P0125 Code 2.7
Old Jan 9, 2019 | 07:13 PM
RedYota93's Avatar
P0125 Code 2.7
Just got a 2.7 5 lug manual, and it has a p0125 code. I've never seen or heard of this before today, but from what little I could find, it has to do with the 02 sensors? The front o2 sensor appears to be newish. Also has a multiple cylinder misfire and cylinder 2 misfire, not sure if that would have anything to do with it? Just trying to figure out where to start.
Old Jan 10, 2019 | 08:08 AM
75w90mantraN's Avatar
https://www.yourmechanic.com/article/-p0125-obd-ii-trouble-code-insufficient-coolant-temperature-for-closed-loop-fuel-control-by-paul-lancette
^^good guidance there on what to check.
o2 sensor not really, but it can be affected by this malfunction
With your other post, you're on the right track, plugs and a thorough tuneup are the best places to start.
An old engine and a new buyer, basically start from scratch, unless you have dibs on PO details.
Old Jan 10, 2019 | 09:10 AM
RedYota93's Avatar
Well, I found a bad plug wire, and she just purs now. Had my obd2 reader hooked up, and the coolant temp was right, along with my gauge. If that matters. But I cleared all my codes and none have come back yet.
Relek37
Sep 25, 2012 02:48 PM
98blacksr5
Feb 21, 2011 04:31 PM
stibz
Aug 7, 2010 12:44 PM
cchinny
9
Feb 9, 2010 06:18 PM
mswenso1
Mar 30, 2009 07:58 AM
