timing for 99 4runner V6
Old Sep 24, 2008 | 08:37 PM
stylistic_99's Avatar
need help...i have a 99 4runner sr5 v6 3.4l i did a water pump change and timing belt change... now ive been told by a toyota mechanic that when installin a timing belt that the camshaft sprocket timing mark should be ever so slghtly to the right and then in a haynes book it says that the camshaft sprocket timing mark should be straight up...with that the bottom sprocket is at zero and piston 1 is at TDC....what is the correct way!?? please help
Old Sep 24, 2008 | 08:51 PM
fillsrunner4's Avatar
Put it all to TDC use two clamps while installing the belt to the cam sprockets to hold them in place and get the belt on the crank sprocket, pull the pin on the tensioner and continue
Old Sep 24, 2008 | 09:02 PM
toytech76's Avatar
Dont look at the marks on the timing cover. The marks on the gears should be straight up with the crank at tdc. It will be obvious if they are off 1 tooth either way
voiddweller
19
May 2, 2016 09:10 PM
vasinvictor
Jan 20, 2016 12:39 PM
Ichneumon
Sep 27, 2015 04:21 PM
crazypaint
Jun 23, 2015 03:27 AM
bobbybouche
Jun 18, 2015 10:22 AM
