3.4 froze, blown freeze plugs, water in oil
Old Nov 16, 2014 | 06:56 PM
twoyotas86's Avatar
alright well a friend of mine is trying to sell me his 97 tacoma. it had water in the cooling system (no antifreeze) and it got cold enough to blow the freeze plugs. Now it has water in the oil. it hasnt been driven. the truck is a 4x4 extended cab auto. i can get it for 1000 bucks. do you think it will need a new engine or just new heads or gaskets?
Old Nov 16, 2014 | 10:49 PM
wyoming9's Avatar
Red face
There is really no way to know till you pull it apart and see.
Plan for the worse case you might get lucky.
Old Nov 17, 2014 | 06:04 PM
Jomoka's Avatar
I think the only way water got into the oil is through a cracked block. I'd plan on replacing the motor.
Old Nov 29, 2014 | 12:16 AM
dad4's Avatar
Cracked block or bad head gasket, only way for water to get into the oil.
Old Nov 29, 2014 | 05:28 AM
wyoming9's Avatar
Red face
Just how much water in the oil when it was first checked was the dip stick coated to the top.
Did the water push the dip stick out ?? A path of oil and water down the side of the block?
How long did it sit like this big swings in temperature will get lots of condensation in the oil.
Once that first freeze plug popped out any pressure was out of the cooling system.
MO transplant
Apr 23, 2023 11:58 AM
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
bryan34w
Jul 6, 2015 05:53 PM
elwood73
Jul 5, 2015 07:07 AM
