15 X 12 Toyota steel wheels and 38.5" tires
Looking at a local newspaper and seen an add for
4 15 X 12 Toyota steel wheels / 6 lug with 38.5" tires
Is that possible ? What would they fit ? My runner would have to have the front fenders removed to clear a 38" tire.
$400.00 for the set and they state 50% tread left on tires.
My truck ran 38 swampers for a while, with the 4"/3" setup. They would rub only a teeny bit at full turn and compression. BUT, they were on 8" rims. With 12s I think you would need a LOT more lift to even run those on the street! Even if you trim the fenderwells, you can't trim the rear of the front fenderwells enough to help much - there is a cab in the way....
Jnkml
07-06-2015 01:20 PM
