Leakdown test question
Old Nov 3, 2014 | 09:56 AM
4Xtruck's Avatar
I've made a leakdown tester and plan on testing my '97 Tacoma 3RZ-FE. I understand how to test cylinders 1 & 4, but going with TDC, how do you get both the intake and exhaust valves closed at the same time on numbers 2 & 3? Can this be done without taking off the cylinder head cover? Hopefully, it will be as simple as 180° rotation of the crankshaft rather than 360°.
Old Nov 11, 2014 | 01:23 PM
4Xtruck's Avatar
After doing the leakdown test, I discovered 2&3 are 180° from TDC. I put a long narrow screwdriver into the sparkplug opening and watched it rise and fall as I approached that spot.
Blamalam
Mar 12, 2022 07:34 AM
the1998sr5
15
Jul 14, 2020 08:35 PM
makemusic116
Aug 2, 2015 04:40 AM
cgilley
Jul 25, 2015 10:55 PM
