hella micro de's installed
Old Oct 2, 2008 | 10:05 PM
Elton's Avatar
found a set off ebay in real nice shape for real cheap .... i made up a few brackets for the lights and the stock bumper has these little tabs that have holes in them for the stock fog lights that are a option for 96-98 4runners so no drilling or anything .... i like them they work real nice
Old Oct 3, 2008 | 05:37 AM
pfdaxe's Avatar
Good find! Are you going to do the HID mod to them?
Old Oct 3, 2008 | 11:19 AM
Elton's Avatar
hid would be awesome if i can find a kit cheap enough i will
Old Oct 3, 2008 | 11:22 AM
BajaRunner's Avatar
Whoa . You're license plate tripping me out brah.
Nice lights. They are like little nipples.
Old Oct 3, 2008 | 12:21 PM
pfdaxe's Avatar
This is all you need and it's what I run in mine (4300k H3):
http://cgi.ebay.com/ebaymotors/CAR-H...mZ270280731012
Read my postings with pics. The HIDs make a huge difference:
https://www.yotatech.com/forums/f2/9...99/index2.html
Old Oct 5, 2008 | 04:05 PM
Elton's Avatar
$50 dollars for that kit is a hell of a deal ill have to order that sometime
Old Oct 6, 2008 | 08:13 PM
Elton's Avatar
i like these lights they fill in the low beams nicely and throw more light to the sides
Old Oct 6, 2008 | 08:16 PM
OSU4Runner's Avatar
Nice...I wonder if I could mount these in my stock fog light spots
Old Oct 6, 2008 | 09:27 PM
freeridethis206's Avatar
i have a 2000 limited... looks identical to your avatar. just installed the micro de's a few days ago. you need a special bracket but they fit perfectly. also very bright. i got mine from here (the bracket and all hardware is included)
http://www.yellowandbluelighting.com...3/Default.aspx
Old Oct 6, 2008 | 09:46 PM
One_96TR4's Avatar
Yup, there a direct replacement for the 99-02 fogs. They are what toyota used in the 99-02 4runners.
Old Oct 7, 2008 | 06:07 AM
Rock Slide's Avatar
That's exactly where pfdaxe put his:
If you're looking for a pair of these micro de's, I may have a pair for sale...although, not as low as $12 .
Old Oct 7, 2008 | 06:48 AM
Fo_SheeZy's Avatar
Looks good, definitely get some HID's!
Old Oct 7, 2008 | 07:07 AM
Sloan's Avatar
so are the hella DEs what are factory in 99-02 4runners or they will just fit in the 99-02 4runners factory spot?
Old Oct 7, 2008 | 08:16 AM
OSU4Runner's Avatar
Can they be wired up to the stock harness so you can use the switch on the headlight arm?
Old Oct 7, 2008 | 08:24 AM
pfdaxe's Avatar
Sloan:
If you read the other threads on this, you'll see that they are replacements for OEM.
OSU:
Yes. You just splice into the OEM harness. Read my thread
Old Oct 7, 2008 | 06:32 PM
if you already have stock fog's then its just a matter of disconnecting the stick lights and plugging them into the new micro de's
Old Oct 7, 2008 | 07:12 PM
algranger's Avatar
ah you finally got them things on there..looksnice
Old Oct 7, 2008 | 09:25 PM
Sloan's Avatar
Originally Posted by pfdaxe
Sloan:
OSU:
so i guess that HIDs want fit in the factory place then?
Old Oct 7, 2008 | 09:41 PM
NorCrawler's Avatar
Night pics or fail..
nvdesertrunner
May 11, 2020 08:18 PM
Regency
20
Jan 3, 2020 07:43 PM
punks_is_4x4
Aug 21, 2015 01:35 PM
Esibnitsud
Jul 30, 2015 08:19 PM
