1998 4runer ECU location?
Old Jan 5, 2008 | 08:21 PM
superfliez's Avatar
Hi,
I'm a newbie here. Can somebody please let me know excatly where is the ECU for a 1998 4runer LTD 2x4 located? My 4runer has a RS3000 system and I just bought a new aftermarket remote from ebay http://cgi.ebay.com/ebaymotors/ws/eB...SA:MOTORS:1123
according to the discription it should work with RS3000 system, but I'm having trouble locating the ECU, please help..
Thanks
ozziesironmanoffroad's Avatar
under the kick panel on the passenger side.
Old Jan 5, 2008 | 08:25 PM
superfliez's Avatar
Thank you, let me go find it.
Old Jan 5, 2008 | 09:30 PM
toytech76's Avatar
The engine ECU is behind the glove box. Your alarm ecu is under the drivers seat
Old Jan 5, 2008 | 09:31 PM
really? crap... i hate givin wrong info
Old Jan 5, 2008 | 09:32 PM
toytech76's Avatar
lol..no biggie. The engine ecu's for the pre 96 models were in that spot
Old Jan 5, 2008 | 09:41 PM
DeathCougar's Avatar
Why would you need to get to teh engine ECU? You should only need to get to the alarm control unit.
Old Jan 5, 2008 | 09:57 PM
superfliez's Avatar
Yeah, Thanks alot I found it. It's underneath the carpet under the driver seat.
BTW ozziesironmanoffroad is right the engine ECU is behind the kick panel. Now I now where to find it...
Thank you very much
Old Jan 5, 2008 | 09:58 PM
i was right? holy moley
Old Jan 5, 2008 | 10:26 PM
uh no. The ECU for all 3rd gen 4Runners is located under the airbag behind the glove box.
1st and seconds have the ECU behind the pass side kick panel.
Old Jan 5, 2008 | 10:28 PM
The engine ECU is not behind the pass side kick panel. if you found a computer box under there, its definetly not the main ECU. The ECU should have a part number of 89661-XXXXX and will be located under the airbag behind the black plastic upper cover/trim piece of the glove box.
Old Jan 6, 2008 | 07:49 PM
superfliez's Avatar
Yes, my 1998 4runer LTD ECU is located behind the kick panel. The box is a metal case maybe 3x3 big. It says ECU on it with a string of numbers about 11 or 12 digits.
Old Jan 6, 2008 | 08:04 PM
Then its either been moved, or you do not have a 98 4Runner. Imma go with moved. Every 3rd gen 4runner i have taken apart (about 15) have the ECU under the dash.
Old Jan 6, 2008 | 09:37 PM
toytech76's Avatar
And the ecu isn't 3x3. More closer to 6x6. You probably found a ecu for some other part of the car. Like I said before...pre 96 ecu's were behind the kick panel
Old Jan 6, 2008 | 10:05 PM
haha get 'im Toytech.
The ECU part number starts with 89661. What is the part number of the one under the kick panel in your 98?
Old Jan 6, 2008 | 10:08 PM
toytech76's Avatar
Old Jan 6, 2008 | 10:10 PM
iceman601's Avatar
Last time I checked, the unit behind the passenger side kick panel is the ABS ECU.
Old Jan 7, 2008 | 04:10 AM
MTL_4runner's Avatar
Yep, it is according to the FSM.
Old Jul 19, 2008 | 04:34 PM
runner 68's Avatar
I'm also looking for the alarm ECU as I need to program an after market remote. I've a 1998 4 runner 2.7L I tried looking for it under the driver seat but no luck. Need help, thanks.
Old Jul 19, 2008 | 04:40 PM
98runner210's Avatar
+1 my '98 Ltd ECU is below the airbag. There is an ABS one in one kick panel and I think a 4x4 one on the other side
DeathCougar
Apr 1, 2018 11:29 PM
sanctfy
All Other Toyota Swaps
Sep 15, 2015 02:52 PM
O Holy P
Aug 18, 2015 02:33 PM
cr@ves4wheelin
3.4 Swaps
Aug 17, 2015 07:47 AM
Athansinis
Jul 27, 2015 08:38 AM
