Putting on second timing belt,, What all should I replace ?
Old Jun 16, 2009 | 06:46 PM
FogRunner's Avatar
Well she is turning over 230,000 miles soon and I'm getting ready to take a one month 5,000 mile cross country vacation so I figure its time to do the timing belt/water pump shuffle again.
I'm going to replace the timing belt,water pump, T-stat, both tension/idler pulleys and tensioner spring, crank shaft bolt and all drive belts.
What else should I replace while I'm in there?? I've thought about cam shaft and crank seals and maybe even the oil pump??
Thoughts??
Old Jun 16, 2009 | 08:19 PM
DeathCougar's Avatar
Def the crank seals, and cam seals. Oil pump you could replace, make sure you get a brand new OEM pump.
Old Jul 3, 2009 | 07:35 AM
Runner4Yota's Avatar
Question
Is changing the cam/crank seals as easy as prying out the old ones and pressing in the new ones with a socket? Are there any issues with the new seals not mating with the old shafts or anything to watch out for?
Old Jul 3, 2009 | 07:45 AM
hross14's Avatar
Peronally, i would send the injectors out to get cleaned. It may run great but every motor i have cleaned the injectors on needed it. And it is an easy job too
voiddweller
19
May 2, 2016 09:10 PM
vasinvictor
Jan 20, 2016 12:39 PM
marcusSRG
Jun 27, 2015 07:13 AM
crazypaint
Jun 23, 2015 03:27 AM
infinityisfive
Jun 16, 2015 06:51 PM
