5VZFE Starter noise
Old Dec 13, 2014 | 10:58 AM
azcat90's Avatar
5VZFE Starter noise
My V6 97 4Runner Limited starts but the starter makes a grind noise at the end of the start that is the same sound as when you try to start a vehicle that is already running. Does the starter need to be replaced?
Old Dec 13, 2014 | 11:24 AM
rworegon's Avatar
For the original Denso starter, you can put in new contacts and a plunger to likely solve the problem. Don't put in a "lifetime warrantee" starter...rebuild the Denso if needed!
Another possibility....the gear on the starter is very worn and causing the issue.
Old Dec 13, 2014 | 01:15 PM
wyoming9's Avatar
Red face
Either worn or very dirty starter drive sometimes called the starter clutch.
For what ever reason it is hanging up.
As was said it could be pitted contacts causing the circuit to take longer to open then it should
Old Dec 13, 2014 | 01:32 PM
azcat90's Avatar
Thanks for the help. I have a new reman denso starter ready to go in once I have the right tools. Since it is the original starter and it now has 283K miles on it - I'm replacing the whole thing.
Old Dec 13, 2014 | 02:27 PM
ThorInc's Avatar
Have it rebuilt...
Bourbonblues
Dec 15, 2017 05:43 PM
LotOMiles
Sep 14, 2015 11:45 PM
Corvoid
Sep 14, 2015 10:10 AM
Kreedy1
Sep 8, 2015 06:33 PM
LJR
Sep 5, 2015 06:02 AM
