Is the 2001 climate control plug and play with my 2000?
Old Jan 6, 2006 | 04:40 PM
UNR.Grad's Avatar
The 2001 doesn't have any slides just knobs, looks a little cleaner, is it a possible just plug and play? TIA
Old Jan 6, 2006 | 06:02 PM
MTL_4runner's Avatar
The electronic climate control (with the LCD readout) is not at all a plug and play item if thats what you are asking.
Old Jan 6, 2006 | 06:11 PM
bamachem's Avatar
i'm pretty sure that it is plug and play for the 99+ runners. not so on the 96-98's for sure. again, i think that it is on the 99+, but not positive.
Old Jan 6, 2006 | 07:10 PM
jeremys73's Avatar
would it also be feasible to use the unit from a '99 Limited in a '98 SR5...
sorry for hijack
Old Jan 6, 2006 | 07:18 PM
Bob_98SR5's Avatar
jeremy,
no. different everything. people have tried and failed
bob
Old Jan 6, 2006 | 08:52 PM
UNR.Grad's Avatar
No I just want to go from this climate control
to this
Old Jan 7, 2006 | 06:02 AM
bamachem's Avatar
so, slides & knobs to just the three knobs?
are your slides basically switches, or to they have a mechanical linkage. they should be just switches, and therefore the 01 control unit could be retrofitted. if they are mechanical linkages, you're SOL.
Old Jan 7, 2006 | 06:17 AM
X-AWDriver's Avatar
I don't think the vent switch can go from a slide to just a button since there's probably a motor that controls that part.
Old Jan 7, 2006 | 07:02 AM
Ditto....that is also not going to be a plug and play at all.
Messing with the climate control is not as easy as it may seem on these vehicles.
Old Jan 7, 2006 | 08:05 AM
flying skunk dog's Avatar
unr.frosh, could you a pic of the back of this
Old Jan 7, 2006 | 11:46 AM
Flamedx4's Avatar
UNR - just for clarification - neither of those are Climate Control. They are basic HVAC controls. Climate Control has a readout and you set the temperature and it maintains it.
The correct answers have been given. It won't work (easily anyway.)
The slide controls have cables.
The rotary controls are all electric.
The wiring and components are entirely different.
You would need most of the system plus the harness to change over.
Old Jan 7, 2006 | 02:28 PM
lee's Avatar
lee
that doesnt sound worth it to get rid of a slidebar
Old Jan 7, 2006 | 02:39 PM
Weasy2k's Avatar
What years did they come in? I want to do something like this for my tacoma
Old Jan 7, 2006 | 04:40 PM
UNR.Grad's Avatar
Thanks for the info.
Old Mar 29, 2015 | 07:12 PM
Tuffy1515's Avatar
climate control 2000 4runner replaced on utube
bought 2000 4runner limited and climate control doesnt work consistently, bought chilton book with that being no help, u tube video shows a guy replacing the unit, I was just looking for maybe an instruction manual since it works like the others posts mention very crazy and inconsistent...a mechanical type may be able to replace check out the u tube
Old Mar 30, 2015 | 07:20 AM
DeathCougar's Avatar
It's not possible without changing the boxes. The Climate Control setup (digital) uses servos to move the levers in the boxes. The HVAC controls use cables to move the flaps/doors/levers, until 2001 when they went to Servos and Cable combo. Either way, you cannot interchange them without changing the boxes as well.
crashburnoveride
Aug 28, 2015 09:20 PM
rushw
Jul 18, 2015 01:46 PM
daddio
Jul 18, 2015 10:20 AM
msane99
Jul 17, 2015 10:13 AM
mengquis
Jul 13, 2015 10:39 AM
