Odd Smell and Slight Vibration
Old Oct 19, 2012 | 05:01 PM
jhenry30's Avatar
I have a 1997 4Runner SR5 5 speed and for the past few days I've noticed a burning smell coming from the rear of the vehicle after driving it to and from work. I recently replaced the fluids in the transmission, transfer case, and rear diff and was worried maybe I hadn't used the proper type or amount of fluid but after double checking it all seems correct. I even took the fill plug out of the rear diff but all the fluid is there and it doesn't smell burnt. While driving home today a very slight but noticeable vibration in the steering wheel occasionally reared its ugly head for a couple seconds and it has me worried. I've searched under the vehicle and cannot find a leak anywhere. I know this is not the most descriptive help post but this is all I've got to go on and I'm pretty new to the Toyota family so any help at all would be greatly appreciated.
Old Oct 19, 2012 | 06:05 PM
Rollon's Avatar
Possible brake issue?
Old Oct 19, 2012 | 06:15 PM
jhenry30's Avatar
I was kind of wondering that myself so tomorrow ill be taking the rear wheels off and inspecting it
Old Oct 30, 2012 | 11:39 AM
paxam's Avatar
make sure the brakes are not too tight , check the axle seals make sure no diff fluid is getting in there. may have a carrier bearing issue if you have a ext cab.
Old Oct 31, 2012 | 03:11 AM
BigBallsMcFalls's Avatar
parking brake stuck on and dragging due to seized bell cranks is the #1 suspect
happens ALL the time
Longbed 90
Oct 19, 2015 11:05 AM
JPV
Sep 28, 2015 03:15 PM
Odin
Sep 26, 2015 06:56 PM
4Xtruck
16
Sep 24, 2015 09:38 AM
Ott47
Sep 14, 2015 12:09 PM
