??? No oil pressure on gauge???
Old Feb 17, 2005 | 05:59 PM
rj's Avatar
rj
??? No oil pressure on gauge??? (87 4runner)
I picked up an 87 4runner and rebuilt the 22re ( new bearings, pistons, rebuilt head) but I'm not showing any oil pressure on the gauge. How do I check to see if the problem is the pressure switch, the wiring or ??? Thanks, rj
Old Feb 17, 2005 | 07:52 PM
SoCal4Running's Avatar
Well the pressure sender should be around the oil filter area on the engine block, its a black boot looking thing. You could remove it and install a temporary mechanical pressure guage just to make sure everything is ok mechanically.
Old Feb 18, 2005 | 07:29 PM
rj's Avatar
rj
Thanks
Thanks for the impute. I am going to give that a try. I'm also going to disconnect the wire to it and check it for voltage with the key on. I'm told it should read out 12 volts if that end of things are working right. Thanks again, rj
Old Feb 18, 2005 | 11:11 PM
bike4miles's Avatar
Yea, same thing just happened to me. How much is a new switch?
bigjstang
Jun 2, 2025 03:56 PM
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
Jdgarrison
Oct 1, 2015 05:22 PM
calderp
Jul 27, 2015 09:58 AM
88yodabasket
Jul 13, 2015 01:32 PM
