shaking lights on bullbar
Old Jun 4, 2009 | 09:37 PM
98runner210's Avatar
I have a bullbar. There are these tabs with foam underneath to mount lights on. When I am on a bumpy road the lights shake so bad the look like strobe lights and I am sure is very distracting to oncoming drivers. I just switch them off. Any ideas on stablizing them?
Old Jun 4, 2009 | 10:00 PM
scuba's Avatar
Rubber in between the bolt and tab..?
Old Jun 5, 2009 | 10:53 PM
already there
Old Jun 6, 2009 | 12:45 AM
CRafferty's Avatar
increase the amount of rubber? I'm not sure there is anything else to do about it.
Old Jun 6, 2009 | 05:02 AM
jdmaccord6's Avatar
which bull bar do you have? is it an ebay one? westin? I know the cheaper ebay bull bars are just not as stable as the westin bar. No matter what you do to the lights, the bar itself will still shake.
Old Jun 6, 2009 | 05:32 AM
elblako91's Avatar
Shake the bar around with your hands and see if it moves. If it does try to find a way to stabilize it. More bolts and nuts or welding a support to it would help then you can do more of this
Old Jun 6, 2009 | 09:06 AM
i checked the bar is pretty solid i am sure it is probably a combination of the lights themselves and the tabs
Old Jun 6, 2009 | 09:12 AM
elblako91's Avatar
Heres an idea. Weld those suckers on there.
Old Jun 7, 2009 | 12:05 AM
that wouldn't help. It's not a loose mount.
Old Jun 7, 2009 | 05:26 AM
elblako91's Avatar
well if its not a loose mount and the bar is not loose the only other thing i could think of would be that the lens is loose in the housing. Might want to check that out.
-Blake
Old Jun 7, 2009 | 07:04 AM
Belize Off Road Team's Avatar
what kind of lights do you have exactly? i know that companies such as Hella, PIAA and KC come with shock absorbing mounts to prevent vibration.
Old Jun 7, 2009 | 08:18 AM
it's not anything loose. I believe it is a combination of the tabs flexing (like a diving board?) and maybe just low quality lights.
Old Jun 8, 2009 | 05:53 PM
fireteacher's Avatar
ditch the bull bar. Get yourself an ARB or TJM. Otherwise, You will have to deal with it!
Old Jun 10, 2009 | 07:54 PM
again, the bar isn't moving
ashersullivan88yota
Jan 18, 2022 05:37 PM
AkitaDog
Sep 1, 2015 08:05 AM
PopsDad1
Jul 30, 2015 02:21 PM
v_man
Jul 23, 2015 04:01 PM
Odin
Jul 15, 2015 09:28 PM
