Clutch Hydraulic System, NEED HELP...
Old Jan 1, 2008 | 09:47 AM
Choopster's Avatar
Hi,
I have been experiencing for some time now being at a red light and my clutch system bleeding off and stalling the engine. I then have to pull the pedal off the floor and away I go for some time, can be several days or a week. I decided to put a new slave cylinder on today that I purchased at NAPA, it is the exact same as I took off, Aisen. I performed a thorough bleeding process of having my son depress the pedal as I opened up the bleeder valve. I also while opening the bleeder pushed the slave piston all the way in to escape any trapped air, I feel like all the air is out. Now the strange part, what was happening every few days of the system bleeding off, it now occurs before I can get out of my garage, every time I lift the pedal and depress it leaks off. Please help...
Old Jan 1, 2008 | 09:59 AM
DeathCougar's Avatar
Sounds like the master cylinder to me. Have you looked to see if it is leaking? Is it losing any fluid?
The master cylinder can bypass without operating or leaking as well. I would look into that.
Old Jan 1, 2008 | 10:05 AM
Choopster's Avatar
No fluid leaking anywhere. I am just very puzzled as to why a new slave has so exagerated my problem. Thanks...
Old Jan 1, 2008 | 01:34 PM
KdF's Avatar
KdF
The new slave had more back pressure than the old one, thus the final straw.
I am confused.....you pull the pedal off the floor?? Does your clutch pedal spring not work? I don`t have a standard so I am lost.
Old Jan 1, 2008 | 01:43 PM
Adam F's Avatar
I had the clutch pedal to the floor problem on my 88. Replaced the slave cylinder...no dice. Replaced the master cylinder, good to go. (actually I rebuilt the master)
Old Jan 1, 2008 | 03:30 PM
Choopster's Avatar
Thanks for the feedback guys. I think my clutch pedal spring is fine, it seems to require fluid pressure for it to return to the top position. I am going to purchase a master cylinder tomorrow and cross my fingers.
Old Jan 1, 2008 | 03:53 PM
apalmer1's Avatar
yea weather you have a good spring or not wont make a difference, if there is a leak in the hydraulic lines the pedal will litteraly get sucked down to the floor when you start to press it. It will do this if the slave cylinder or the master cylinder has a bad seal or if the bleeder valve is left open. In your case i bet its the master cylinder, they seem to fail much more often.
Old Jan 2, 2008 | 01:01 PM
Adam F's Avatar
FYI i had no leaks anywhere in the system when mine failed
Old Jan 2, 2008 | 03:40 PM
warriors_03's Avatar
Thumbs down
What symptoms where you having and on which runner?
Old Jan 8, 2008 | 08:16 AM
Choopster's Avatar
Hi,
I have replaced the master cylinder and my problem is fixed. Thanks for the feedback...
Old Jan 8, 2008 | 09:28 AM
I win at teh internets and teh Toyota.
Bow down puny mortals! lol jk
he's gone
7
Dec 3, 2019 07:08 AM
Flossy
Aug 5, 2015 05:14 PM
exporunner
3.4 Swaps
Aug 3, 2015 06:10 PM
Shaun Crystal Gomban
Jul 30, 2015 10:13 PM
