Manual hub conversion on 99 Tacoma
Old Jan 26, 2015 | 10:43 AM
Luke99tacoma's Avatar
How much is a manual Hun conversion gonna cost? Should I have a professional do it?
Old Jan 26, 2015 | 10:54 AM
JasonYota's Avatar
Defiantly a professional job
Old Jan 26, 2015 | 10:55 AM
have any idea for a price point?
Old Jan 26, 2015 | 11:49 AM
JasonYota's Avatar
Haha. It's pretty easy. What year is your truck?
Old Jan 26, 2015 | 12:48 PM
it's a 1999
Old Jan 27, 2015 | 12:16 AM
wyoming9's Avatar
Red face
Now Jason`s first comment might be more on track.
I take it this now has ADD a little more involved then just removing drive plates.
Then does it have manual hubs you just need to change??
Please lets us know just which one??
Old Jan 27, 2015 | 05:48 AM
habanero's Avatar
Some tacos came with manual hubs....some with abs too. Could be "bolt-on" depending on what you find and how bad you want to keep your abs if you have it. You'll need the cvs too, they're different from the add version. If you have abs and get the hubs without abs you may need to change how your speedo gets its signal...or have an abs ring pressed in.
I stuck manual hubs on my 4Runner and fixed the speedo issue. It wasn't cheap and it wasn't hard. Since you're having 4wd issues maybe start with working on that first. Manual hubs are not the solution for that....unless you're changing out the front diff while you're at it. Mayhaps start with some testing of vacuum and electrical first.
Old Feb 5, 2015 | 01:27 PM
Originally Posted by habanero
Some tacos came with manual hubs....some with abs too. Could be "bolt-on" depending on what you find and how bad you want to keep your abs if you have it. You'll need the cvs too, they're different from the add version. If you have abs and get the hubs without abs you may need to change how your speedo gets its signal...or have an abs ring pressed in. I stuck manual hubs on my 4Runner and fixed the speedo issue. It wasn't cheap and it wasn't hard. Since you're having 4wd issues maybe start with working on that first. Manual hubs are not the solution for that....unless you're changing out the front diff while you're at it. Mayhaps start with some testing of vacuum and electrical first.
thanks brother
Old Feb 5, 2015 | 02:15 PM
habanero's Avatar
You're welcome sister!
Old Feb 5, 2015 | 04:25 PM
JasonYota's Avatar
thanks brother
Uh Habanero is a lady, not a guy…
Old Feb 5, 2015 | 05:45 PM
habanero's Avatar
Not that I care, but I can never seem to resist the sister bit when someone calls me a dude.
BeMiceElf
Oct 10, 2015 09:40 PM
jaretstuff
Aug 4, 2015 02:08 PM
PlayAwhile
Jul 20, 2015 11:36 AM
Poncho0206
Jul 10, 2015 06:21 PM
ItsJustD
Jul 7, 2015 07:49 AM
