99 4unner engine problem
Just recently my 4runner's been behaving quite weird. When i started the car, the engine sounded horrible. It sounded LOUD like something grinding coming form the bottom. I would then shut off the car and pull the key out and the engine would continue to run for about 2-3 seconds. Then it would sputter to a stop. When I restarted the car, it started up and sounded fine like normal. This already happen twice so I'm writing to you guys to try to figure out what the problem could be. Any suggestions/help would be greatly appreciated.
Thanks |
Check the timing belt and tensioner.....when was th last time it was done?
also delete your 2nd thread
Which engine?
It's a 3.4L Supercharged Sr5. The timing belt was replaced about 2 years ago when my motor blew. Thanks
i forgot to say welcome to yotatech
Elton,
Thanks. I was actually a member before but for some reason when I tried signing on today it didn't recognize my id and my email so I had to re-register. |
Originally Posted by dtliao
(Post 50337760)
Elton,
Yeah sounds like a timing issue
What caused your motor to blow the first time
Originally Posted by MTL_4runner
(Post 50337728)
It sounds like your starter contacts may be bad. The grinding is from the solenoid staying kicked out against the ring gear, then when you shut it down the starter stays engaged trying to spin up the engine again...hope it's this and not a timing issue.
Originally Posted by 984RNR
(Post 50338128)
But I think SLC97SR5, nailed it on the head. It could very highly be the starter. Now, can anyone show me where it's located? And how to replace it? Thanks |
(Post 50338485)
Thanks |
