will a 4.0l engine work in my 3.4l runner?
Old Jun 16, 2009 | 01:33 PM
jlludwig's Avatar
I need to replace engine in my '01 4runner and have found a reasonably priced '05 4.0L locally. Is the swap possible?
Old Jun 16, 2009 | 08:03 PM
One_96TR4's Avatar
I've only seen one person do this swap and I believe it was in a 91-92 pick-up. It's doable but not a straight drop in deal.
Old Jun 16, 2009 | 08:05 PM
DeathCougar's Avatar
Anything is *possible* but it is NOT a direct swap. The 4.0L engine was COMPLETELY redesigned, and has no close relation to the 3.4L
Old Jun 16, 2009 | 11:03 PM
scuba's Avatar
DO IT DO IT !!!
Old Jun 16, 2009 | 11:08 PM
Mic09dcsm's Avatar
If they'll sell the ecu and tranny do it. I think one big headache MIGHT be the ABS getting to jive between the new ecu and existing hardware, also the speed sensor, the tachometer and speedo might be a SOB but if you can get it all reasonably priced, it would be a good step in power.
Old Jun 17, 2009 | 01:37 AM
TNRabbit's Avatar
There are all kinds of issues with transfer case hookup & engine height, not to mention it's a drive-by-wire throttle, plus a host of other issues. Like One_96TR4 said, it was done & the write-up is on here somewhere, but it cost 'em a ton and took a long time & good mechanic. Last I read he was having issues with some sort of binding with the front diff...
Old Jun 17, 2009 | 09:23 AM
jlludwig's Avatar
Thanks all for the quick responses. After a few hours of research I've decided to continue searching for a cheap 3.4l as I need my vehicle operational soon. I'll post some pics of the existing engine after we pull it and find out what happened without any warning whatsoever, that is if anyone is intersted...
Old Jun 17, 2009 | 09:27 AM
scuba's Avatar
Of course we want pics, We are pic whores..
Sorry to hear about your dilema though
Good luck !!
Old Jun 17, 2009 | 09:34 AM
jlludwig's Avatar
After lurking for some time I had a feeling you'd want pics.....
It may be a couple of weeks, but I'll get them posted. I'd love some what and why answers.
Old Jun 17, 2009 | 12:23 PM
cackalak han's Avatar
I'd rather mess with going diesel than swapping in a 4.0L V6. Too bad Toyota engine swaps aren't like Honda's.
Old Jun 17, 2009 | 06:46 PM
22R-to-5VZFE's Avatar
true that, I have and Acura Integra too and that car can have like 5 different engines easily installed into it...different honda engines that is...same with civics, they can have my motor bolted directly into them and running like a raped ape in like 3 hours...
A diesel would be sweeeet....25mpg is nice...
Old Jun 17, 2009 | 06:52 PM
ozziesironmanoffroad's Avatar
u can put a new honda civic 4 cylinder engine into an old del sol pretty easy, huh? a buddy at work did it, and man is that thing fast. tho he CLAIMS to have spent 20k on the swap alone... id say he spent 800 on the motor (brand new from honda of poway) and the rest on the suspension. ...if he even spent that much.
Old Jun 17, 2009 | 07:59 PM
$20k? Yeah, right. Unless he's got solid gold valve covers, I don't believe it. A K-series would be around $10k, which is one of those most expensive engines that you can put in there.
Old Jun 18, 2009 | 04:52 PM
stir_fry_boy's Avatar
Ditto to that! Is it made of gold?
voiddweller
19
May 2, 2016 09:10 PM
94whiterunner
Sep 22, 2015 07:25 PM
gog1968
Jun 22, 2015 05:55 AM
TheManOutside
Jun 18, 2015 03:32 PM
DuckFan
11
Jun 18, 2002 11:56 PM
