Installing Indiglo gauges
Old Jan 11, 2006 | 02:19 PM
maguirre's Avatar
Hi all,
I'm considering buying Indiglow gauges to install in my 4Runner.
Is there a write up on this????
Is there anything I should watch out for????
Any advise will be appreciated.
TIA,
maguirre
00' SR5, 5spd
Old Jan 11, 2006 | 02:23 PM
Bob_98SR5's Avatar
look in the tech section, i wrote one for 3rd gens
Old Jan 11, 2006 | 02:24 PM
Tofer's Avatar
Sponsor
https://www.yotatech.com/~corey/tech/techpage.htm
Old Jan 16, 2006 | 05:37 AM
maguirre's Avatar
Thanks,
I found the installation for a 99 4Runner, not for the 2000 model.
But I'm sure it's not much different.
thanks,
maguirre
00' SR5, 5spd
Old Feb 22, 2006 | 08:46 AM
maguirre's Avatar
"sorry for the long post"
Hi there,
I'm almost done with the installation...
I have a question though.
When I was hooking up the Positive power cable for the gauges
I went to my repair manual to see which cable from the harness that
plugs behind the gausges assembly I had to use.
If you please open this link:
http://www.cardomain.com/ride/2110228
you'll see that the last pic is a copy of the page from the repair manual.
Initially I thought it was going to be the "Headlight Dimmer Switch" in the
"Wire harness Side" (Sorry the page got cut off on the left). This way the
gauges will lit up when I turn the knob for the headlights. I was using my
voltmeter to see which one had a electric charge when I turn the headlights ON...
Suprisingly, It was No. 10 on the "E" section - "TAIL Fuse"
Should I be connecting the positive wire for my gauges to this one???
It's a little odd that this is the only one that has a charge when I turn the headlights knob.
Please advise,
TIA,
maguirre
00' SR5, 5spd
Old Feb 22, 2006 | 10:18 AM
FUZION's Avatar
not to sure about that but when i install mine im just going to wire them up up to the guage dimmer switch, did it in my Acura, that was the easiest way to go
:chicken:
Old Feb 22, 2006 | 10:52 AM
trd_style's Avatar
how to power it up or dimming the lights of your gauges? to power up the gauges, i wired the gauge to my corner lights. which the green is the 'red' wire. and white? i think goes to black wire of your gauge. about dimming, i'm not sure.
gary4runner
Sep 24, 2015 12:53 AM
Esibnitsud
Jul 30, 2015 08:19 PM
Nickyodaman
Jul 27, 2015 12:13 AM
Tyler Cunningham
Jul 11, 2015 10:18 AM
Poncho0206
Jul 10, 2015 06:21 PM
