Fuel pump concern
Old Dec 22, 2014 | 05:00 PM
pcurtice's Avatar
Fuel pump concern
Have a quick question for you folks and appreciate you taking the time to consider my question. My sons 1996 Tacoma 2.7 would not start today. Yesterday it was difficult starting as it took a handful of tries along with needing to be jumped. I have pretty much lived by the rule that if you don't hear the fuel pump cycle upon turning the ignition key then you more than likely have a fuel pump concern. Is this correct?
Here are some facts regarding this issue.
1. no cycling of fuel pump upon turning ignition key.
2. engine does fire intermittently upon turning over.
3. Check engine light comes on upon turning ingnition key on. Hoping this would rule out a problem with the ECU.
4. Lately it has been idling rough on occasion. Especially at stops.
5. Have tried holding the pedal floored today while turning over. No luck, but could smell a bit more gas after doing so.
I haven't checked fuel pressure and am planning to do so tomorrow. Will also check power to fuel pump. Just curious as to whether the lack of hearing the pump cycle pretty much means it is going or is gone. I did a bit of surfing on the site and it appears it could be a host of things that could be of concern. Any advice would be greatly appreciated. Thanks again.
Old Dec 23, 2014 | 02:19 AM
Texas_Ace's Avatar
Best way to test for a fuel issue that I have found is to take off the intake pipe at the throttle body. Then get a can of brake cleaner or Starter fluid and have someone turn the engine over while you spray it at the semi-opened/opened throttle body. If you still get nothing, then time to look else where.
If it starts and runs as long as the fluid is being injected, then it is a fair bet it is a fuel issue.
Old Dec 23, 2014 | 03:40 AM
pcurtice's Avatar
Thanks for the tip Texas Ace! Will give it a try today.
Old Dec 28, 2014 | 07:52 PM
TheDurk's Avatar
At least on the V6, the fuelpump does not run until the starter motor engages (or the engine is running). It does NOT run with just key in ignition on position. I donīt know about the 2.7.
Old Dec 29, 2014 | 04:02 AM
pcurtice's Avatar
Pretty much the same with the 2.7. Determined the fuel pump was working so changed out wires, plugs, and fuel filter. Those items were due for a change anyway. That was the fix. She fires right up now. Thanks for the input.
sandyota
Feb 4, 2021 11:16 AM
Sep 4, 2015 09:27 AM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
Fundy Rider
Jul 16, 2015 01:35 AM
Tyler Cunningham
Jul 11, 2015 10:18 AM
