1997 4Runner SR5 Power Sunroof and Tailgate Window Stopped Functioning
One day I had both my sunroof and the tailgate window open. Upon parking I rolled both to a close. As they were closing I noticed they both seemed slow to roll to a close. Once they were closed I tried to open each of them separately and they each would not open.
As it stands today, the tailgate window will not respond when the switch is activated. The sunroof clicks when either the tilt, or the open switch are pressed.
i've read through the forums and have found posts related to either the sunroof or the tailgate, but nothing involving a simultaneous interruption. Not certain there's a connection. Not sure where to start on this one. Any assistance would be greatly appreciated, thank you.
Well, to start...
Some possibilities:
-failing/failed switches, relays, bad wiring, or circuitry
-failed/failing tailgate window motor
-dirty dirty window tracks
-damaged or misaligned window tracks
Good luck
Some possibilities:
Good luck
bfdrunner
04-29-2011 05:27 AM
Toyota4Runner
07-22-2010 08:19 PM
