PDA
View Full Version : 95.5-2004 Tacomas & 96-2002 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 [42] 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222
  1. Leak coming from front diff...pics
  2. Deck plate/intake mod completed-seems to work
  3. I downgraded to 235/70/16's LTX AT/2
  4. Got some hail damage...cha ching!
  5. my rear drivers side window is falling out
  6. For anyone with a/c knowledge...
  7. 95 tacoma leaf ?'s
  8. Rear Storage Compartment?
  9. 07-09 Tundra 18" TRD ORP wheels & Tires
  10. Exhaust Tip question
  11. my a/c sucks! help** need suggestions
  12. exhaust pipe is pouring out somke
  13. hellas on factory roof rack
  14. 3rd gen 4Runner Tundra brake mod in new Toyota 4WD Owner July/Aug 09 issue
  15. Wheel options-16"
  16. headers for 2.7 4cyl in 96 4runner
  17. Is it unwise to buy a high mile '00 Taco?
  18. cracked manifold
  19. 99 4Runner Limited Lock Issue - Help
  20. Tacoma buy back question
  21. Who makes a mild cam for 3RZ???
  22. Long term effects of cracked exaust manifold?????
  23. VSV for VPS for sale
  24. 6 Speed Swap?
  25. advice on "weatherstripping" I think PLEASE help me out
  26. My truck dies when i turn my lights on.
  27. Plugs/Plug Wires
  28. Strut mounts -- When to replace ??
  29. Rear shocks too long?
  30. 02 4Runner 4wd Shift-Out problem
  31. check engine light
  32. TRD Supercharger Need a Rebuild?
  33. Lost my front axle
  34. Intermitent temperature gauge malfunction
  35. Fixing dent in top of rear hatch. What should I do?
  36. Recommendations for a low profile roof rack...
  37. How much payload can a 4Runner take?
  38. ome lift 1996 4runner
  39. wanna convert my 2wd to 4wd
  40. Glad to have switched to Toyota!
  41. Having problems getting crank nut off? Heres easy way
  42. Coolant leak on passsenger side
  43. 2000 4Runner Harmonic Vibration
  44. Are 4runner 4cyl's reliable??????????
  45. Can a new shift sensor be bad??
  46. Mounting a transmission cooler between condenser and radiator ??
  47. Coolant leak on 98 Taco 3.4 V6
  48. Looking for 96 4runner sr5 liftgate and bumper
  49. Gauge cluster lights
  50. is this a timing belt issue
  51. Cel p0420
  52. 3rd gen 4Runner Tube Bumpers-need pics
  53. Double Decker Sleeping Bed?
  54. Coolant flush...in need of a good write-up
  55. Neglected cooling system
  56. grille identification
  57. 03 Tacoma Wont Start After Cruise Control Light Flickering
  58. Looking for YA9730 Tension Tool in Ohio
  59. Radiator hose temperature
  60. Crack Kills!!! (Exhaust Manifolds)
  61. Check engine
  62. no 4wd on my auto
  63. wobble only when braking
  64. My engine is make LOUDER initial start-up noise under normal running conditions...
  65. Help! Brake Questions for '98 Tacoma
  66. Clicking under the dash when I turn the heater on
  67. Running Lights Shake
  68. Ctrankshaft Pulley problems (partially solved)
  69. How many miles are on your supercharged 3.4
  70. Should I change my P/S fluid?
  71. 2002 4runner rear diff oil leakage
  72. Is this worth it ?
  73. Electrical problem
  74. What should have been a simple brake job = brake job from hell.
  75. Transfer case 4wd Actuator probs: multimode
  76. o ring
  77. 10A AC Fuse near battery '03 Taco
  78. need a cat for my 98 2.7 4runner
  79. My 4Runner Threw a ROD! *pics*
  80. For those who have removed running boards and have front mud guards
  81. Need help with 97 Runner 5 Speed Trans removal
  82. Is it the starter?
  83. Need help/expertise on differential plug
  84. Rear domelight doesn't turn on anymore when opening rear gate/hatch?
  85. Help with rear hatch releasde handle on 96-02 4Runner
  86. Front and rear Bumper Question
  87. No I know doors are not supposed to unlock when you turn on blinker right?
  88. 2000 4runner elocker help...
  89. Headlight Problem. Please help.
  90. S/B and easy overheating question for you experts
  91. TRD Supercharger Guys
  92. trans swap question
  93. 3rd gen rear susp ideas
  94. 1999 Tacoma Rear End Noise
  95. Finally bought a 4Runner!
  96. Ring and Pinion Set Up
  97. AC Help? 200 4Runner
  98. Good source for steering rack?
  99. Anybody have a 96 & up 3.4L 4runner FSM?? ASAP
  100. What is the Max cylinder bore for 2.7???
  101. '97 4 Runner Alignment - After Lift
  102. My new $1000 Taco Prerunner
  103. By popular demand: The 3rd gen. Door thread
  104. Help me Diagnose
  105. Goodridge brake lines-length ???
  106. Ball Joints and OME Springs and shocks assembly order
  107. A few Pics of my stock 99-4runner :).
  108. ARB bumper and A/C drier
  109. 3rd gen art thread
  110. How many O2 sensors on my 98 Tacoma?
  111. shift solenoid location ????
  112. what mod should I do next??
  113. Auto trans fluid capacity 5VZFE ?
  114. Dad's 4Runner got new shoes !
  115. Steering rack re-build service...
  116. For Sale: 1999 Tacoma (v6 3.4/TRD 4x4)
  117. 1999 Toyota Tacoma
  118. 1998 4runner overheating
  119. overheating
  120. Radio light out..
  121. Wheel adapters installed with pics
  122. 2001 4Runner rear window problem
  123. Hard Downshift back into first....
  124. Radio Deck Unlock Question
  125. ? about locking rear diff compatibility
  126. Clear lenses
  127. Front diff/axle leak?
  128. Wheel spacer installation dilemma: Loctite or no Loctite
  129. atf and psf type???
  130. Anyone running OME 883 springs on their 3rd gen runner??
  131. TRD exhaust
  132. Quick Oil Drain Valve.....
  133. Steering rack leak...photo
  134. 33s with black plastic fender flares and mudguards
  135. Center console lid question
  136. Vibration at 40, Goes away at 55
  137. ATS Upper Control Arm Replacement Bushings
  138. 4Runner CV Shaft
  139. Steering rack questions -inner tie rod
  140. A new noise - oh joy!!!!
  141. Cargo/ Dog barrier 3rd gen 4Runner ?
  142. OME 881s with stock shocks ??
  143. bumpers and sliders
  144. 96-98 Grill fit 99?
  145. *** Key Stuck On ACC - HELP!
  146. Truck runs rough after car wash!?!?!?
  147. Putting on second timing belt,, What all should I replace ?
  148. Possible starter issue?
  149. 3.4 troubles and codes - gurus needed
  150. Help AC Idler pulley bolt snapped!
  151. Dealer recommendation
  152. Upgrade shocks AND springs or just shocks with 215,000 miles?
  153. Best muffler for 3.4 taco?
  154. will a 4.0l engine work in my 3.4l runner?
  155. Engine part vibrating and smoking
  156. 1" Performance Products springs installed
  157. How to remove a/c compressor belt?
  158. Redline MT-90/tranny...first impressions.
  159. brake pedal travel
  160. Oil pressure and oil weight
  161. Interior fuse box
  162. Just swapped in elocker into Taco Now have weird issue
  163. Quick Poll: Your Feelings on a Used Steering Rack
  164. Not Ready for emissions tests
  165. 01 4runner trouble with getting out of 4wd
  166. ARB bumper winch control bracket
  167. recovery points on 1997???
  168. White truck, black canopy...look dumb?
  169. problem with 96 tacoma 2.7
  170. CV Joints...
  171. new (used) seats
  172. 33" Tires on My Taco
  173. Rhode Island Toyota shops
  174. Engine squeal or chirp
  175. ome 890 install --precompressing the springs
  176. a/c squeel
  177. Crickets under the hood??
  178. 3rd gen stock chrome rim
  179. ATTN: Photo Shoot in Savannah next Tuesday 6/16
  180. horrible CV shaft luck
  181. junk/salvage yards in socal???
  182. 2000 Tacoma 2.7L 5 Speed performance
  183. Just curious: Front Bumper
  184. Part2: Fab job is DONE! Now... really did I get jipped..?? :X
  185. 3rd gen. 1996-2002 4RUNNER Owners Poll: Does your cruise control work???
  186. Cargo Kit # PT34735991HK. What is this?
  187. front end and steering wheel shake
  188. 02 Sport with ?transmission problem?
  189. Oil in Bellhousing?
  190. 2000 4runner - maintenance schedule
  191. Oil in coolant
  192. Pic Request: Wheel Spacers
  193. Lotek gauge pod install question
  194. Lifting rear: will it mess with alignment?
  195. Trailor Hitch wiring Help!!
  196. Sway bar question?
  197. Is there OBD II scan/diagnostic software for laptops?
  198. No lift but upgrade
  199. Stock suspension for 2002 Sports Edition.
  200. HELP! taco/4runner fitment question
  201. Tacoma beadlocks/street locks...searched and can't find anywhere!
  202. Igniton lock help/Key
  203. I'm looking for a 5-speed Tacoma. Are there any?
  204. Is It Ever Too Old for a Lift?
  205. Help Dad's 1997 runner needs an engine!
  206. stolen cat replaced/now control arm broken from mechanic?
  207. Are these all the parts I need? Big Brake Swap
  208. '01 corner marker lights, cant remove lights to replace bulbs
  209. P0753 Transmission code
  210. 02 4runner mods
  211. What else should I do to the Taco for a safe/reliable daily driver?
  212. rear axle oil seal
  213. rear axle oil seal
  214. going to 305s from 285s, fitment?
  215. Spot rust above winshield...options?
  216. Has anyone tried the Bosal header pipe?
  217. acura/honda seat swap?
  218. Striping and sand blasting frame. Is it worth it???
  219. Can't find the damn OBDII port
  220. question about spider gears
  221. Hood Strut installed, strongly recommended.
  222. simple question simple answer
  223. Going to the dragstrip tonight what to expect?
  224. Just bought '99 4Runner Have Many ????
  225. WTB: 1999 4Runner OEM Steering Wheel Tan
  226. 3.4L with 1st Gen SC High Idle and No top end power
  227. Best way to reset after O2 install...
  228. looking to get a winch
  229. shaking lights on bullbar
  230. '04 tacoma w/ 51k..repaired title
  231. 1998 4Runner. HELP!
  232. Tacoma front shock/strut bushings
  233. '97 4 Runner Seat Belt
  234. Seat Bolt through floor board
  235. Converting 96-98 Sunroof Button to 99-02
  236. LightForce HIDs worth the extra money ???
  237. OEM radio swap question.... Need fast answer!
  238. toyota frame recall strikes again
  239. Grabber AT2 vs. Dunlop radial rover rt
  240. 3rd Gen transfer actuator - DON'T DO THIS...
  241. 265/70/17 w/ Cadillac escalade Rims
  242. Caliper Pins Seized
  243. Tundra coils and 2 top-out spacer Q?
  244. Side mirrors on 96-98 4Runner, 99-00 4runner, and 01-02 4Runner, what's different???
  245. 2000 4Runner Limited Power Seat Issue?
  246. I guess I could have pulled over ...
  247. oem textured flares??
  248. *** A/C not blowing cold! HELP! ***
  249. Scraping Sound need some advice
  250. Please give advice on engine swap!
