Oil in Bellhousing?
Old Jun 10, 2009 | 04:05 PM
cchinny's Avatar
Oil in Bellhousing?
Changing my clutch and I have lots of oil in my bellhousing. Evenly spread with a big pool back by the trani. Is there a trani seal? The rear main looks okay, but I can't be sure. Any ideas?
Old Jun 10, 2009 | 04:21 PM
iamsuperbleeder's Avatar
'tis an input shaft seal on there
not 100% sure on the process of replacing it, BUT I'll be doing mine soon since my motor's out for rebuild
My mess IS from the rear main though; I'm just going to replace the trans seal as assurance, so I don't have to separate the motor and trans later just to replace a $5 seal, lol
Old Jun 10, 2009 | 04:26 PM
cchinny's Avatar
Mine looks a lot like yours but with a lot more oil. Did you have oil on your clutch or flywheel? I heard it spins too fast to get on there even though it may be the rear main seal. How can you tell if the rear main is bad?
Old Jun 10, 2009 | 04:31 PM
waskillywabbit's Avatar
Rear main seal I bet.
Question is: Is it motor oil or ATF? That would tell you what is leaking.
Old Jun 10, 2009 | 04:32 PM
Ron's 85's Avatar
sounds like your rear main to me. it's only gunna leak when the motor is running.
Old Jun 10, 2009 | 04:53 PM
the clutch wasn't coated like the bellhousing, but there was a thin layer all over everything accept for the friction surfaces
Old Jun 10, 2009 | 05:43 PM
DudeBud's Avatar
ATF in a toy manual trans? it should be 80w-90w.
you can tell the difference between motor oil and gear oil by the smell.
Old Jun 10, 2009 | 05:47 PM
space-junk's Avatar
i know that we are already answering his questions, but just saw, hes in the wrong forum... lol...
Old Jun 10, 2009 | 05:49 PM
DudeBud's Avatar
why is that?
Old Jun 10, 2009 | 05:57 PM
cause he has a 96 Taco
I hadn't noticed untill you said that
oh well, lol, same thing applies, the picture I posted just might be a little different
Old Jun 10, 2009 | 06:06 PM
Yeah, what he said. It has been a long day.
Old Jun 10, 2009 | 06:12 PM
DudeBud's Avatar
oh just because his sig says he has a 96 taco doesn't mean he's working on one right?
take another look at the pic diff on the wrong side. you should know its not a taco but a 86-95 ifs truck or 4runner.
Old Jun 10, 2009 | 06:13 PM
OP didn't post the picture.
Old Jun 10, 2009 | 06:17 PM
DudeBud's Avatar
ok its been a long day for me to
Old Jun 10, 2009 | 06:24 PM
RMA's Avatar
RMA
Hahahahah , Long day for everyone huh !
Old Jun 13, 2009 | 06:23 PM
cchinny's Avatar
Thanks for all the advice. It is actually my 89 4runner I'm doing the clutch on. Did the rear main seal today. I didn't do the gasket that goes behind the seal cover. Is this necessary? Icouldn't get it off despite the oil pain bolts out and the 5 bolts in front. Also, how hard is it to do the front seal on the trani in case in case that is where the oil is comiing from? Last question, how do I know which way the clutch disc goes in...does it matter? Are the scallped edges supposed to face a certain way?
Thanks!
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
RobotMoose
Diesel Swaps
Aug 2, 2015 11:00 PM
Toyvana
Jul 29, 2015 10:47 PM
yourrealdad
Jul 29, 2015 11:08 AM
calderp
Jul 27, 2015 09:58 AM
