OBD II Code PL120?
Old Jan 7, 2008 | 07:58 AM
highplainsdrifter's Avatar
OBD II Code PL120?
1999 4Runner 3.4 liter, intermitently throws a check engine light with a PL-120 code. The truck runs fine. When the CEL comes on I reset it and it seems to be fine but in a week or so the CEL comes on again. Other than the intermittent CEL the truck runs fine and just passed smog.
Any ideas on what part/ sensor is going bad?
Thanks.
Old Jan 7, 2008 | 08:04 AM
MTL_4runner's Avatar
Your code is P0120 and there's plenty of info on that one.
Just do a quick search and you'll find copious amounts of reading material.
https://www.yotatech.com/search.php?searchid=4126832
Old Jan 7, 2008 | 09:18 AM
I actually have searched quite a bit and cannot find anything about PL120.
Old Jan 7, 2008 | 09:49 AM
Elvota's Avatar
At a quick glance, seems to have something to do with the TPS sensor.
PM me your E-Mail and I can send the FSM testing procedures in regards to PO120.
Old Jan 7, 2008 | 09:59 AM
Sent, thanks.
By the way, its a PO120... not PL.
Old Jan 7, 2008 | 10:45 AM
Baloo's Avatar
Just had the same problem on my 01. While it could be a hort in the TPS circuit, more than likely the TPS needs to be replaced.
You can get them for anything from around $40 online to $80 + locally (my experience). Not sure what the dealership gets for them.
Old Jan 7, 2008 | 10:50 AM
Elvota's Avatar
Originally Posted by highplainsdrifter
Sent, thanks.
Related FSM sent. Hopefully it will be of some help.
Old Jan 7, 2008 | 11:01 AM
Thanks. After doing some research I believe it is the TPS which is a relatively inexpensive part. The vehicle only has ~90k on it but it is 8 years old so I guess I shouldnt be too surprised a potentiometer is wearing out.
Old Jan 7, 2008 | 11:03 AM
I found it for $39. at Toyota of Dallas... toyotapartsales.com
There is no damage to any of the wire loom and its all 100% stock so I too am assuming its the TPS that is wearing out.
Thanks
Old Jan 22, 2008 | 01:16 PM
kmcaprice14's Avatar
figured it was better to bump a thread than make a new one...
My engine threw this code PO120 (and behaves as it should with a TPS malfunction), so I want to swap it out... but my question is: where is the TPS sensor in the 3rd gen? I searched but didn't see much, so can anyone give me an easy answer? Thanks
Old Jan 22, 2008 | 05:25 PM
It is right on the side of your throttle body.
See attached pic.
Old Jan 22, 2008 | 06:51 PM
ninjarunner's Avatar
it only takes like 5min to replace.
Old Jan 23, 2008 | 02:27 AM
See attached pic.
perfect... i appreciate it
Old Jan 28, 2008 | 09:44 AM
Update to the thread...
I replaced the TPS with a new one which was very simple to do. I verified before removal and after re-installation that the TPS settings were the same with my Scangauge II (10 - 75), although there is no adjustment of this sensor for this year vehicle. The CEL has not appeared since and everything seems to be working fine. I would say time will tell as the CEL only came on very intermittently before, but I think this fix has solved the problem.
Old Jan 28, 2008 | 01:48 PM
It also solved my idle problem.
Old Feb 6, 2008 | 05:37 PM
mikes19984x4's Avatar
i had this code to show up in my 98 4runner and it comes and goes like once a month...however, i never notice any difference in how the truck/engine actually perform...
moparbay
Oct 6, 2015 09:24 AM
bradahman
Oct 1, 2015 09:24 AM
charlie_fong
Sep 27, 2015 10:06 PM
Odin
Sep 26, 2015 06:56 PM
Draven023
Sep 26, 2015 12:41 PM
