Rotor Help
Old Dec 30, 2014 | 06:43 PM
tpg013's Avatar
Junior Member
Rotor Help
I have searched and searched on here with no results.
I have an 04 Tacoma 4x4 3.4L, manual.
I need rotors and was looking to get a pair of Brembo blanks, but I cannot seem to find them anywhere. Do they make them for my truck? If so, does anyone have part numbers?
If not, open for any advice on alternatives.
Appreciate the help.
Old Dec 30, 2014 | 07:03 PM
rworegon's Avatar
Try Brembo's website:
http://brembo.mycarparts.net/
Old Dec 31, 2014 | 04:16 AM
tpg013's Avatar
Junior Member
Thanks but that shows only 2wd mine is 4wd.
Old Dec 31, 2014 | 05:23 AM
rworegon's Avatar
Hmmm, I find Brembo rotors for your rig.
I used these selections: Toyota, 2004, Tacoma, Disk Brake Rotor, 3.4L V6 3378cc, Base
Are you sure all of the rotors that come up with this selection will not work for your application?
Old Jan 1, 2015 | 12:40 AM
wyoming9's Avatar
Red face
My last Rotors and Pads came From the Dealer Price was not bad.
It is getting harder to find parts not made in China.
Old Jan 1, 2015 | 03:42 AM
tpg013's Avatar
Junior Member
What you have indicated above is for a 2wd not a 4wd.
Old Jan 1, 2015 | 05:59 PM
KZN185W's Avatar
Here's some info on the front disc dimensions. HTH
File Type: pdf
Old Jan 1, 2015 | 07:52 PM
rworegon's Avatar
The Brembo pdf KZN185W provided above is on target.
Ok...I'll admit my eyes are old and tired but it certainly seems I see rotors for your 4wd rig depending on features:
09.7226.10 Oe ReplacementDisc Brake Rotor
  • Nominal Thickness (mm): 22
  • Outside Diameter (mm): 319
Front
  • 3.4L V6 3378cc
  • Base
  • 4WD
  • Electronic Stability Control
09.7226.11 Premium Uv Coated Oe ReplacementDisc Brake Rotor
Front
  • 3.4L V6 3378cc
  • Base
  • 4WD
09.8193.80 Oe ReplacementDisc Brake Rotor
  • Nominal Thickness (mm): 25
  • Outside Diameter (mm): 297
Front
  • 3.4L V6 3378cc
  • Base
  • 4WD
  • Exc. Electronic Stability Control
09.8193.81 Premium Uv Coated Oe ReplacementDisc Brake Rotor
Front
  • 3.4L V6 3378cc
  • Base
  • 4WD
Old Jan 1, 2015 | 11:51 PM
wyoming9's Avatar
Red face
Perhaps your looking at two different online catalogs??
Following the link You provided
Looking up 2004 Tacoma I found the part #`s you have all saying 4wd or at least the ones my old tired eyes focused on.
might be what gave us the old tired eyes looking up parts for longer then I want to think about !!
Old Jan 2, 2015 | 02:14 AM
KZN185W's Avatar
a good alternative to brembo discs would be dba 4000 T3 4x4 survival series (these are what I have on my truck):
http://www.tirerack.com/brakes/brake...tor&cat=Rotors
Old Jan 2, 2015 | 04:35 AM
rworegon's Avatar
Originally Posted by wyoming9
Following the link You provided Looking up 2004 Tacoma I found the part #`s you have all saying 4wd or at least the ones my old tired eyes focused on.
Wyoming9, thanks for using the same link and confirming my findings.
Old Jan 2, 2015 | 10:11 AM
wyoming9's Avatar
Red face
Your Welcome !!!
ladybugRC
458
Aug 21, 2020 10:41 AM
Kamaloha
Oct 16, 2015 05:13 PM
the_supernerd
Oct 1, 2015 09:20 PM
hiluxinargentina
Sep 30, 2015 05:51 PM
Toys4parts
Sep 26, 2015 01:56 PM
