16x8 rim with a 5" backspace
Old Nov 8, 2006 | 11:27 AM
gregbreakseverything's Avatar
Is it possible to fit 265/75/16's on 16x8 rims with a 5" backspace on a 2.5" suspension lifted 4runner without wheel spacers?
Old Nov 8, 2006 | 03:15 PM
Elton's Avatar
ya should fit fine may stick out a little bit
Old Nov 8, 2006 | 03:53 PM
nc994run's Avatar
From: raleigh, nc for school chapel hill, nc for home
It actually wouldnt stick out that far, if at all. I had 265/75/16's on a 16x8 with 4" backspacing for a little while and it didn't stick out past my Limited flares. As for clearance on the A arm, i can't be of much help.
Old Nov 8, 2006 | 04:06 PM
SoiledGreen98's Avatar
Wouldn't 5" backspace mean only 3" would stick out? That would put it just about stock.
http://www.rsracing.com/tech-wheel.html
Old Nov 8, 2006 | 04:18 PM
mastacox's Avatar
I might be suspicious of it being able to clear the control arm, because the backspace is so big... Just check to make sure is all. My 16x7's which have 4.25" of BS I think (stock 2000 4Runner Limited Alloys) only leave about a 3/8" or so of space between the upper control arm and the tire. If I got my backspacing right, that would mean your rims would be 3/4" IN, definitely touching the control arm...
Old Nov 8, 2006 | 04:35 PM
nc994run's Avatar
I think the stockers are actually a 4.375" backspacing, so .625" closer than yours would be.
Old Nov 8, 2006 | 11:08 PM
kcebes's Avatar
Don't forget he is talking about an 8" wide wheel. Not stock width.
Old Nov 9, 2006 | 04:43 AM
I was also very suspicious about this. I was checking out wheels on tire trends.
http://www.tiretrends.com/wheel2/iuc...9&wheelSize=16
I noticed one of the wheels that they said would fir the 4runner was the american racing diamond back +12 offset (5 inch backspace). Since I have an SR5 without flares, I realized this rim would sit inside the wheel well almost stock. I was just weary of the 5" backspace hitting the a arm or something. I was hoping for someone else on here to be runing a wheel with 5" backspace.
Old Nov 9, 2006 | 04:46 AM
Great website by the way. If everyone looked at this website, there would be alot less confusion on yotatech.
Old Nov 9, 2006 | 07:42 AM
mastacox's Avatar
I understand he has a wider wheel, but the backspacing measures from the back of the rim, meaning regardless of overall rim width the distance to the upper control arm will be the same.
Thanks for the clarification on my backspacing nc994run, based on those numbers I do not think a 5" BS will work, because if the tire is .625" closer to the control arm it will rub! I would find a rim with at MOST stock backspacing, and less if possible.
Old Nov 9, 2006 | 01:27 PM
Its starting to seem that I am doomed to have my tires sticking out of the wheel wells with aftermarket rims. Does anyone have pictures of how far 265/75's on a 4.5" backspace 16x8 stick out of the wheel wells on a sr5 with the chrome strips?
Thanks
Old Nov 9, 2006 | 04:56 PM
I haxe 16x 8s with 4.25 and IMO the look perfect. they stick out about 1 1/2 inches +/-. With the bfg mts they make the truck look like a truck instead of a station wagon.
1uzRunner
63
Nov 10, 2018 03:58 PM
Cycles
Sep 29, 2015 06:37 AM
Bill McBride
Sep 20, 2015 02:51 PM
theduck21
Sep 10, 2015 07:01 PM
AkitaDog
Sep 3, 2015 09:01 PM
