97 ecu in a 96?
Old Oct 23, 2014 | 04:47 PM
Boostum's Avatar
97 ecu in a 96?
howdy guys just wondering if a 97 4runner 4x4at 3.4 work in a 96 4runner 4x4 3.4at? im getting mixed results searching online and calling Toyota well there no help at all thanks guys!
Old Oct 24, 2014 | 12:10 AM
wyoming9's Avatar
Red face
As long as the numbers match on the units that is really what one goes by if you just want a plug and play
So get the number off the one you have that is the one you want.
Old Oct 24, 2014 | 01:47 PM
TheDurk's Avatar
Doesn't look like they are the same numbers. These should be the ECM p/n's involved:
89661-3D150 (11/1995 - 07/1996)
89661-3D320 (08/1996 - 11/1996)
89661-3D321 (12/1996 - 07/1997)
As you can see, there was a switch four months into MY '97. I have no idea why.
This doesn't mean it won't work. It means it is not plug-and-play (or probably not.)
What you need to do is buy yourself a $15 2-day pass on TIS and download the wiring diagrams for Starting and Ignition and Engine Control and ETC (A/T) for '96 and '97, and then compare plug-by-plug, pin-by-pin, wire-by-wire what each ECM connects to. Maybe the plugs are the same but they need a few repins. Maybe the changes are minor spec changes internal to the box and it will work fine. Maybe the plugs are different but you can transplant a donor plug or two and repin.
Unless you can find someone who has done the exact same p/n swap, there is no way to know unless you do the homework.
If you get the diagrams, I'll try to help. I think I have '96, but it doesn't help, you need both.
Old Oct 25, 2014 | 09:23 PM
dntsdad's Avatar
What is your ecm part number?
I assume yours is a 96 and someone gave you a good deal on a 97 ecm.
My guess would be it will be fine. Little change from 96 > 97 but only an exact ecm swap would be ideal. What was posted above is sound advice and I can send some diagrams if you pm me your email address.
Rerun
3.4 Swaps
Oct 1, 2015 12:24 PM
bradahman
Oct 1, 2015 09:24 AM
Boomer8404
Sep 24, 2015 01:12 PM
Dobich
Sep 14, 2015 11:15 PM
zz_denis
Sep 6, 2015 03:43 PM
