2001 4Runner Acceleration & Wiper Motor Problems
Old Sep 27, 2018 | 09:09 AM
Nickdigg's Avatar
2001 4Runner.
When AWD is engaged via the button on the transfer case shifter, if you're at a stop then begin to accelerate, acceleration is extremely slow, like the traction control is kicking in. No lights when this happens. If you let off, then get back on the gas it will accelerate. Typically its when turning from a stop. Wheel speed sensor issue? Any suggestions?
Also, the rear wiper motor is not functioning. Does anyone have a wiring diagram for it or suggestions on what to check? I checked for voltage at the plug with the switch on, didn't get 12v anywhere. I'm thinking this could be a bad switch on the column.
Thanks for the help,
Nick
Old Sep 28, 2018 | 03:55 AM
aowRS's Avatar
Nick,
Make sure your rear window is all the way up and that the child lock button is not engaged. That said, I've replaced my wiper stalk twice in 17+ years of owning the truck due to worn-out contacts.
Andreas
Old Sep 28, 2018 | 04:47 AM
habanero's Avatar
If the above checks out-
For the wiper motor do a quick and easy check of the wiring between the hatch and the body. Move the rubber boot out of the way and look for broken wires, they are very common after that many years of open/closing.
Old Sep 30, 2018 | 04:32 PM
Nickdigg's Avatar
I checked that the rear window is up and child lock is not on. Wiper still wont work. If it was contacts, I'd think that one of the two positions on the switch would work. Also, the sprayer works just fine. Anyone have a wiring diagram so I can check that the motor does in fact still work by applying 12 volts to the correct pins?
Updates to the acceleration trac issue. The trac light does flash when I'm having issues. I removed the front wheel speed sensors, cleaned them up, also checked the resistance and got about 1650 ohms for both of them. From some other posts I saw this sounds like a normal reading. I also did the zero point calibration. Neither of these solved my problem. Any suggestions on what else to check out? The traction control should not be kicking in when turning from a stop on dry pavement.
Old Sep 30, 2018 | 04:34 PM
Nickdigg's Avatar
I will check out the wiring. I noticed that the rear dome light doesn't come on when the tailgate is open. Maybe all of this is related. I didn't look for the pressure switch though on the rear tailgate, maybe it's on the body and isn't affected by the wiring between the body and the tailgate.
Old Sep 30, 2018 | 06:28 PM
habanero's Avatar
Sprayer = nothing to do with rear wiring, both washer pumps are up front at the right corner in front of the wheel. Highly recommend starting with checking the wiring between the hatch and body. Much easier to get to than the connector which is under the panel where the cargo light is. I do not have the schematic on hand.
The cargo light is activated via switch within the hatch latch. I have pics of it in my build thread (see sig, post 2 has link) if you want to see what it looks like. It could also be affected by a broken wire under the boot you'll be checking. Or a simple burned out bulb.
Redeth005
Aug 24, 2022 03:01 PM
MNBOY
Jan 4, 2013 08:00 PM
gwat
Nov 5, 2008 06:17 PM
DeathCougar
Mar 24, 2007 11:33 AM
