Strugglin when starting up
Old Oct 11, 2012 | 06:52 PM
eosandov's Avatar
Hey guys I have a 2000 runner with 93K miles, a couple of days ago the truck started to struggle when starting up like if the battery was dying. I cleaned the posts cause they had corrosion, but that did not help much. I don't think is the battery because the truck is still running, I have not check the charge thou. No issues after the truck fires up. Any body has had this issue? any suggestions? Thx
Old Oct 11, 2012 | 09:21 PM
tantacoma's Avatar
Could be one of several things:
Dying battery
failed alternator (dash charge indicator should be staying on)
bad battery cable to the starter
Old Oct 11, 2012 | 11:08 PM
RAD4Runner's Avatar
... like if the battery was dying. ...I don't think is the battery because the truck is still running, I have not check the charge thou.
Dying battery, failed alternator (dash charge indicator should be staying on)
Concur.
Battery cold be barely alive, just enough to barely start truck. Once the truck starts up, you don't even need a battery, if alternator is good. Definitely have to have battery checked. It's such simple procedure. If your battery's around 3 years old, it could easily bad.
Old Oct 11, 2012 | 11:47 PM
wyoming9's Avatar
Red face
It could also be bad ground cables the cables get brittle after years of use.
First thing you need to check if the battery or alternator is on the way out.:jessica:
Old Oct 12, 2012 | 07:02 AM
eosandov's Avatar
Ok so I took my battery to be check and it is low on charge, so this seems to be the problem..
Old Oct 12, 2012 | 11:07 AM
RAD4Runner's Avatar
Cool to know, it's not that bad. You checked the electrolyte level as well, right? Battery may still be OK, but if electrolyte is low, it may not take a charge.
If it's around 3 years old, probably needs replacement anyway.
Old Oct 14, 2012 | 04:23 AM
eosandov's Avatar
Battery is/was maintenace free. I got a good deal @ costco, interstate battery 575 cca for $65...
Doug4320
Mar 24, 2018 10:11 PM
ZONAYODA
Jul 13, 2015 07:17 PM
Poncho0206
Jul 10, 2015 06:21 PM
raiderhawks00
Jul 8, 2015 06:23 PM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
