- Question rebuild or motor swap?
- 3.4 misfire mystery (another)
- Same part? Transfer switch vs. backup indicator
- 1999 PreRunner TRD Starting Issue
- 97 4runner won't start after valve cover gasket replacement
- Truflow air filter substitute
- Testing the IAC
- LBJ prices
- 99 4runner limited
- 2001 Tacoma 216K Miles 5vzfe blown gasket/cracked head
- A/C condenser bolt mounts
- help 4wd
- Spring issue
- Oh no, not the Master Brake Cylinder
- ‘01 4Runner trying to kill me.
- 97 4runner limited front diff not engaging
- Help the Chevy guy...suspension question
- Troubling noise that I can't diagnose...
- O/D RPM in a 3.4 litre 4Runner 5VZ-FE
- 4R upper strut mount bushings part #
- Check out my odometer :)
- Occasional missfire when open throttle and low RPM
- Tacoma ecu swap
- Rusted Floor Pan on 1999 Tacoma 4x4 xtracab
- Exhaust Y-Pipe
- 3rd gen fog lights not working
- Rear end axle housing
- 2004 Tacoma leaking issue
- 1996 wireing 4 runner harness 1999 Tacoma engine 3.4
- is my 99 4-runner dead? video included
- Auto transmission advice
- Towing in the Mountains with a 3rd gen 4Runner
- Fuel Injector replacement... just need some confirmation
- Brake booster for 4runner 2002
- Fuel injectors 97 toyota 4runner
- 99 4R Ltd: repairing T-case actuator wiring (aka fixing 4wd blinking light)
- Finally, 2000 Taco seats replaced!
- Fuel Pump problem???
- Removed my transfer case actuator - should this shaft move?
- 01 Tacoma 2.7 fuel issues
- 3rd Gen 4Runner Heater/AC Blower Motor Upgrade?
- No crank no shift
- Think I need ecm, 98 taco 5sp 3.4
- 300K miles on stock water pump and timing belt 99 runner
- Replacing supercharger 99 taco 3.4 with stock intake need help please
- odd brake issue
- 3.4L Catalytic converter and downpipe options
- 2001 4runner rear hatch
- How Many Miles and what issues have you encountered
- Fresh 5spd swap - No Start - ISO 9142
- 99 4runner v6 4wd power loss at 60mph
- Texas_Ace hit a bump, went airborne, broke stuff, anyone tried cheap ebay suspension?
- Novice- 99 4runner to 2018 trd offrd t4r shocks
- Timing belt question
- Help - AC idler pulley question
- Fuel Injectors
- How many of you have an Overlanding build, pics?
- Torx screws on factory rack.
- 99 4Runner shifter knob button
- 97 Tacoma with SC and 7th injector lean out
- 96 4Runner not engaging 4WD - lots of troubleshooting done - calling TheDurk!
- 5VZ JDM engine sawp-oil cooler location
- Auto transmission swap from a 98 4runner to a 2002
- What's the purpose of this bracket? - 98 Tacoma
- Supercharger bypass valve
- Custom Power Steering Line
- Solution for Broken Bolt Head in Hitch
- Where does the MAF sensor go?
- Trim clips for wheel well edge- AL on '97 4x4 PU
- 2000 4runner keyless entry
- 3.4 L 5VZ-FE V6 seized after oil change
- 1997 4Runner SR5 Power Sunroof and Tailgate Window Stopped Functioning
- 97 4runner
- Rear upper control arm replacement
- Hood latch replacement on 98' Tacoma
- alarm location
- 99 4Runner fuel gauge
- Winch Bumper
- 5VZ Oil filter close to motor mount?
- 2000 4Runner automatic rough idle / staling problem
- New inner tie rod ends - one not like the other.
- Camber/caster cam replace
- Oil Filter Relocation Kit...
- 2000 4Runner SR5 - Shock/strut replacement?
- Alcohol in gas going up this summer
- Crankshaft or camshaft position sensor replacement
- 99’ 4runner transmission cooling
- 2001 3rzfe won't restart after running for 1-2 minutes
- 99 Tacoma 3.4l misfires
- General Spring Leaf Springs
- Help! - 4LO acting like jackhammer
- 99 Tacoma cylinder misfire 3 and 6
- Locker Advice
- looking for new bed side
- 2000 4runner No power to the fuel pump after body swap
- Help y'all!
- 1998 4 runner 4x4 only disengages when vehicle is turned off!
- Fuel line at tank with red disconnects ???
- Fuel Gauge Issues
- Transmission leak
- Awesome electrical Gremlins inside
- Exedy clutch
- Wiring Harness Connector Locations?
- 2.4L Cyl 3 misifre cause found
- 99 2WD 3.4 decel rumble/grind feeling
- Uneven Tire Wear
- 98 4-Runner 2WD Shocks/Struts
- 99 4runner leaking rack and need advice
- Surging Issue
- Strange 4wd issue that is pissing me off
- Loss of Power and MPG
- 1999 4Runner 4WD has humming noise on highway
- Humming noise in 1999 4Runner on Highway
- replace seat belt
- No Heat !!! 96 4runner - need help bad
- Botched valve job
- Burned Up Electrical System
- leaking axle seals - swap instead of fix?
- 02 Taco LED headlight assembly?
- 3.4 dipstick help
- 5vz aftermarket temp gauge help.
- ID'ing a 3.4
- 2000 Tacoma battery light issue
- Help w/ ADD tube removal - contaminated bearing
- Stock Head Unit with Bluetooth
- 2001 4-runner 4WD Light blinking
- 98 4runner bad injector
- Grumbling noise from 4 wheel drive high 2000 Toyota 4 runner
- Front speed sensor ABS replacement 2000 4runner
- 1996 Tacoma 2.7 Low Compression
- 3rd gen chalky black plastic fender trim..is there a fix?
- Tacoma frame question/s
- 3rd Gen 4Runner Ignition lock cylinder
- Rough Idle, rough acceleration at low RPM
- Anybody swap rear 4Runner seats into their double cab tacos?
- Cylinder Misfire. Changed plugs and wires. Injector?
- 1996 Toyota Tacoma Part Swap
- 4WD will not engage -- another one
- Not Communicating
- Supercharged 5vz Fuel Trims
- Won’t start!
- Truck stumbling a bit when engine is lugged
- Sub $500 front or rear off-road bumpers
- 1997 SR 5 Aftermarket Key Fob Not Working
- Dead Hatch Struts
- P0125 Code 2.7
- 2.7 spark plugs
- Fuel injector(s) leaking? Why?!
- 3rd gen 4Runner tundra brake upgrade
- WIll it match up 340f and 1997 T-100 t case
- 2001 transfer case shift actuator no 4wd flashing indicator
- 2002 4Runner SR5 4WD Door Lock Switches Not Working...
- Is this a Crack or an Imperfection?
- TACOMA electric fan
- speedo recal
- Awful grinding noise when I turn the key
- tacoma 2.7
- Radio, clock, and dome lights our, but not fuse
- Need help finding power steering leak
- Mouse Entry Points
- Need plug sensor information 97 4runner
- Anything to worry about ? (Rust and steering)
- Too much pressure in cooling system
- Dead Battery.... Fuse is the issue
- Rear sway pics
- 5vz-fe DIY Timing belt tensioner tool
- Long cranking when warm?
- 3rd gen 4runner suspension guidance.
- Post a picture of your engine please
- NO SPARK! Hypotheis: BAD IGNITOR!
- Part number for hard fuel line from filter for 01 Taco
- 2005 tacoma front caliper
- Aftermarket wheels with 199 Tundra brake upgrade
- Leaking sunroof fixed (with pictures)
- wheel bearing/axle/seal need replacing?
- Getting code P0300, 0301, 0305, 0306
- Gear slipping out of first sometimes, already changes bushing
- Identify OEM Injectors (5vz)
- 2000 Tacoma brake question
- Where does the alternator tensioner bracket attach to?
- 99 runner poor acceleration and gas mileage. Need help
- Brake pad recommendations - Tundra calipers 231mm
- Noise on acceleration
- What are the typical door handle problems?
- Locking diffs
- Speed Bleeder sizing
- 97 4Runner with intermittent misfire
- looking for inclinometer for Toyota hilux surf
- 02 4Runner SR5 Front Seat Dimensions
- 97 4runner no heat
- Tacoma wheels
- Electrical problems?
- Need help wiring AUX lights to high beam please.
- off Road Style Bumper
- 2001 3.4 cylinder 6 misfire. PLEASE HELP
- 99 4runner LTD: 4wd won't switch/indicator blinking
- Help code p0451
- Diagnostic help
- 2000 toyota 4runner
- Clunky and rattle
- 2000 4Runner front axle - Help please
- Rear window repairs on 96 4runner
- 2001 4runner ltd
- Rear suspension (not sag)
- Custom rack mount - any interest?
- Stuck in Four Wheel drive
- 1980 Celica GT 20r GM HEI conversion
- hard clutch pedal
- Well.....not what I expected
- 265/70/R16 vs 265/75/R16 on 2000 4Runner
- strange misfire wiyh no check engine code
- 3RZ-FE Shop didn’t torque harmonic balancer, now what?
- 3rz iac valve coolant hose help
- Powered door locks
- Bumper Question
- P0115 - ECT Sensor
- Chatter at high speeds
- Fuel filter/ line leaking!
- 99 Taco Headlights Don’t Work Except Manually
- 2001 4Runner Acceleration & Wiper Motor Problems
- Part number for 3.4l crossover coolant hose
- To the Young Man who stopped me at the Shell in Big Sandy
- 1999 4Runner headlights, alarm and ignition issues
- supercharger parts ..
- MT vs. AT throttle body
- Busted 3.4/ new(to me) 3.4 swap
- Marlin 1200lb clutch daily driver?
- 99 Taco Resto
- Another Cat question
- Steering Shakes
- 3rd gen rear end question
- Best lift gen3 front oem shocks
- misfire cyl. 1,2,,3
- Good price?
- Steering knuckle
- Tacoma rear axle bearing replacement without a press
- 1999 CND dealer Brochure
- Door Lock actuator MOTOR
- Exhaust size?
- 80 series cruiserhead - Rebuild cost for a Taco.
- 1996 Toyota 4runner 4wd takes a few seconds to engage, then wont disengage
- 30-40le. Leak problem
- 2000 4Runner - Sunroof won't open / clear drain tubes
- Plastic in oil pan?
- 1996 4Runner radiator thickness question
- 2000 4runner sluggish when accelerating?
- Tailgate window switch location on 97' SR5 4runner
