- 5VZ-FE Valve Springs Coming soon....
- TRD Tundra Coils with Revtek
- 3.4 Water Pump - what gasket to use?
- OME kit opinions
- Places near San Diego that deal in off-road upgrades
- Cornfed 3" with 305/70/R17 on a '98
- noise under dash
- 1997 4 Runner - Looking to buy, need input
- 3" Front Lift + 1" Diff Drop = OK?
- Uncomfortable drivers seat
- Lengthening the rear links... Does this look right?
- A Bunch of Suspension questions
- Removing starter and replacing contacts on 99' 4Runner
- FJ or Taco
- ROCKCRAWLER STREETLOCK....Question?
- Thump noise from rear
- Tundra Brake upgrade for 3rd gen 4runners/partial Rant
- Clicking/ chattering from rear right tire?
- 98 4Runner - What Mods?
- Slick's Lift, Tires,Wheels UPDATE *PICS*
- Donahoe,Downey,Billstines and total chaos.
- Oil filter P/N for 3.4L?
- Left turn blinks super fast, but. . .
- Pond Liner GapGaurds...
- What bolts up to what?
- 2003 Center Console Help
- Cigarette lighter question
- Taco Overheating?
- Cleaning polished aluminum wheels
- Lift Questions
- 98+ Front clip on 1996 Tacoma?
- stock exhaust and hood
- Tuning Issue - Stuck in Closed Loop???
- Value of 98/99 4Runners(Possible Purchase)
- Radiator Cap with Temp Gauge on it
- Vac Guage help
- 2001 4Rnr under hood noise and idle issue
- Running Rich Bank #1
- my new sliders that i made pics
- tjm t-17 installed! *pics*
- pic request: 3rd gen t-stat
- Gas gauge won't work on 99 4Runner
- high or reg. pressure walbro?
- I added another inverter and removed my rear seats today.
- 99-00 Transfer Case swap onto 96-98
- squeaky sound from startup
- seat belt tensioner
- Need small spring for Aisin Hub
- 3rd Gen Cheap Power Brake Flush
- 3RZ engine upgrade
- Troubleshooting engine codes?
- buying a wrecked 4runner back from insurance company: is it worth it?
- brush cables?
- 3.4 4runner VS 3.4 tacoma horsepower question??
- Utimate 3rd gen?
- Locker for Daily Driver
- frozen calliper (sp?). can it be un-frozen?
- Deck height and piston size of the 3.4?
- My Girlfriend has a Bigger Truck than You!!
- Driver Door Power Lock Problem
- Not starting and couple electrical problems..
- pictures of lift for sell
- Shifting Issues
- Body lift vs. Suspension lift?
- 1997 to 1999 tail light difference?
- Stellar Blue Pearl???
- Won't go into 4X4 drive
- installation of brushguard on 97 runner
- Engine is locked, Choices to make?
- Tundra top plate same as 3rd gen 4Runner?
- Check engine, injector or O2
- Yet another shock question
- Is this a weird tire size for 4R? 255/70/16
- 2002 4Runner Master Cylinder Internals
- 5vz-fe fuel injectors: Why did they change after '98?
- 3rd gen 4runner body lift question
- Starter Problems 99 4Runner
- Brake upgrade
- Question about 2.75" EZ-Lift Spacer
- Timing belt, seals?
- Swapping axles, couple of Q's
- Anyone got pics of Jaos Victron Excell rims on Runner??
- vsc,trac,abs lights are on
- Flutter in engine compartment
- JDM Headlights??
- Where can I find this for my truck?
- New Rig!!! '98 4Runner
- Is the 2.7 as reliable as the 22re?
- Bump stops: How to remove?
- For all of those who are supercharged-
- why does this supercharger look different?
- Stubbs sliders installed...
- New Wheels!
- 2.5" cornfeds
- 3.0 vrs. 3.4
- Anybody running 15" rims on your 3rd gen?
- Got a S/C with piggyback? Wanna try something?
- Lifting wife's 4runner
- Wheel Size
- Parking/signal combo light modification - any out there?
- Panhard drop bracket bolt-on 3rd gen
- What superwhites are you using for 3rd gen (99+) fogs
- Front lift suggestion
- Final Buildup of '01 4runner Sport
- Head Gasket Replacement
- Delay in transmission when shifting to drive
- Newbie sayin hello
- True Amber Corners for 3rd Gen?
- Shaking 4runner After Lift.
- Window curtains/shades for sleeping in back?
- Advice on shocks?
- '99 4wd spring question
- 3rd Gen Leaking oil
- Buying a 3rd Gen, how does this deal sound?
- CEL P0120 Throttle Position Sensor/Switch A Circuit Malfunction
- Brake problems
- Help with fuel line
- sport edition emblems
- Starter problem with cold weather
- Sounds behind dashboard
- Roll Call: 3rd Gen V6 owners w/rear lockers
- Electrical Meltdown
- Thinking of Cornfed 3 inch
- TSB: what is it and how do I get them done?
- Looking for a Brush guard w/o breaking the bank
- 1998 Brake Release Thud in the Rear
- Reactions to IFR mod on 97's anyone?
- 98 4runner wont start, alarm/starter issue, need help ASAP!
- Check Engine Light
- Any body got a picture of an Eclipse AVN5435 in a 4Runner
- Wheels, backspacing and spacers
- My poor clutch!
- Will these wheels fit my 4runner
- Did I mess up! sagging REAR suspension
- timing belt replacement
- 99 4runner Parts
- Important - Please Read - EATON TORQUE CONTROL
- Ignition Tumbler Problem
- 1997 4runner coil springs
- Looking for an Engine
- DC TRD Tundra Coils same as Access/Xcab/Reg Cab?
- poor acceleration under highway conditions
- Are these fender flares stock?
- 99 4runner Toytoa Spark Plug Wires
- What can I get for a 3rd gen power antenna?
- Who? 3rd Gen, full armor, Kansas, Light Blue
- Which bumper?!?!?
- Anouncing the newest member to the family "1996 4Runner Limited 146K miles"
- 4Runner starting to shake on highway
- Manual a/c to electronic climate control
- Hi from a new member!
- Dash Lights
- I'm shocked at the difference...
- which shocks to go with??
- Manual Hub Conversion, about to do...
- Offroading with a 5 Speed
- Digital Climate Control Burnt Out -- The Fix.
- Reinstalling taco third member
- Alarm system
- Help with CEL's
- I need some 3.4 vacuum part pictures
- front windows "loose"
- Professional Rustproofing
- Air conditioning
- Leaking outter cv
- 4wd Lo questions
- O2 and emission warranty
- 04 Taco - 30K Tune Up
- 4Runner Possible Slip Yoke Binding.
- finally my christmas present came!
- what year taco
- What part of 95 was my Tacoma made?
- 1998 4Runner: Want to understand stock ECU timing operation
- leaky coolant
- Supercharger nose support brace?
- Help w/ swapping '01 lights to '99
- Rear Gears Screaming?
- New owner w/ squeaky 4Runner
- 3.4v6 Chip???
- HKS OE replacement air filter
- Shocks for '97 Tacoma
- 4wd High won't work
- looking at a 96 4x4 v6 pickup
- 3.4L power upgrades...
- Helpful Tire Calculator/ Comparison Chart
- Fixing a scratch
- 99 4Runner newbie, SC/Suspensions questions
- Lock Right for a 2001 4Runner
- early 00's 4runners vs xterra's
- Waterpump
- Anyone else have problems w/ driveshafts?
- I Need A New Dash
- 3RD gen 4Runner tow points...suffice?
- TUNDRA Front Disc Brake Conversion
- Replaced Catalytic converter to correct CEL, now what?
- how do i remove this yellow tab?
- Tailgate
- How should I mount my driving lights?
- electric fan mod question
- So would these give me a super lift?
- Steering Wheel Trim
- Looking to buy a 2000 Limited T4R
- Installing Indiglo gauges
- good deal?
- Fuel Injector removal
- SC Oil Change
- Warn sells manual hub conversion kits?
- Just bought a '99 4Runner Limited
- Remounting stock rear shocks
- speedhut guages
- OME 906 rear coils (installed)
- extensive runner problems
- E-bay Find - All part numbers and diagrams for 3rd gen runners
- Frame Rust
- How does a normal 02 ride?
- This a good deal on a tacoma?
- 32 inchers on
- Driveshaft Length? 96 Taco
- lift kit pics
- Switched to 32s: Fuel Economy / MPG observations
- 3rd gen parts diagram
- finally did my 99+ HL mod
- Mileage Question On Third '4runners
- scraping on drivers front end
- 1998 4 Runner LTD- 4 wheel drive problem
- timing belt
- Muffler??
- Test driving 97 T4R
- Need clutch help
- Squeak noise from front end. 1999 4Runner
- Front Bumper For a 97 Coma
- 98 6-cyl Oil Capacity
- Replaced my steering rack
- 3rd Gen. CV axle (w/ & w/out ABS??)
- 2001 headlight problem
- 1/4" Tundra trd lift... :-(
- Smog check fail and pass info
- 4WD Problem on 3rd gen. The fronts don't engage
- trd exhaust system
- Just Changed the Fuel Filter! Starts Better!
- 2003 Tacoma doublecab 4x4 question
- Turning Buper Turn Signals Into Running Lights
- Is the 2001 climate control plug and play with my 2000?
- Pics - Toyota mudflaps on Limited fender flares
- OME 3rd Gen What to buy Where to buy
- what modle cruiser is this????
- Best year 4 runner 97-2000
- Paint code for silver SR5 flares
- Where is the button for e-locker?
- 96-02 Black SR5 Flares, where to get?
