- oil leaks everywhere
- Looking for a 3rd Gen. 4Runner Tail light guard
- Low Idle on ’02 Tacoma with 2.7L/4 cyl and A/T
- 3.4L Turbo or Supercharger?
- 1996 2.4l looking at 1996 3.4l parts runner
- 96-02 4Runner Service Manual Online
- Fender flares info PLEASE 3rd Gen 4Runner
- No gauge or Running lights
- Question!
- 1996 Tacoma Transmission Problem!
- 98 4Runner Sas question
- 95 taco standard cab 4x4 leaf springs
- 3rd Gen window track issue?
- Clutch sticking to the floor but not engaged
- crashed it, what are my options
- 2001 toyota 4runner keyless entry help??
- My Toyota And Upgrade Thoughts?
- Connection for Electric Brake Control?
- High Idle on the V6
- Flywheel vs Flexplate bolts dang you Toyota!
- Rear end axle differential diff ujoint noise
- Tacoma Tokico factory shocks on T4R
- 3.4L Idle Issue(I have researched but have questions)
- fuel injector problems, or is it? HELP
- Looking for Running Boards...
- 95. 5 tacoma speedometer
- 02 tacoma wont start. HELP!!!!
- Need help on 96 4runner head gasket
- 1995 tacoma automatic transmission to manual transmission swap speed sensor help
- 3.0 head gasket choice
- FSM missing pages?!?
- Overheating question
- 2001 4runner: Screeching noise - Need help
- Wheel spacers for a 97 runner
- Coil Strut Combo....bad idea??
- Front CV axles
- 96 limited 4WD inop (sorta)
- Do You Have An AFR Gauge?
- Shop Manual and Torque Specs?
- buying 01-03 tacoma
- 2000 Tacoma won't run readiness monitors no MIL
- Life Expectancy of 1997 4Runner
- IDIOT Needs help determining 4WD & Center Diff Lock Status
- Power Steering Stiff @ Idle
- 02 4Runner Auto trans Won't Engage, grinds into P-No Engine Code
- RS3000 alarm issues?
- Towing a Trailer to Alaska w/ 2001 4Runner
- Transmission problem
- Rear bumpstop length for Bilstein 5100 33-187174
- my 5vz-fe engine replacement
- Milo942 1998 Limited T4R Build Thread
- Alternate spare tire locations. Reasons, Pros, Cons.
- Raptor style amber lights.
- Knock sensor circuit codes
- What is this? Need to get a pigtail.
- The Impossible to Diagnose 3rd Gen T4R Issue
- 3.4L motor R&R w/o trans?
- 2001 4runner Throttle position sensor 89452-35030
- Keep my 2002, or get a new Limited?
- 98 2.4L Tacoma rear gear ratio
- Frame Compatibility Questions
- How bad is a HG job? What to look for inside a 3.4?
- 97 3.4l 4R overheating
- HELP PLEASE! blown Fuse 2000 4runner Rear defroster
- Three people in a single cab
- What to look for?? 2001 3.0, 4x4 5sp tocoma
- 2001 TRD Tacoma 4x4? automatic question
- Torque converter measurement
- Elctronic controleled transmission not shifting
- rear window issues
- JDM engine help!!!!
- Front Suspension Help
- Replacement headlights and buckets for 1999 4runner?
- Rear main leak...recommendations?
- Need help. 98 4runner lift
- 4wd Issues - Delay in engaging
- 99 transmission issues
- please help. 96 4runner SR5
- 01 4runner oil leak HELP!
- Any come across a red/white coded 4runner front spring?
- Tundra Shocks/Struts on stock Gen3 Coils
- 3.4 Multiple misfire
- 2002 4runner, code P0136
- Is this the correct ATF FLUID for my 3rd gen runner?
- Knock sensor bypass question
- 2000 Tacoma 3.4l Rear end Grinding Noise
- Fuel Injector Maintenance
- Need OME rear spring advice please.
- Mass Air Flow Sensor Fail
- All aluminum radiator for a 1997 4runner 5 speed
- 96 Tacoma Automatic 2.4L: Dash Brake Light flickers on and off
- 2.7 problem need help
- SS 1.2 and tire question
- Manual hub conversion on 99 Tacoma
- 3.4 to buggy
- any advice please..
- king,fox,sway a way shocks for 3rd gen 4runner
- New to me 4Runner
- Tacoma 96 2.4L: Upper exhaust manifold torque specs
- trans troubles yet again.....
- Recently aquired 03 tacoma
- New to me 98 Tacoma stereo/lighter issue
- Whining sound when in gear
- Need part number for 3rd gen strut stem bushings
- 3.4 Valve train noise?
- TRD ECU for SC
- Are front lower control arm bushings interchangeable (front/back)?
- URD 7th Injector Tuning/AFR Problems
- 99 tacoma
- Upgrade or stand pat?
- 5VZFE Upgrade fuel injector review + results
- Dumb mistake - now no starting
- Tcase grind while shifting into 4hi/awd
- !HELP! Code: p0136
- 2000 4runner - RPM drops when idling in drive.
- Coolant leaking from the upper hose after changing the coolant
- Toytec 3" lift
- Tundra & Sequoia Wheel Colors?
- Recovered stolen truck wont start Master Key/ECM trouble?
- slip indicator light vs VSC light
- Brake fluid reservoir area squeak - 2001 4Runner when cold
- 2002 4Runner actuator
- '00 limited runner door lock issues
- Torque specs
- Headlight adjustment
- looking at a 96 4runner what should i look for ?
- 3rd gen 4runner evap canister buzz
- Buying 3rd gen 4runner - looking for advice
- 1985 Toyota Pick up 4x4 front axle problem
- 'Ol Betsy has some Problems!
- 99 limited- cd head unit replacement options
- fuel inlet pipe?
- 3RZ has no power
- Fuel Injector fun
- Which timing belt kit, oil cooler?
- 3rd Gen 4runner Towing Advice
- Rotor Help
- Differential leaking, breather was blocked, is my pinion seal destroyed?
- Which trans solenoid kit (aftermarket is best?
- Transfer or front diff grinding badly when AWD or 4WD is engaged
- Chassis/firewall to engine block ground?
- Skid plates / under body guards?
- 97 4runner rust found! advice needed.
- 99 highlander spring questions
- Fuel pump concern
- 2wd transmission for 4wd swap
- Brake Issues
- 99 Tacoma pulleys,pulleys,pulleys
- Opinions, Thoughts for on board air.
- Led bar Brow Mount
- Can you blow both heads? Low and variable compression reading with other symptoms.
- metal line?
- friends v6 runner has burned valve socal
- 99 Tacoma rear sag
- 5VZFE Starter noise
- installing fog for a 02 sport. am i missing a part
- Question about removing the timing cover on 2.7
- 3.4 metal shavings in oil
- Grill options
- 96 tacoma 2.7 dies randomly
- viper 571vx remote starter problems
- '98 4runner front-end clunk
- Question about stock front bumper compatibility 98 single cab tacoma
- Anyone ever crack their 99 runner strut tower?
- Kick Down Cable
- Timing seems off. What to do?
- Help with Low Fuel Light Blinking
- Air filter housing
- Where To Buy OEM Tacoma Ball Joints? Who Has The Best Prices?
- 97 3.4 won't start...
- 2001 4Runner Headlights - DDM Projector HID Retrofit
- 98 Transfer Case Issues
- Direct grounded hot side on battery!
- Antenna Replacement
- engine hesitation, surging, low power
- What type of oil for transfer case and diff? 1999 5VZFE AT 4WD
- steering travel question and request
- Axle leak after multiple repairs. Need help.
- So Cal engine builders??
- Advantages of Larger Wheels?
- 1999 limited rear blinker won't work, have power to the connector
- 4runner won't stay running
- Anyone using peanut butter to restore their 4 runner exterior plastics?
- Quick Question About Timing.
- Urd 7th Injector tune Question
- 97 Tacoma 2.7L Exhaust leak and other minor problems....
- Differential Question
- keyless entry gone crazy
- Toyota 2wd Supercharged - Lets Discuss
- 2003 Tacoma Double Cab 4wd V6 Rear Diff Lock
- long travel set up
- 2000 5VZE for a 1997 4Runner?
- JDM 5VZ engine help!!!
- No electrical power to 99 4Runner at all!
- 1997 4Runner V6 3.4L threw piston rod
- Help remove/install 95 4wd tacoma front wheel bearings
- How to get nut off 95 4x4 tacoma front hub
- LED roof top light bar and mount question
- Going price for a 95-00 4wd, v6, extra cab truck . . .
- Pics of 4runners with Flares & Running Boards Removed
- Anyone have a Front Tow Hook For Sale?
- Weird grinding noise from 95 tacoma 2.7
- Timing Cover WONT come off, its loose but it wont slide out!
- most common packages with the 8" rear locker
- Dash light slowly dying, flickering, out...wait, the're back.
- Baffles under valve covers
- 2000 4Runner Limited front clip
- Will 3.4 Block off 98 4 runner work for 03 pre runner
- My next tire
- 3.4 froze, blown freeze plugs, water in oil
- Quick question... help plz.
- '00 3.4L automatic trans overdrive noise
- '98 4Runner Lift
- Rear Lift Info
- 1998 Tacoma 2rz
- My 4Runner Limited. Cleaned up.
- 96 tacoma 3.4 brake light keeps coming on?
- Safari Snorkel releasing 3rd gen 4R snorkel at last
- New Extreme Dimensions 4.5" Rear Bedsides - PN 108888
- Maybe buying a 3rd gen 4runner
- Another 1999 limited 4runner 4x4 won't engage thread...
- Which option should I choose?
- 1997 4Runner 4wd Won't Engage....or Will it?
- Engine rattle
- Transfer Case Wiring Question
- Check engine light blues.
- Change Transmission shifter and OD dont work!!
- P0304 after gassing up the night before
- Making the intake tubing more pliable?
- How to get your leather looking new! Write-up with pics!
- outdoor logic bumpers
- Lowering kit for my 2001 4runner
- Believed Torque Converter issues with '01 Tacoma
- Leakdown test question
- 1997 4Runner rear lower control arms
- Front shock removal on a 96 tacoma extra cab 2wd
- alternator draining battery 300ma leakage current
- could headers cause p0401 on 3rz?
- 1997 4runner sr5 check engine light
- spark plug removal ?
- Engine RPM surge
- 98 4runner won't engage in 4WD, electric issues?
- Question about bilstein struts 99 runner
- 2002 Tacoma Truck Does Not Reverse
- 320,00 miles with 15W-40 oil in the 2001 4Runner
- I have a 04 tacoma double cab with 3.4
- Low Beams do not work, High beams are now Low Beams
- Amsoil Engine flush
- 97 ecu in a 96?
