- In virginia?
- inconsistent miss
- Need help with missing engine.
- front lift question
- rim specs
- starting problems
- My saturday projects done!
- optima marine battery in the runner?...
- Need a carfax please!!
- Which wire is + and which is -?
- [HELP] ARB compressor leaking oil?
- Anyone ever used this part?
- Throttle body spacers
- whens a good time to sell?
- Anyone running the ACT HD PP with street disk?
- HD Video of my Supercharged 4Runner sand draging
- 99 headlights on 97
- LED Bulb in Shifter...
- Darn high idle
- Slick roads in 2wd
- Test pipes & URD simulator problem
- Heres My 6in 99 Runner
- headlight moisture
- Clutch pedal will not fully retract?
- New shocks... Lift?
- Stiff clutch
- Which airlift airbags for my 3rd gen.
- 4Runner that I'm checking out..
- Another Sparkplug thread. I searched...
- I want 35's on my 4runner....the parts list is cyclic.
- Lift height clarification
- when did 3rd gen homelink start?
- 96 Runner spring sag
- knocking noise
- Spare Tire Wheels
- 3rd Gen stock OEM wheel backspacing (offset) w/ pics
- Anyone has info on TSB EG034-07 (O2 sensor-related)
- J/Y score today
- 01 4Runner rear door windows (rear vent glass)
- Spotted it 1/14-98 4Runner part outs (2)
- MacNeil weatherflectors, best price???
- cricket noise from engine at idle
- 2000 Toyota 4runner SR5 bumper end problems
- 3.4 lifter replace How-To??
- Landcruiser ARB's on a 4Runner?
- '96 4Runner runs rough and rich OBD-II
- 3" 4crawler body lift installed :) and love it !!
- Trail riding and mudding in a manual?
- removed emblems, how do you make the paint under the emblem shine again?
- Help for rear window!!
- new(?) rear bumper option for some
- 98 4 runner, clutch pedal popping/squeaking!!
- 1999 2wd 4Runner
- Illuminated Cup Holders
- looks like i'm getting new rubber afterall.
- Lifting A 3rd Gen With A 2" Body Lift
- Toyota or Dayco
- water pump gasket leaking after replacement
- HomeLink - HELP!!!
- 99+ dash panel into 96-98
- body lift on top of a suspension lift?
- can you put a lift on a lift?
- Can I use these Hella 100/80W lights in my stock headlights
- Stock Front Bumper
- Will this shock work?
- Bumper mounted lights?
- Wheel decisions
- Sport Hood.
- bent spring perch?
- Getting my 285's today...
- Wheel Painting Question
- revtek with ome 890's
- How capable is this thing stock?
- What is your latest Mod?
- Gen 3 Auto Dimming Mirror Complete Install
- Leaky caliper bleeders?
- squeeling engine...
- Advice real needed
- 2wd performance mod advice wanted
- Weekend Project DONE! (PICS)
- TJM-15 for '98-02 -what's involved to make it fit '97?
- Factory Aux light harness install help!
- opinions on new gears
- 4runner front end ??
- flushing coolant using compressed air?
- Brake problem after 3 weeks...
- Well, back from dealer and my butt still hurts!
- was this ebay deal too good to be true?
- Washer and Door Lock Controls Switched
- Rear window stuck in down position on 2001 T4R
- ignition coil OHM Readings... 97 4runner 3.4 V6
- interior retaining clips?
- I just had my starter replaced
- 4Cawler 3" BL help/options....anyone who else has this setup....
- Things to look for in Tacoma
- slight vibration after PP 1" spring install
- exhaust manifold question? please help
- Can't tell if 4WD is engaging
- someone must not value thier life.....
- 01 Taco- Mud Flaps
- My 4Runner reached a milestone today!
- installing 05tundra coilovers in my 96taco.....
- stupid shock/spring questions
- will 35" nittos fit a runner with 3'' bodylift?
- pulling transmission during clutch job
- Recommended Spark Plug Wires?
- TRD Exhaust CHEAP
- I can change my sig line now!
- Holy raked front end batman!!
- I hate starting this thread, manifold crack?
- Power steering rack options?
- How Much Lift Needed To Run 315/75/R16?
- Time for a new auto trans, who's done one?
- why mod a 2wd??
- Scored a sport hood!
- Getting off the darn fender liner snaps
- Turboxs KnockLite giving false warnings?
- Traction Control
- Silverstars vs Ultras
- Rear Drive Shaft Question
- diff drop, need more than 2 inch?
- spring compressors
- Need more torque
- Another question about wheel spacers !!!
- 550cc inectors w/ S/C
- Horn
- Odd drivetrain problem...
- Broken Cruise Control
- Tuning open loop Q' w/R4 ware
- 3 joint driveshaft?
- Anyone seen or have any experience with this setup?
- a/c rebuild (for the a/c experts :) +pics
- what in the world does this tube go to w/ pic.
- Adding to the family
- 98 4runner HIDZ WITH PICS!!!!
- 4Runner - sticky front brake calipers?
- 4Runner - rattle/clunky noise coming from rear
- Flowmaster 50.
- 98 4Runner Cluster Swap Canada/US
- Properly adjusting headlights
- CEL, Traction Ctrl Lights.. What did I do?
- tire squeal?
- My light set-up
- Wanting to replace stock 1998 fog light blubs...
- 6 inch Fabtech
- Rock slider?
- Protection for 99+ stock fog lights foglights?
- acceleration problem?
- question on lifting rear of tacoma
- TC Lift Questions
- 96 runner shakes & stutters till 2.5k....
- I'm finally part of the club! Here's my introduction and progress thread...
- Needs someone to Direct me
- Which starter do I have?
- Does this sound reasonable?
- 04 Tacoma Double-cab bed design
- in need of a good yota shop in Orange County
- 98 runner rear window move after engine crank
- tacoma bed
- running boards are off, not sure what to do with the hole?
- OBD II Code PL120?
- Need Opinions on Polyurethane Body Mounts
- Probably Easily Fixable : Alarm Problem
- dont forget to run 10 miles per month in 4wd
- Which keyless entry remote do I purchase if I don't have an original?
- Need help wiring new stereo. Keep blowing 15 ACC fuse.
- KC lights, and storms in my area
- Sacramento Yota Heads i need help!!!!!!
- 2000 t4r nerf bars
- Wearever Brake Fluid
- Thinking of new rims? Need opinions
- How to clean out Sludge?
- Possible Transmission Issue
- lift installed. pics of truck and other random crap
- Is the rear dome light supposed to come on when the rear hatch is open? 97 4runner
- Stripped Exhaust Bolts
- How would these wheels look on my 98 4runner
- FJ's 17's fit a 99 4runner w/16's?
- FS: Yakima Mega Warrior + Extension & Cargo Net
- Added Body lift and clear corners! (PICS)
- Mobil 1 Syn multi-vehicle atf?
- Dx needed: trans fluid in radiator?
- Replacing axle with e-locker axle
- Adding lights to roof basket?
- 1998 4runer ECU location?
- water pump gasket - RTV required?
- Clunk After Rear End Collision
- Lift Mystery
- Tried Searching, Need to verify steps to get Stereo out of '99
- Looking to purchase a 02 4runner
- ISR Removal Question
- 99 Tacoma squeak (Annoying)
- starting my build up
- spare on roof or hitch mount tire carrier?
- stock gearing tire upgrade
- Check Engine Light error codes found! I bought an OBDII code reader
- Jardine vs. Magnaflow
- Electrical Problem (i think)
- Three idiot mods
- Just ordered my clear bumper lenses from Burtmans (also sticker info)
- Stock Radio Backlighting
- clutches
- Driveline Noise - sounds like a loose belt
- Are single ground plugs a problem?
- Brake Controller & 7-pin trailer Install 3rd Gen 4Runner
- Anyone ever run TRD IS wheels without a lift?
- How often should you change your Fuel Filter?
- Stock number of 1997 4Runner Caliper? V6
- Anyone ever used Green air filter?
- Upgrade the 4runner *help*
- To Pull of Not to Pull Transmission?
- rear sun deflector?
- Towing with a tranny quirk?
- 01 TACO has a P0120 CEL
- Lift info for Newb - Complete FAQ
- Dash Light install....HELP!!!.
- Where can I buy a steering rack rebuild kit?
- who has a built s/c 5vzfe????
- Need Help
- Water pump changed or not?
- 4Runner wouldn't crank sometimes...
- 120K tune up - What should I have done?
- air locker question
- Just got the timing belt replaced... (MPG's)
- Center Console fab
- Cargo Bay power outlet mod write-up
- Steering Rack Replacement
- 02 4Runner Rear Noise - Solved! (Thanks)
- Electrical Problem on 96 Tacoma...
- Toyota Wiring Harness Help!
- Power Antenna Issue
- 7th injector and Deck Plate
- Busted Leaf Spring--Need Help!
- 99 4Runner limited auto hubs
- First time 4Runner owner...couple of questions...
- HELP WAAG brushguard/bugshield combo? NEED HELP!!!
- Has anyone tried this with "Rhinoliner"?
- *clunk* from the front left when i hit a bump
- Sonoran Steel Lower Links
- where to find 4runner parts
- Anybody added rear heat option to a 3rd gen?
- 2001 SR5 4 Run Instrument Cluster
- "Burning" smell when i drive on cold days
- 96' Tacoma
- Look what I found.
- Did the drive belts- some thoughts afterwards
- Anyone dealt with TSETruckstuff.com?
- Clutch Hydraulic System, NEED HELP...
- Magnaflow ?
- Another Flare Question...
