Need help/expertise on differential plug
Old Jun 25, 2009 | 11:30 AM
wyorunner's Avatar
So about a month ago i got new gears put in my 02 4runner. The guys that did it put the front differential drain plug in so tight that it is now perfectly round on the inside, where it should be a 10 mm allen wrench hole. I need opinions and ideas and anything that can help me get this out to change the fluid. I dont really want to drive another 2500 miles with the fluid that is in there currently. I thought about taking it back, but thats a two hour drive and im leaving this weekend. PLEASE HELP!! THIS IS MY DISTRESS CALL!!!
Old Jun 25, 2009 | 12:31 PM
hross14's Avatar
Get a bigger allen and hammer it in there or drill it and use a large easy out.
Old Jun 25, 2009 | 12:34 PM
scuba's Avatar
^^ Or, Have a welder ? A friend with a welder ?
A fab shop or even a muffler shop near by..?
Get a Nut and tack it on there in 2 small spots, Now you have a solid point to attach a socket to..
Old Jun 25, 2009 | 02:48 PM
hross14's Avatar
Good One Scuba--didnt think of that--and i have a welder--but have done it before--unforutnately with no success--but it was over FUBARed
Old Jun 25, 2009 | 03:27 PM
jeremy9allen's Avatar
If nothing else, see if you can find these----> http://www.irwin.com/irwin/consumer/...rwinProd100509
I have a set of these at work and use them often for rounded hex and torx fasteners.
Get it warm with a torch around the bolt first. The one on mine was in pretty tight from the factory and needed some heat to get it out.
Good luck
Old Jun 25, 2009 | 03:55 PM
wyorunner's Avatar
Great ideas, ill have to give these a try. Unfortunatly itll have to wait until i get to Wyoming. Oh well lets hope i can get it out. Keep em comin if theres any others.
Thanks Yall
Old Jun 25, 2009 | 04:01 PM
waskillywabbit's Avatar
Big EZ out hammered in there with a BFH and then hit it with an impact. Come right out.
Ladythump
22
Nov 9, 2015 08:53 AM
justdifferentials
Just Differentials
Sep 17, 2015 06:14 PM
justdifferentials
Just Differentials
Aug 15, 2015 05:25 PM
ripp96
Jul 31, 2015 11:14 AM
AaronM
Jul 8, 2015 07:15 PM
