Valve Cover Gasket Job
Old Sep 6, 2012 | 07:41 AM
BDTB's Avatar
I think I'm going to tackle my valve cover gaskets this weekend. I'll probably adjust the valves while I'm at it. Can someone give me a rundown of parts I'll need. Have you guys had better luck with aftermarket gaskets over OEM? Any links to helpful writeups would be appreciated.
Old Sep 6, 2012 | 07:56 AM
thedrewski86's Avatar
You should just need the cover gasket itself. Probably easiest got from the dealer. I've done valves on my 22RE so often it only takes me about 15 min, I just reuse the gasket so long as it's sealing well.
Old Sep 6, 2012 | 08:34 AM
Stu Pidasso's Avatar
I got an extra Victor Reinz Valve Cover gasket set laying around here.
Old Sep 6, 2012 | 09:00 AM
SacRunner's Avatar
I went with Toyota parts when I did mine (for my 3.4 swap). You'll need:
22271-62040 - Throttle Body Gasket, $7
17176-62040 - Plenum Gasket, $9 (you'll need 2).
11213-62020 - Valve Cover Gasket, $20 (you'll need 2)
90210-05007 - Crush Washers, $0.75 (you'll need 16)
11193-70010 - Spark Tube Gasket, $2.50 (you'll need 6)
You'll also need some black FIPG (I went with the stuff from Toyota) and follow the FSM regarding how and where to use it.
http://www.ncttora.com/fsm/1996/SIL/...ylhea/inst.pdf (pages 6 and 7)
Old Sep 7, 2012 | 09:55 AM
BDTB's Avatar
I forgot to mention, this is on an 02 4runner 3.4
Old Sep 7, 2012 | 04:09 PM
rworegon's Avatar
These valves need shims to adjust. Do you have access to a set of shims of various thicknesses? If not, plan on some downtime while you order shims from Toyota.
http://www.ncttora.com/fsm/1996/SIL/...alcle/insp.pdf
Replace the PCV grommet also.
Spark plug gaskets, page EM-48, step 2:
http://www.ncttora.com/fsm/1996/SIL/...ylhea/repl.pdf
smthwsn357
May 1, 2024 07:28 AM
the1998sr5
15
Jul 14, 2020 08:35 PM
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
Sep 4, 2015 09:27 AM
87blyota
Jul 10, 2015 04:31 AM
