RCA Input without Head Unit/Radio
Old Sep 25, 2012 | 09:54 PM
fixnode's Avatar
Hello Everyone,
I recently installed a car computer into my 1997 Toyota 4runner. I basically have a mini computer (Raspberry Pi) that is connected to a 7 inch touch screen via HDMI. Before connecting the Mini computer (HDMI) to the screen, I used a HDMI splitter with RCA audio out converter (because screen does not have audio out) so this is my setup (sorry for bad illustration):
Mini Computer (HDMI with audio) --> HDMI Splitter (connection 1) --> HDMI Touch Screen
HDMI Splitter/RCA Audio Out (connection 2) --> RCA converted from stock amp connector
Basically I need a connector that converts the connection coming out of the car amp (that normally connects to head unit) to go directly to RCA (Analog Audio or Red and White Cable, female RCA)
Hope someone here can help!
Thanks,
Phillip K
Old Sep 26, 2012 | 03:57 AM
Discombobulated's Avatar
Factory amp or aftermarket??
Old Sep 26, 2012 | 05:19 AM
fixnode's Avatar
its for a factory amp.
if it was an aftermarket amp then I wouldn't have this problem since they already come with a RCA out
Old Sep 26, 2012 | 09:56 AM
mynameistommy510's Avatar
I can't do too much research for you but here's a start: http://www.sonicelectronix.com/cat_i...tegration.html
Old Sep 26, 2012 | 11:15 AM
TheDurk's Avatar
I'm not sure if this is what you want, and I'm sure you won't like the price, but here goes:
http://www.installer.com/item/displa...hp?it=TOY-AUX2
These guys have stuff that nobody else has, but frequently not cheap. It says '98+, so that could be a problem. Did the amp really change?
Old Sep 26, 2012 | 02:10 PM
Ahh I see, as posted above might be your only option unless you are extremely geeky and can home brew something. I have read many posts of people giving up and going aftermarket and bypassing factory. Sorry I'm not much help let us know what you do and post some pics of this set up!!
Old Sep 26, 2012 | 06:48 PM
fixnode's Avatar
Will this hook up directly to the car amp, completely bypassing the radio?
I have read on mp3car that the stock radio controls power to the amp, if this is the case then I might need to tap into the wire harness and create some kind of switch for powering the amp on and off. I'm not sure if this is true, can someone confirm? I always thought that the amp auto turns on when the car is on.
Old Sep 27, 2012 | 07:35 AM
TheDurk's Avatar
This circuit diagram below should apply. As I read it, the amp supplies ground, continuous power, key-on power, and illumination power to the H/U, not the other way around. I am just guessing, but the RCA speaker inputs should be all you need. Given the Service Hints on the second page, there is no power switching at the H/U. Amp would come on with ACC power. Of course, with this info, assuming your wire colors match up to this 2002, you could build your own. I know you could NOT do this on a BMW, as their H/U has output higher that standard line-in and the amp needs that to work right. But, since lots of people put aftermarket H/U's on the Toyota amps, this should not be a problem for you.
http://www.ncttora.com/fsm/1996/SIL/...mci/052rap.pdf
It would be nice to have access to the wiring manual for '97, but the 2002 is the only one on-line. I'm worried the colors won't match.
Old Oct 9, 2012 | 04:50 PM
fixnode's Avatar
Found the right adapter
Hey Guys,
After doing some LONG research (couple of weeks) I was able to find the right adapter for my car harness without having to "splice" or cut into the original harness.
Link: http://www.metraonline.com/part/70-8112
This part outputs sound from the STOCK amp to RCA. It comes with a blue cable which needs to be connected to the vehicle ignition power in order to turn on the amp (normally the stock HU would do this with its power button). So my problem is now solved!
Hope this helps anyone else trying to connect a Car Computer to their stock audio system.
EDIT: I'll post pictures as soon as my setup is complete
Old Oct 9, 2012 | 05:57 PM
And your going to post some pics of this mobile multimedia awesomeness when your done right
Old Oct 9, 2012 | 07:28 PM
RobD's Avatar
For future reference, this is probably one of the better forums for carPCs:
http://www.mp3car.com/vbulletin/
Old Oct 10, 2012 | 09:34 AM
TheDurk's Avatar
Hey Guys,
It does? Just curious, but doesn't it provide an input from RCA to the stock amp. Otherwise, I really don't understand what you are doing.
old87yota
Oct 25, 2015 02:15 PM
JAmdor3
Aug 11, 2015 10:53 AM
nonstop
Jul 24, 2015 06:29 PM
dinks07
Jul 15, 2015 05:34 PM
ryerye13
Jul 14, 2015 08:27 AM
