Anyone running the ACT HD PP with street disk?
Old Jan 18, 2008 | 06:11 PM
Jeff B. in Michigan's Avatar
Hi,
I just installed an ACT heavy duty pressure plate and street disk. It replaced an ACT 6 puck race disk...
Anyhow... I had a very difficult time adjusting the clutch pedal and I wonder if anyone else has experienced the same difficulty.
The specific problem is this:
*In order to provide a tiny little bit of through-out bearing to pressure plate gap I need to mash the clutch pedal all the way to the carpet to get enough release to put the thing in gear.
Other than that the clutch works fine.... no slip and very smooth... just much different than the pedal I had with the race disk or stock for that matter.
FYI.... I did bleed the hydraulic system
djpg2000
Nov 11, 2020 04:56 AM
Sleaker
Aug 26, 2020 06:03 AM
Doug4320
Mar 24, 2018 10:11 PM
Poncho0206
Jul 10, 2015 06:21 PM
Kluch8651
Jul 9, 2015 10:39 AM
