Tuning open loop Q' w/R4 ware
Old Jan 9, 2008 | 10:41 AM
jrock's Avatar
During deceleration-open loop, AFRs jump to 17-20-if not higher. Should I increase the cell value on the fuel map for this area? I am just finishing closed loop tune...I am assuming I would move the cell value in the same
direction for WOT-open loop-with high AFR reads, correct?
thx in advance!
98/sc/390cc/walboro
Old Jan 12, 2008 | 02:28 PM
ninjarunner's Avatar
Nobody here knows...........
Old Jan 12, 2008 | 02:51 PM
ornery's Avatar
AFR's jump REALLY high during deceleration because your pumping the engine.. its not a problem and I dont it anything to do with you running open loop. My brother's turbo Civic does the same thing and its closed loop.
Edit: as long as it doesnt ping, I think youre OK.. I'd check other tuning sources though.
"Under very high vacuum (deceleration conditions) run 15.5:1 or 16.0:1 AFR's or even fuel cut on deceleration to prevent lean exhaust system backfiring."
- How to Tune and Modify Engine Management Systems by Jeff Hartmen
Old Jan 12, 2008 | 06:46 PM
mt_goat's Avatar
No, you don't want to add any fuel during deceleration. The A/F is suppost to go really high then.
Old Jan 12, 2008 | 07:33 PM
Ian Rogers's Avatar
you are in fuel cut, the ecu is cutting all the fuel to help with emissions
jb451
7
Oct 7, 2022 06:58 AM
Longbed 90
Oct 19, 2015 11:05 AM
Odin
Sep 26, 2015 06:56 PM
runnermedic
13
Sep 21, 2015 05:20 PM
