ARB Taco bar and 99 SR5
Old Sep 14, 2008 | 10:55 PM
TC4RNR's Avatar
well, i got an used Taco bar and planning upgrade. it didn't come with any instructions. i did call ARB USA and got a pdf manual via email. sadly, it was for a Tacoma.
so, my question is "how much you cut off the front end of the frame?"
here is what i have right now:
the frame has not been touched, all factory. should i cut at "1" in front the hole or some where near "2" behind the hole. i'm planning on doing the swap this week. thanks.
Old Sep 15, 2008 | 12:27 AM
AppleJack's Avatar
Let's see if I remember right. I think you're only supposed to cut those upper and lower tabs off, just where the upper and lower bolts are and not actually cut the frame. There should be a threaded hole in in between those bolts but you're current bumpers mounting pads are covering them now.
Old Sep 15, 2008 | 08:07 AM
TC4RNR's Avatar
i don't think there is one on the 4Runner, at least for the 99. take a look at Trevor's picture here, his truck is the same as mine only in different colors.
Old Sep 15, 2008 | 04:02 PM
TC4RNR's Avatar
anyone? i'm leave for a biz trip on friday and reaaaally want to have the bumper installed before that.
thanks.
Old Sep 15, 2008 | 07:11 PM
4runnin2's Avatar
Just look at the bracket that slips over the frame ends. I don't think you have to cut the frame, I didn't have to on my 97. Just had to trim up the end plate so the bracket would slide over.
Old Sep 15, 2008 | 07:29 PM
CASTAIC 4RUNNER's Avatar
all i had to do was cut the frame rail at the end and grind down the burrs and the impact absorbers just slid right on...the instructions are HORRIBLE so expect any help from them, unless you are putting a winch on too cuz thats all the instructions talk about!
good luck
keep us posted
Old Sep 15, 2008 | 07:32 PM
sorry just read your question... cut the least you can
Old Sep 16, 2008 | 09:36 AM
TC4RNR's Avatar
got it. thanks folks. i'll see if i can get it on tomorrow night.
he's gone
7
Dec 3, 2019 07:08 AM
justdifferentials
Just Differentials
Sep 17, 2015 06:14 PM
Crgrey42
Aug 10, 2015 04:23 AM
coffey50
Jul 28, 2015 10:55 AM
