99 4unner engine problem
Old Nov 13, 2006 | 03:59 PM
dtliao's Avatar
Just recently my 4runner's been behaving quite weird. When i started the car, the engine sounded horrible. It sounded LOUD like something grinding coming form the bottom. I would then shut off the car and pull the key out and the engine would continue to run for about 2-3 seconds. Then it would sputter to a stop. When I restarted the car, it started up and sounded fine like normal. This already happen twice so I'm writing to you guys to try to figure out what the problem could be. Any suggestions/help would be greatly appreciated.
Thanks
Old Nov 13, 2006 | 04:27 PM
MTL_4runner's Avatar
Check the timing belt and tensioner.....when was th last time it was done?
Old Nov 13, 2006 | 04:28 PM
Elton's Avatar
also delete your 2nd thread
Old Nov 13, 2006 | 04:33 PM
rimpainter.com's Avatar
Which engine?
Old Nov 13, 2006 | 04:40 PM
dtliao's Avatar
It's a 3.4L Supercharged Sr5. The timing belt was replaced about 2 years ago when my motor blew. Thanks
Old Nov 13, 2006 | 04:42 PM
Elton's Avatar
i forgot to say welcome to yotatech
Old Nov 13, 2006 | 04:54 PM
dtliao's Avatar
Elton,
Thanks. I was actually a member before but for some reason when I tried signing on today it didn't recognize my id and my email so I had to re-register.
Old Nov 13, 2006 | 05:06 PM
Originally Posted by dtliao
Elton,
You can ask the admins to help if you want your old ID back and it isn't taken by someone else.
Old Nov 13, 2006 | 05:23 PM
Firefightertaco's Avatar
Yeah sounds like a timing issue
Old Nov 14, 2006 | 04:53 AM
984RNR's Avatar
What caused your motor to blow the first time
Old Nov 14, 2006 | 06:03 AM
ebelen1's Avatar
I'm w/ Jamie on this one. My belts look slightly worn and need replacing, and once in awhile, it makes that awful sound upon start up. I don't have the other issues w/ pulling the key and the motor still running but the horrible noise, I've had.
SLC97SR5's Avatar
It sounds like your starter contacts may be bad. The grinding is from the solenoid staying kicked out against the ring gear, then when you shut it down the starter stays engaged trying to spin up the engine again...hope it's this and not a timing issue.
Old Nov 14, 2006 | 12:56 PM
dtliao's Avatar
Basically, I think it was my whack ass refurbished TRD Supercharger. It was installed by the dealer but never sounded right. I floored it one day and it blew at 80K+ miles. Now with everything rebuilt, it runs great. Everything was rebuilt/replaced including the timing belt so I don't think that's the problem.
But I think SLC97SR5, nailed it on the head. It could very highly be the starter. Now, can anyone show me where it's located? And how to replace it?
Thanks
Old Nov 14, 2006 | 01:43 PM
Thanks
https://www.yotatech.com/~corey/tech...r/haveblue.htm
steve miller
Oct 10, 2015 01:40 AM
Yota.Jay
Jul 23, 2015 08:08 PM
Jnkml
Jul 6, 2015 01:20 PM
wilbertd
Jul 6, 2015 07:39 AM
