PDA
View Full Version : 95.5-2004 Tacomas & 96-2002 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 [19] 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222
  1. Whitson Metalworks Tube bumper build
  2. I got water in the cylinder.....
  3. New recall: 2001-2004 Tacoma spare tire mount
  4. CV Axle Help!
  5. 1996 tacoma 3.4 superchared questions
  6. Front end rattling noise after lift install
  7. bad coolant leak after replacing Water Pump/T-belt
  8. What type of rear locker is best?
  9. Rear bearing woes...
  10. York OBA on a 3rz with A/C
  11. 2003 fan clutch
  12. VSC, CEL warning light reset
  13. Hayden 679 tranny cooler question
  14. 3.4 timing belt visual condition
  15. 95.5 coma, no start, no codes, cel wont flash
  16. 3rd gen rear diff replacement on 4Runner
  17. New to me Taco
  18. The dreaded P0304 Code
  19. Weathertech Floor Liners in Grey?
  20. Rear drum cylinder bore 1" or 15/16"?
  21. WESTIN Nerf bars - black - new $80
  22. Valve Noise
  23. Pictures 1996 Tacoma auto 4X4 2.7 L
  24. Front End Noise, My Plan - Thoughts?
  25. Timming Belt
  26. Tracking down source of PO171 CEL and cold start throttle issue
  27. Thinking about buying another Toyota. One or two questions...
  28. New 3RD gen for the fam
  29. 1998 4Runner, How Do I Add Fogs?
  30. 96 4runner 3.4 Overheating Issue
  31. 97 4runner overheating
  32. rear axle seal leak story
  33. Continental CrossContact LX20 vs. Michelin LTX MS/2
  34. Trying to do lift. Front 3 studs keep spinning advice?
  35. How to replace transponder key lockset to non-transponder key?
  36. front wheel bearing replacement
  37. 97 4Runner 5-Speed 4WD problem
  38. Backing Plate
  39. Need a bit of wiring help.
  40. i want to add a condenser fan for my 98 4runner,any sugestions?
  41. Looking to Purchase 3Gen 4Runner
  42. upper control arm ball joint reinstall
  43. 2001 4R Combination Meter (Speedo cluster) Removal
  44. broken CV axle shaft in front diff drivers side, weld bolt to pull out shaft?
  45. 4runner clutch return spring, stiff clutch
  46. 1996 Tacoma 2.7L auto question
  47. Ultragauge anyone used this?
  48. Anyone here used Tacoma Lower Ball Joints on a 3rd gen 4Runner?
  49. Tow Package verses trailer hitch package
  50. centerforce clutch... what flywheel?
  51. Gage Cluster Needed For 97 Tacoma
  52. 99 tall coils
  53. 1997 4rnr Brake Problem
  54. 3.4 TRD SC dyno
  55. Transmission Parks, but does not Reverse or Drive
  56. Has anyone tried Powr-Flo Mass Air Sensor?
  57. occassionally misfiring 3.4
  58. Interchangable Seats 97 4runner
  59. 97 XtraCab Tacoma over sensitive brakes? HELP!
  60. Air conditioning stuck on
  61. AC compressor issues
  62. 2004 4.7 V8 vacuum leak.
  63. Will 1989 4runner rear diff fit my 98 4runner?
  64. Bambi messed the front end up... need bumper, suggestions?
  65. Another HID thread. No ebay here lol.
  66. Testing the vehicle speed sensor
  67. 97 4runner odometer and trip bad
  68. Valve cover is dirty
  69. Leaking CV axle, Diff side
  70. Anyone painted 3rd gen 4Runner fender flares black?
  71. Emergency... Cranks but won't start!
  72. Confused on which O2 Sensor to buy
  73. Advice Needed for Multiple Scenarios
  74. Alternator Fuse Bolt
  75. Need possible info on new 99 4runner
  76. CB antenna mount
  77. Trunk lid/hatch swap
  78. have to flat tow
  79. Transmission won't hold in any gear
  80. Transmission Swap '98 4runner
  81. 98 4runner starts then dies after 1-2 seconds
  82. tutorials on valve cover gasket?
  83. No start-up on cold mornings??
  84. Replace Transmission and Water pump?
  85. fuel pump trouble shooting. need help!!!
  86. Bed body work options
  87. 1998 Tacoma Clutch Replacement
  88. Hood w/scoop
  89. Tranny an Transfer Split
  90. Mystery Alarm drawing over 2 amps when off...
  91. Code P0440
  92. Odd Smell and Slight Vibration
  93. Battery light conundrum
  94. leaky water pump....
  95. '98 4runner - trouble starting...sometimes
  96. Anyone buy this OEM timing belt/water pump kit on eBay???
  97. Charleaton area 4runner
  98. 75 MPH Speed Warning Buzzer???
  99. Rear Differential or drifeshaft noise???
  100. obd2 port not working with scanner + fuel pump keeps priming= bad ECU?
  101. 98 4runner 2.7L 3RZFE
  102. Installed a new fog light bulb and now keep blowing fuses
  103. 3rd gen 3.5" toytec lift anyone?
  104. Pulling right, any suggestions?
  105. Vibration Problem After Lift
  106. Factory Skid compatibility?
  107. New 4Runner - What is Under My Oil Cap?!
  108. Buying 2002 Taco. Need input
  109. Why not to hit your bell crank with an air hammer
  110. Diagnostic 0.00 for o2 sensors, rough idle and stalling with a (-) 20.31 trim
  111. '96 Taco MASSIVE power steering fluid leak
  112. Radio Harness - Radio side are different . . what now?
  113. 97 LC Wheels + 285/65: Minimum Required Lift?
  114. 2000 4Runner Limited Climate Control R&R
  115. 5vz-fe fan pulley bracket removal only
  116. Catalytic Convert 96' 4Runner
  117. Prodigy H/T tire opinions
  118. 4runner misfire 4 & 5
  119. '97 SR5 Running Board Removal - Which Front Mudflaps?
  120. Lift questions
  121. New 4Runner - Leaking Radiator - Fear of the Strawberry Milkshake - Help!
  122. Leaf springs uneven
  123. Strugglin when starting up
  124. Best year?
  125. 199mm and 231mm rotor difference?
  126. door switch panel illumination 97 limited
  127. king shocks
  128. Diff oil question
  129. Possible oil pressure problem?
  130. ECU location for Tacoma double cab???
  131. Typical 4runner limited electric Climate Control problem?
  132. Bumper built for good approach angle
  133. 96' 4 Runner Fuel Guage Wierdness
  134. Running shackle lift with OME lift?
  135. Manually Disengage E-Locker?
  136. 3rd Gen Headlight Switch Lever "Cap" Needed
  137. New to me 97 SR5 - suspension question
  138. Nedd help with O2 ID
  139. plasti dipped rims
  140. Quick TRD Coil Question
  141. Loose body mount - Is it normal ??? (pics and Videos inside)
  142. bottom window trim removal
  143. Horrible Gas Smell - New VC Gasket, PCV, Plugs, and Plug Wires
  144. '97 tacoma overheating
  145. 5ve-fe timing question
  146. 95 Prelude Seats into 3rd Gen 4Runner
  147. Tundra Upgrade Price...Pretty darned Affordable
  148. Runner Lift Questions
  149. 1998 4runner rough idel and surging
  150. Tranny help
  151. let off clutch squeal and down shift squeal
  152. What inch lift will clear 35s on 3rd gen 4Runner?
  153. Need wheel advice
  154. tacoma enhancement ?
  155. FJ Cruiser Axle swap? into 3rd Gen 4Runner
  156. Take foot off brake from complete stop, feel a clunk, please help
  157. Under Carriage Zerk Locations
  158. Valves tapping....
  159. 2000 4 run 3.4l , Fuel injectors not spraying
  160. "Humming" sound investigated. Questions inside.
  161. Hesitation at low speeds
  162. Hot S/C after install
  163. Misfire 2 & 5
  164. RCA Input without Head Unit/Radio
  165. 2000 4runner SR5 rear elector, rear spoiler, rear wing, rear sunshader????
  166. wich obdii protocol fro my 98 4runner?
  167. 3.4 timing belt inspection
  168. Lifted and 32s for $500 (pic!)
  169. Tundra 231mm Brake Upgrade
  170. Stiff Brakes
  171. My gear install
  172. Timing belt won't go on!
  173. Fading brake pads
  174. 99 TRD Taco w/Head or Head Gasket Issues: Fix and sell, or sell "As-Is"?
  175. P0171 (bank1 lean1) trouble shooting on my 99' Tacoma
  176. front corner light not working
  177. Blinker sound and clock dimming over and over
  178. Which wideband and where?
  179. Automatic Transmission Experts ?
  180. Replacing engine - Manual Trans
  181. Where did you guys install your URD (split second) ecu?
  182. 3rd gen 4runner downhill surprise!!!!!! no brakes!!!!!
  183. 2000 Tacoma Frame Rot (New Issue)
  184. New to me 99 Ltd 4wd
  185. Installed new fan clutch, now it won't disengage
  186. Work Truck Suspension Suggestions.. 95.5
  187. Bilstein HD with OME 883's???
  188. 4Runner Basics - Transmission (What makes my 4Runner Shift)
  189. Black Friday Deals
  190. universal synthetic transmission fluid. Any Good?
  191. 4th gen e-locker in 2000 4runner??
  192. 1995 Tacoma Speedometer Issues
  193. 1996 4runner(2wd& 4wd) stuck in neutral
  194. Crankshaft pulley issue during removal
  195. Upgrading Headlight Harness
  196. quick question about gas level gauge
  197. Gas gauge problem: Please help
  198. P0330-knock sensor (bank 2)
  199. help with oil leak diagnosis. Pics
  200. 01'-02' taillights in a 98'?
  201. quick question gears and locker??
  202. 2001 4Runner SR5 3.4L P1126 - Please Help!
  203. 96 4Runner Instrument Cluster Issue
  204. Blown CV Boots
  205. Magnaflow Muffler for 02 4Runner ?
  206. picture of 1999 tacoma with 89-94 bed
  207. elocker engages only
  208. CV Axle angle?
  209. 5VZ-FE service manual
  210. Possible Ignition Relay Issue - looking for troubleshooting ideas.
  211. OME 883 front/OME 891 Rear.. what else?
  212. No heat
  213. Flowmaster 50
  214. Any Experiences on diesel swaps?
  215. fuel pressure regulator gone bad?
  216. Downey w/Doetsch Tech
  217. 99 4runner 4x4 light not working
  218. General Mods?
  219. Whirring noise after fan clutch replacement...
  220. Quick question bout LED tailight bulbs
  221. Broke my spindle w/PICS
  222. Which Monroe Rear Shocks For My 2000 ?
  223. negative camber issure on right side, 00 tacoma 4x4
  224. Electric rear locker question
  225. anyone have a york compressor on there 3rzfe
  226. 98 tacoma died while on highway
  227. Front Bumper Cover Chrome End Replacement
  228. Brake issues
  229. 96 Tacoma 3.4L.. Stalled and won't Start
  230. Engine swap
  231. 1998 4runner limted fuel pump not turning off
  232. Rear brake is seized
  233. pre 1996 5VZE headgaskets
  234. urd maf calibrator
  235. '01Truck Lunges when A/C on at stop
  236. 96 SR5 V6 4wd Catalytic Converter Direction
  237. LC coils, which side?
  238. k&n intake silencer mod?
  239. wants to go in 4 wheel drive by its self
  240. 02-04 body styles identical?
  241. Valve Cover Gasket Job
  242. Broken timing idler pulley bracket
  243. Antifreeze smell
  244. 3 inch OME lift kit questions
  245. Rear Differential problem?
  246. prerunner lift kit
  247. Engine whine when lights are turned on
  248. Connecting negative jumper cable
  249. Emergency Brake is stuck.
  250. My High Idle... CURED!!!
