3rd Gen speedo gears (transmission)
- 3rd Gen Fire Continued
- Mudguard part #
- ABS Not Working After Some Swimming
- Rear Door Gets Stuck Ocassionally... Need Help Getting It Not Too...
- SMT6 Open/Closed Loop fix...idea....
- Shock Recomendations
- Parts list for 2002 4Runner?
- 2003 Sequoia wheels fit my '96 4Runner??
- 2002, LTD, 4WD @ 105K miles for 15K?
- Tundra brake upgrade onto Tacoma S13WE
- 99T4R/LC Rear Shock Questions
- Amp turn-on alternatives?...my Remote Control Signal is Jacked
- trans removal headers?
- Heavy or Med Duty Springs
- Bull Bar
- just got tundra springs ...
- Sounds like front drive shaft still spinning
- lift questions
- Strange Brake Problem with Front Brakes 'Sticking'
- shackles recovery gear
- 1996 4runner diff ?
- Does the 16" wheel option brake caliper take a banjo or a flare?
- mods and gas mileage questions
- 99 3.4 weird grinding noise and water on drivers side?
- Leaf springs sitting on exhaust...
- Full bowl of repairs with some deckplate on top!
- Euro tail lights?
- Winch Questions
- new pass rear flares?
- Timeline of my 97' 4runner
- cv replacement?
- Flaws to look for when buying tacoma
- New 4Runner or fix the rusty roof??
- Hitting 100,000 Miles
- Guys with Yakima fairing?
- Wheels: 16x8 w/ 4.0 BS OK?
- Boost gauge install question
- alignment after trd lift?
- dyno...tune?
- Broken sway bar links w/ TRD 3rd gen lift
- 2000 4R overdrive problem
- cant get tires mounted, rubbing issues.
- Black Wheeler's Off-Road Alloy Wheels
- Retorquing bolts as routine maintainance
- Do they make shift kits for Toyota trannys?
- Stuck upper shock obsorber nut
- Clutch Problem
- Arrrggh...Front differential Drain plug!!
- 02 4runner Sport Grill and bumper mods?
- Best Place to Pull 12V from?
- I also have a check Engine light
- Check Engine Light... I have Had Enough...
- 5 hours of free time to work on the RNR
- Will this Odyssey battery will fit my '96?
- finally drove a 4runner
- Picture Request: 96-98 OEM Foglight Mount
- Bad Alternator??
- Knocking/Pinging Noise
- 1997 Toyota 4 Runner Hood Latch
- More 16" to 15" wheel questions...
- Factory toyota Posi ?
- Springs
- Limited Flares
- E-Locker Differential
- Can anyone tell me what size rear end housing 3rd gen 4runners have? 7.8 8...
- bilstein shock bushings
- Climate Control Lights on the Blink
- How much weight in bed for snow & ice traction?
- Need Some Advise on Transfer Case and Actuator
- Sport scoop hood for my runner
- Univeral antenna?
- hard to start, funny noises
- 99 4unner engine problem
- Airbox measurements for taco/runnner
- 7th injector kit CONFLICTS???
- Forward jerking before coming to a complete stop
- 50 state emissions / CA cat - ?
- Tundra Coil-Overs on a Tacoma
- help what rear end in 3rd gen 4Runner need limited slip truetrak?
- Removing the roof rack supports...
- Smell from Transmission
- Flippable Hitch p/n
- Field Service manuals
- taco axel in my 3rd gen?
- URD MAF Sensor Calibrator??
- Lift pics
- Starter Problem or Ignition Switch Problem?
- My First attempt at a brake job, 5 hours later, im not even 1/2 done
- What gears do I have???
- Tranny problems?
- Panasonic battery suppliers in the US ?
- convert non-ADD front diff to ADD?
- My 4runner got rear ended this morning... Thank you trailer hitch!!!
- PO151 code - quick question - Symptom?
- Turn signal/headlight problem
- Mystery harness near ignition
- Auto up/down windows
- MAF Sensor swap/borrow in SE WI?
- 96 Tacoma Clutch Problems
- OBDII code P1780
- PLEASE HELP FAST! Truck isnt starting....
- Finally found new rims & tires
- CEL Help
- PCV catch can/murky oil
- Anyone Running just a body lift?
- ? for those with Sport Hood
- Need 2 CA catalytic converters for 99 4runner.
- Sonoran Steal #4 vs. OME Vs. REVTEK
- TJM-15 and Custom Hitch Pics
- Smittybuilt or Manik?
- 1998 4runner rear wheel bearings/seals...
- ( ( ( Tire Upgrade Question for 97' 4R ) ) )
- FRONT/REAR Brake line extensions for lift
- A340F Wiring
- Where to buy replacement seat covers
- 01 tacoma... seats too low, any quick fix ideas?
- 16x8 rim with a 5" backspace
- S&B Cold Air Intake
- Tensioner
- Blinking MIL
- OBD II plug wiring for 99 4runner
- A little wheel help
- LC Shocks on 3rd gen
- 3rd gen 4runner 3" toytec lift
- Running Boards Removed-Pics to show result-Need OEM Mudflaps
- Bug deflector...grr
- Swaybar Disconnects Recomendations
- new A-Arms with uniballs?
- Air Conditioner Problem
- OME 906 coils
- rolled
- ELocker engagement question
- Front Wheel Bearings Bad?
- Weighing purchase options
- Need brake pads for my 13WL (231mm) Tundra calipers
- Glove box bulb dead, changed bulb, checked fuse, still SOL
- Which spark plugs do i buy?
- Teflon Wheels?
- Mechanic's quote on cylinder misfire... what do you all think?
- All-Pro Rear Disc Brakes: Gauging Interest
- Installed LPD 4454 Trans Cooler *PICS*
- Leveling The Front After LC's
- 100 Octane???
- To lift or not to lift???
- 3rd gen sliders
- 2 flat tires. Tire Sizing Help guys! QUICK!
- Winch dilemma
- 99' 4Runner ECU check light issues
- Manik Grill Problem
- Locker Actuator Guard
- How smooth are your engines?
- Thread on Polishing headlights?
- ABS Question
- Aussie locker
- to supercharge or not to supercharge!?
- idle and clutch problems
- Replacing the Starter
- New O2 Sensors and MPG dropped??
- Looking to buy 3rd gen. (1997) factory Hella foglights
- Need trany help
- S.C Taco exceleration problem
- My lift
- 4Runner Gas Smell -- should I be alarmed?
- Dash Bulbs
- 3rd member / abs question
- Catalytic smells on warm up
- Ecm
- Pulling / Tugging / Slipping Feeling
- Replace Front Bumper and Body Shop Suggestions (Maryland area)
- What tools do I need for SS lift #7
- Dash lights?
- Aux. Power Options?
- I get a new radiator
- Tilt Steering Wheel Question
- Pro- comp coil spacers....good, bad?
- Tacoma Gas Mileage
- Who else has done this?
- Lets see your off road Lights!
- Header Opinion. Just got cat-back
- is this accurate? (steering wheel size)
- Which air intake is better for 2001 4Runner?
- ABS malfunction?
