- Post up your 4runner pics...
- 92 truck slack in rear end
- ? for you guys running 285 Mud Terrains....
- Rancho rear spring question?
- Lift Question?
- '88 Dash Light replacement
- My starter wont stop turning over..help!
- ARgghhh! Trying to find aftermarket parts for the 82'
- gear change
- 1st time out wheelin... some questions.
- To paint or not to paint...
- Transmission kinda slipping?
- '96-oil residue around heads--is this bad??
- Well, I got my first yota. (1982)
- Does zip-tie installation of Hayden tranny coolers really case damage?
- Sunroof Leakage
- 2001 Rav4 Steering/Alignment question
- 33x9.50 on stock 3rd gen??
- Replaceing Ignitor Wires
- 86 4Runner low idle, throttle cable too loose?
- 22RE Sounds Like a Diesel
- Broke my wheel lock
- Identify lift please
- Can anyone think of a drawback...
- 99 4Runner....Gas Mileledge poor
- Looking for Tacoma bumper 01-04
- beat the crap out of the 4runner this weekend
- really, really, weird cold start problem
- 93 4Runner question
- possibly getting a trail rig
- Another Toyota Cheap Trick - Under $10.00 - Caution dialup, kinda big pics
- removing flywheel bolts!!!!!! (arghhh)
- '85 EFI 4runner fuel return line? What is Spring W/plastic cap by cs injector
- mod help please
- Pre-runner style light bar bumpers
- ARB Compressor Install
- Pics of the Truck (pre-lift)
- intake question
- Paint stripping
- Where To Get Fibergalss Fenders?
- Quick RPM jump in 97 4Runner
- Need help with Spring matinence
- what are the biggest tires
- 22re Electric Fan?
- FINALLY Removed Running Boards
- Help me
- Fuel Pump Installation
- A340h Transmission Diagnosis. HELP!
- 3rd Gen 4runners, does anyone have one of these...(pics inside)
- 2" BL installed - shifter problems...
- Cool Video May be a repost>>>>>>>
- Tires!
- What Fuel do you use?
- Annoying Rattle
- Is this Transmission toast?
- need ideas for your 2nd din?
- tacoma 4x4 rear axle ????????
- Another S/C is in!
- Rear Axel WTF?
- Halfshafts Playing around!
- Heads
- TRD/Firestone Air Bag Helper Springs...Need some feedback
- Black Rims...yeah or neah?
- V6 running issues identified
- 4x9x18 Magnaflow installed..
- Finally Sahara Installed! (pics)
- Mounting new tire to replace tire damaged at 38k miles... Bad idea?
- Hi, help wanted
- wheres the cheapest place to buy gears and lockers online?
- turn siganl frozen w/ lights on
- wHAT DOES A 94 rUNNER WITH A BAD TRANSFER/TRANSMISSION COST?
- Hi to all across the pond. In need of help
- 3VZE turbo
- Removing a 3" body lift?
- dashboard kits
- Marlin urethane vs. OE rubber shift bushings
- TRDOLMAN's Dyno Day
- Need help: How bad is this?
- Tach Installation Questions??????
- Timing tensioner......
- PF pad warranty update
- any fixes for 3.slow slushbox
- Pics of my "new" '85
- extended studs
- Water Pump
- URD will be in the San Francisco area this weekend
- HELP! speedo problem....ugh..
- Timing chain problems
- Stupid Stealer! (dealer)
- 3.0 4Runner w/ 32x11.50 tires - Owners?
- Paint touch up
- Surco roofrack owner
- Anyone know where to get a 3.0?
- The new FJ Cruiser
- ETrailer, Rockstomper arrived in mail yesterday, time to make a rear bumper!!!!
- Melting Headlights?
- What MAF's have been used successfully with the V6
- 91 pickup ?'s
- did you know...
- Overdrive Jerk
- Power Steering Pump Rebuild or New?
- 4 Banger on a 3rd Gen?
- what mileage is everyone getting?
- Fuel Consumption
- Got some new pictures
- *Dash lights went out...*
- Cornfed vs OME
- Bleeding question
- what is this part?
- Wont Idle at all ????
- Any major changes in performance after putting on 33"s?
- Front headlight shot with BB gun
- 4x2 Rear to SOA
- locating current opening efi relay
- Finally Got A Pic
- Used Wheels!?
- sensatrac shocks
- What gears does my 96 have?
- ??? No oil pressure on gauge???
- MPG Woes
- tinted tails
- 1994 4runner ome rear springs
- V6 Oil pressure question
- Do these springs look sick?
- optima
- Cat Question, please help
- OME/Tundra TRD Lift Pics
- 1st gen v-6 gas mileage w/ auto.
- XREAS damaged ??
- 1996 Failed Smog - Advice needed # incl.
- Hanna Quality Rocksliders in Peterson's 4Wheel&Offroad!
- Gearing in 3rd Gen Runner
- better alternative to bushwacker flares?
- Brembo/PF upgrade and break in
- Another question about upgrading brakes
- Code 14 and flash O/D off?
- Oil leak without washer?
- sunroof on xcab?
- Hella hook-up
- safari doors
- Rear differential replacement
- 2ND GEN 4Runner Check Engine Light
- Sliders with divits?
- need engine (3.4) tool measurement
- My new exhaust
- hood strut/shock
- rear spring sag??
- Shipping question.
- Brake Problem......
- Hilux Surf - 4Runner bull bar, chrome hoop?
- Supercharger in a 1995.5 - What's the story?!?
- pics of 33x12.50x15 on 15x8 3/75 bs ?
- diff lock question
- Brakes on 3rd gen
- 400 000 KM tonight
- 22RTE idling problem
- Good catalytic converter
- Distributor grease?
- help cant get truck to start
- Tire size
- Rear wiper problems
- Learning to love your 2nd gen 4Runner?
- What does Supercharger Ping sound like?
- Ahh WTF!
- 97 brakes problem when it's cold
- tranny problem
- What do I need to do a tune-up?
- Automatic Transmission Tranfer Case question
- Question about Foglight/Driving light Wiring
- Lighting ignoramous question
- Wheel spacers and safari rack
- Supra motor + tranny = ?
- Fog light options for a 3rd generation 4runner
- Transmission acting strange after flush and Amsoil... help?!
- Clogged Cat.=code p0171
- Saw this sticker on a Jeep
- Brake Proportioning Valve
- What do you all think about this?????
- front bumper for 91 4WD pickup
- revtek... out the door?
- Coolant leak, leaks when not running
- Brakes Locking Up
- What could have gotten messed up?
- Amateur Comp truck lift invention questions
- deckplate mod and gas mileage
- Seafoam clogging
- observations about tires/gears on my 3rd gen
- volt regulator
- New hybrid toyota, power of a v8 in a v6
- Crazy Gas Gauge
- quick spacer q...
- 32x11.50 versus 31x10.50
- Did search, still don't know?
- I hate ICE!!!
- Well I sold my '99 Pre Runner and bought a ....
- wierd idle, anyone have this?
- 04' 4runner billet grille
- tacoma leaking water.
- Any San Diego welders?
- HELP! CV/Snapring question
- Rear window keyhole access
- Youch - just put $160 worth of fluid in today!
- How much these sell for?
- Which ARB locker do I have?
- Dash Temp Control Light
- tundra trd dc coils
- Skyjacker Nitrogens?
- Woohoo, New 4.88's and New Clutch came in Today
- Key stuck in ignition
- Transmission Question / Problems
- What do you think about this?
- Toyota Recalling 22,228 2005 Tacoma Pickups
- expected dealership damage? (parts)
- anyone A/C Pulley Issues???
- Flowmaster
- Noisy engine
- HG versus knock sensor repair, need help!!
- need help-check engine ligth
- 4Runner ARB in a supra MKIII?
- Who is running stock...?
- Clutch Pedal Assy.
- 2nd generation 4 runner / crossmember
- Help Prevent Closure of CA Trail to Toyotas and All Offroaders: Feb 17 Deadline
- FINALLY ordered the lift
- noob question of the day
- 15 X 12 Toyota steel wheels and 38.5" tires
- Unsolved Mystery...help AGAIN please!
- Trail damage and a tech question
- U joint????
- gen2 alternator help!!
- Upgraded Timing Chain Guides
- Just got a 4runner
- After market speedo calibration
- ON EBAY TRD AIR Helper Springs
- Seafoam Substitute
- Aussie locker
- Double Stacked IFS lift?
- Ideas for patching a hole in my '85 X-tra cab frame??
- regearing without bigger tires
- Speedometer and 4X4 On Light
- Would you like cladding with that?
- new member - replacing engine Qs
- Procomp Front Al Skid with a Superlift Lift Kit?
- Question about lift/tires
- Fuel Level Guage
- Another lift question(s)
- 3vze valve adjustment?
- 3rd gen End Link ??
- 05' 4Runner - Standard Suspension vs. X-REAS
- 05' 4Runner - Rear Height Control Air Supension!
