PDA
View Full Version : 95.5-2004 Tacomas & 96-2002 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 [51] 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222
  1. 02 sensor compatibility
  2. Is this common?
  3. Need some help on a lift
  4. New pic of leds tails. On my truck.
  5. Would you rather have a sunroof or NO sunroof?
  6. 3rd Gen's and Rust
  7. 96 taco good buy?
  8. 97 4runner LTD running boards, free to a good home
  9. Toytec CO vs SAW's - trying to figure out whats best for me.
  10. Vinyl floor kit?
  11. DTC - P0340, Truck won't start all the time
  12. Changing plugs and wires on '00 4Runner Sr5?
  13. Who's running 31 or 32x10.50 (Got pics?)
  14. A Few New Mods
  15. End links bushing install.....advice please
  16. Front coil over springs
  17. Best place to buy FACTORY oem parts?
  18. Cat-back for 04 DC
  19. Need some recommendations for lift
  20. '99 4Runner center of Rear Axle leaking
  21. How are the factory running boards attached?
  22. Introduction, advice and such welcome
  23. What gear ratios does my 98 4run have
  24. 99 springs and goodyear mt/r
  25. Remote programming-tried it all, nothing works
  26. Rear Brake sticking / locking / seizing
  27. speedometter sticking
  28. any easy ways to get the pin stripe off my 4runner
  29. Is this Locker correct for my truck??
  30. Towing with a V6?
  31. Fog lights
  32. ARRIVED IN TUNISIA!!!! Desert tips appreciated!
  33. I ask... because you ROCK!!!
  34. speed sensor part number?
  35. Ball Joint and LF drive shaft
  36. Bang for the buck power 3.4, NA, Boosted etc
  37. Your guy's opinion of Pop n Loc tailgate lock
  38. Misfire
  39. 97 4runner won't start
  40. 01 Taco w/ Bentup bumper and Smittybilt winch *pictures*
  41. No power, battery tests fine...
  42. Small noise coming from the front
  43. Yes, it's another 3rd gen cupholder mod.
  44. Lightforce 240's on ARB
  45. Squealing steering...
  46. $800 3.4 In NW Washington
  47. intermittent starting problems
  48. 02 4Runner Manual hub conversion axle question
  49. 5vzfe rebuilder in the SF bay area
  50. Selling my 99 Sport, maybe...
  51. I need more power! Bigger (more amps) Alternator Question:
  52. Swap 1998 4Runner Radio Bezel with 1999 Bezel
  53. Width or Height Limiting Factor on Stock 4Runner?
  54. Anyone with this setup?
  55. ? on door panel removal
  56. Factory Steel Wheels?
  57. Key won't come out!!
  58. swapping an auto tranny with a manual one?
  59. front bumper lights
  60. Interesting problem
  61. Lift Plans
  62. Do '01 Tundra wheels fit a 3rd gen 4Runner?
  63. Drivers Side (Right Side) Convex Mirrors?
  64. roof rack
  65. Coolant dripping from Exhaust Manifold???
  66. Bent Rear Axle on 97 4Runner 4x4 auto
  67. 1996 4Runner - Interior Light Question (Dome, Map & cargo bulbs) Bulb types?
  68. hella micro de's installed
  69. Rear springs keep shifting
  70. Steering Rack Bushings: Done, but I have a Q!
  71. Leveling 96 Tacoma
  72. Weird Idle
  73. Deciding between two 4Runner's
  74. lifting my 02 4runner
  75. Front End Rattle....Driving me crazy..Help!!
  76. How is handling with 235/85/16's on 3rd gen 4runner???
  77. e-locker mod/pic request
  78. 3RZ Ticking, again...
  79. Where to get replacement Supercharger oil?
  80. Looking at a 4Runner - need some assistance
  81. E-Locker's --- Who has them?
  82. 2001+ 3RZ exhaust manifold in a 4runner?
  83. A/C compressor? Clutch?
  84. so i had a wreck
  85. Help - Play in Rear passenger wheel
  86. Headlight adjustment, 3rd gen 4runner...revisited, "JDM" pos replacements
  87. 99-02 "Fat Lip" Bumper Upgrade on a 96....
  88. Leaky Ball joint
  89. really bad gas mileage
  90. Gas Mileage In My 3rd Gen
  91. 99+ Cupholder Mod In the Works
  92. How to protect catalytic converter from theft?
  93. I want to upgrade my 3.4L
  94. To SC or not to SC? THAT is the question!
  95. diff sive question HELP
  96. A little something for you guys (video!)
  97. What color to Durabak???
  98. headlight ?
  99. 15" rim question
  100. Another brake question...
  101. Need a Steering Rack
  102. Remote transmission Filter ??
  103. Factory HU, LOC installed, no sound, need help???
  104. build my taco
  105. 2000 4runner front end assistance needed!
  106. 200 bones for plugs and wires
  107. Front Seat Mounting Hole Repair
  108. 02 4Runner looking for lift advice
  109. FJ spring/struts/shocks on 96 runner?
  110. Dealer lost their mind!
  111. Question on replacement spare wheel
  112. timing
  113. Broken Lumbar
  114. Is this normal?
  115. 4Runners With Rear Ladder?
  116. I think I am getting raped by a mechanic.
  117. Advice on my current set up
  118. rubbing issue! PICS
  119. Won't idle when cold
  120. 4Runner Rear End Creeking
  121. 4Runner leaking HELP!
  122. Just performed quick tune-up, special thanks...
  123. Random Alarm Going Off!
  124. timing for 99 4runner V6
  125. paint peeling off roof rack
  126. [Help] Need to take trim off, how?
  127. 5VZ + TRD Supercharger, cant stop the ping?????
  128. 96 4runner 15mpg? what are you getting to the tank?
  129. How to Remove 3rd Gen. Cowl
  130. locker and gear question
  131. acorn in my vent?
  132. parking lights not working!! help!
  133. taco e locker 3rd for warn 9000 pound winch?
  134. 99+ Center Bezel Wiring?
  135. 1998 Tacoma front axle damage
  136. my CB antenna install PICS!
  137. Engine TOO LEAN! help!
  138. Wheel spacers on a 3rd gen 4runner, part two
  139. Aftermarket Headlights
  140. 97 4-runner w/ 5sp & 5vz-fe clutch issues
  141. ABS disable
  142. Gear Engage Problem
  143. Whats invloved in an engine swap?
  144. Starting Issues 3.4L
  145. Cracked wire harness covers
  146. Good Day Turned Bad
  147. 15x8" wheel backspacing with 33's??
  148. Updated Pic's
  149. 96 4runner 1500-2500 rpm rattle: HELP!
  150. Putting in a new steering rack.
  151. Input on 3rz?
  152. supercharger oil change - my experience
  153. 315 KM2's are on
  154. u-joint replacement
  155. Converting 60/40 bench to buckets
  156. Roof rack lights and sunroofs
  157. Brush/Grill Guard's that fit 99-02 4runners?
  158. Not bad for 190K Y2K LTD SPORT
  159. Antenna Relay Issue?
  160. How to Change Corner lights on my 97 4runner?
  161. TRD exhaust rusting.. anyone else?
  162. Hilux surf field monitor - I need one
  163. Vinyl Roof Wrap
  164. high angle cv boot? where to buy?
  165. trans temp ?
  166. My 2000 4Runner Sport
  167. New Steering Rack Bushings = No shaky!!!
  168. After market Antennas 99 4runner
  169. Power Steering Leak/Steering Rack
  170. MOre Flex?
  171. Swaying problem
  172. Fitting 285's
  173. 3RZ Problem compilation...
  174. 98 4r 4sale
  175. 99 to 96 4runner fitments
  176. service manuals
  177. How can you tell if your Runner came keyless?
  178. 305/70 vs. 315/75? HELP!
  179. Why Toyota Clutch Release Fork Boot has a "Hole"
  180. How far do your tires stick out?
  181. Tacoma jump seat questions...
  182. New to Yota Tech, just wanted to say hi and had a few questions
  183. What does FOB stand for anyway?
  184. 96 4runner 3rz O2 sensor Resistance?!?!
  185. Anybody retrofit e-locker rear on 2002 4Runner with ATRAC?
  186. I need a roof rack!
  187. Do trekmaster make a load leveling shock for 4runners?
  188. Shell Pics on DC Taco anyone?
  189. 4runner shock question
  190. Toyota Prado Y2000 5vz power loss
  191. Need opinions & info on possible purchase - '04 Tacoma
  192. Tacoma bushbar fit a 4runner ???
  193. What parts need to be replaced
  194. 31's or 33's?
  195. Timing belt & water pump quote
  196. How much lift from Tundra Coils?
  197. Coil Packs
  198. Upgrade/ Replace Alternator
  199. Can Air Box Clips be replaced? Part #?
  200. 4.88's vs 4.56's
  201. ARB Taco bar and 99 SR5
  202. Confusion about tundra brake upgrade...
  203. TRD Supercharged 96 4runner specs
  204. Realistic Price for my '98 Runner Ltd?
  205. SOOO many Suspension Choices
  206. Let me bounce an idea off ya
  207. Idling RPM issue
  208. Rear Hatch Strut replacement
  209. Brake Vibe
  210. how do you check the timing belt / water pump?
  211. My '97 4runner; ISR; emblems
  212. Replaced motor now running too rich
  213. 01 tacoma u-joint problems
  214. MIA, tranny oil...$1800+ fix...
  215. Never had a problem with my 96 4runner 12 years running...until now???
  216. What Weight of Gear Oil for rear diff
  217. Rear Axle Seals not A Vent issue
  218. Bad Injector
  219. Help!!!
  220. taco gearing
  221. running boards
  222. Filter minder
  223. Confused on cylinder#/misfire codes
  224. The wonderful rear axle seals again
  225. CV boot Part numbers
  226. 5-spd 3.4L owners shifting rpm?
  227. Hood release cable - adjustable?
  228. Tail, Dash, & Running Lights OUT : need some help
  229. Shipping Wheels/ UPS-FedEx-Etc. What's Best
  230. Help-o2 sensor position-4 banger
  231. Pacesetter headers
  232. Just had a Pioneer double DIN deck put in
  233. Write up to replace knuckles
  234. 97 4Runner Exhaust questions (Again) : Newbie is still learning...
  235. Need help, feels like I'm hitting a rev limiter
  236. Hella 700ff replaces 500
  237. looking for top plate dimensions
  238. Key - keyhole (ignition) locks up - won't turn
  239. What is the best model year for 3rd Gen
  240. 33x12.50's fit on a 3rd Gen?
  241. Newbie Intro
  242. Pic Request - 3rd Gen w/ FJ Wheels
  243. trd supercharger
  244. Another comparison...
  245. Adding a sub amp to stock stereo?
  246. bolts for 99runner skid plate? #'s?
  247. cleaned up the 4runner and got some poser shots
  248. Amsoil synthetic Tranny Oil 50 degree drop
  249. 96 Tacoma Oil shooting out of tailpipe
  250. New Suspension Idea? What do you think?
