- 2001 4Runner lift question..
- Super Weird Electrical Problem 99 4Runner
- 2002 4WD Manual Tranny and Tfr Case with ADD
- Rpm goes down when i hit the brake
- Lift/Wheel fitment question from a newbie
- 99 4Runner LTD - Swap out front bumper for SR5 bumper?
- 4 wheel won't engage on my 2002
- Oil leak location? Pics included
- Timing belt alignment
- Towing My Taco
- intake and plenum removal
- starter ?
- Digital/Analog Temperature Gauge Install
- 1998 Tacoma 2.7 Fuel Pressure Regulator
- Took the 4runner out in the "blizzard" Lol
- P0304 cylinder 4 misfire code
- Power Steering Flush
- Installing new driveshaft
- Advice Needed Broken Bell Housing 99 4Runner
- 1996 Toyota Tacoma 5spd J TCASE 4wd will not disengage
- Emission help on 1999 Tacoma 3.4 motor
- **Need Help* Half Moon fell into head...
- 3.4 Water Pump Replacement....Too Corroded For Molded Gasket??
- Post rollover Maintenance
- 99 Tacoma have Auto Transmission questions
- 01 Runner; Timing Belt Marks NOT Aligning with Crank Marks
- Spark plug wire numbers
- Airlifts lifetime warranty explained
- Will 5speed driveshaft work on automatic
- Driveshaft question.please help!!!
- 2wd Suspension, its too soft and floaty
- 4wd diff on 2wd?
- Trans wont shift out of first with brights on
- Cali smog help ........high NO
- Replace AC compressor worth paying a shop?
- E-locker actuator cleaning
- Did the brake pads get hard?
- 5vzfe hard start after fueling
- Rear Brake Adjustment, Help needed.
- rainwater on passenger floor PLEASE HELP!!!
- 2000 4Runner 5speed transfer case options
- Is this radiator cap bad?
- 1998 4runner 3.4 4Wheel Drive will not engage
- 95 4WD VSV Question
- 99 runner... Replacing drivers door latch mechanism
- Anyone ever lose an AIRLIFT bag after 6 months?
- Harmonic balancer: is any amount of wobble OK?
- Rear heater removal and bypass
- New Alternator and Battery Light on when Cold
- Any '02 4Runners out there with a M/T swap with multi mode????
- 96-02 rear spoiler end of the year sale! Ends 12/31 midnight
- Throttle Body Bolts
- Intermittent clutch problem
- How to change lights behind climate control not on limited
- lubricating the tailgate hinges
- CV's, Wheel bearings, or something else? Help!
- 3rd gen suspension help!!
- Throttle and Limp Problems
- 1998 Tacoma 2.7 Hard Cold Start
- A/C Clutch won't disengage
- Tacoma wont go into 4wd
- Vsc or not
- Interior Visor Q&A 1998 Tacoma
- New Tires
- Gibson catback for 3rd gen, special deal ends 12/18
- 1998 Tacoma Problem with hose placement
- Tacoma 5 Spd Transmission Problems
- Stock 2000 Tacoma 4x4 Front End Won't Stay Aligned Loses Toe Adjustment Easily
- HELP!! Is my syncro out in my 96 tacoma
- Just wanted to introduce myself
- Suspension lift question
- They're back!
- Visor Card for 2001 4Runner SR5
- VERY strange 4WD problem. I promise!
- Auto shifter swap?
- 99 4R Blistered dash cluster backing
- help! on the road, water lines blowing!
- '98 Ltd - can I swap '99+ lights, grille,bumper?
- rear differential
- 3.4 coolant bypass pipe ?
- 96 4runner won't completely turn off
- '98 Ltd Hood Replacement - black primer over mismatch hood? spray can options?
- Front End Damage Repair: Forward Wall of Engine Bay - bend or replace?
- 3rd Gen 4 Runner Rear Drum Brake Job Advice
- OBD2 2000 and newer smog question
- "Never change your transmission fluid"??
- 99 Hilux Surf Aftermarket Radio Decks
- Driver door dome light switch (& key fob)
- New guy with a 96 4Runner
- Swap Tacoma wheels/tires with 3rd Gen 4Runner
- 3.4 jumping time repeatedly
- How can compression be so low?
- Firestone Ride Rite
- Tacoma 1996 2wd extended cab: heat suddenly went cold
- Towing mirrors - 98 Taco
- shopping to buy used 4runner
- Quick question about maf on 97 runner
- Reconditioned injectors for 3rd gen runner? Anyone use them?
- Rear Window/Wiper Won't Work
- 2000 4runner with frame patches
- First Generation (1996 toyota tacoma) Front Wheel Bearing Replacement
- Hilux surf 1999 4wd question
- Salvage Yard 》What Should I Grab? -noobie
- finally SCORED ONE! but wait...should I upgrade? 2006 >> 2009
- PCV issue?
- Coolant Leak
- 99 runner V6 Auto stumbling and hesitating
- Transmission Fluid Coolers?
- Installing Real Coolant Temp Gauge
- Missing zerk on rear driveshaft?
- Looking to buy a Toyota 4Runner
- Mirror/map light additional gauge pod?
- Where is a Good Clutch Write Up for 3.4l Tacoma 99 4x4
- 98 Tacoma random headlights failure
- Fan blowing when switch is in off position.
- Are there any rear drums that i need to stay away from?
- best buy for rebuilt 2.7 head or used engine
- Replacing my steering wheel
- Boiling coolant
- HELP!! Rear liftgate/hatch issue...
- Fuel filter torque
- 99 4runner Ltd stuck in 4wd
- Universal Joints
- Tight Steering After Spot Weld Shaft Fix?!?
- truck running a little warm after timing belt and thermostat change
- 4Runner won't move until 3000 rpm?!..Then BAM.
- 04 tacoma ignition and throttle issue
- Thread size for slave cylinder?
- automatic lighting / ambient light sensor
- LED dome and cargo lighting
- truck pulls left under acceleration and goes right decelerating
- Understanding my URD 7th
- P0446 Code
- Fun with ball joints
- Changing tire sizes, any issues?
- Changed Valve Covers, now have a short.
- I need a bumper latch
- 1998 tacoma dome light issue
- New to me 99 4Runner with 224k
- 1999 Tacoma 3.4 belt squeak
- Intro and first issue [99 4Runner]
- Magnetic Clutch Circuit Malfunction
- please HELP! im about to burn it!
- 7th injector Denver Maps
- 2002 4 runner
- tundra tokico trd struts on 4runner?
- Overheating after headgasket job
- Snapped Manifold bolt - Now what? 96 3.4
- Michigan Rust!! :(
- Things to look for
- Unknown Wire or tube in cargo area
- the MILKSHAKE
- Transfer case issue
- How to replace the 3rd gen Limited fender flare cushion
- wassup all my yota peeps. I've got a question for you
- p0420
- 97' 4Runner bad warm hesitation
- Am I crazy to buy a '99 4runner with 180k miles?
- 3rd gen 4Runner suspension help
- Firing up 01 Runner after 5 years of sitting
- Front Brakes on 98 Tacoma Questions
- 3rz valve timing
- Transmission problems
- 1998 Toyota Tacoma P0303 Code Fix
- How do I reset the ECM on my 96 Tacoma 2wd 2.4L?
- Doubts about Intake Mods
- Installing front shock/coil assembly
- 99 Taco Buggy help with the rigged rig..
- Life in the 4Runner now that I'm supercharged
- prospective buyer with questions
- 01 Prerunner buying advice
- Front diff 95 taco 4x4 2.7 5 speed
- '97 4Runner - blown head gasket?
- Head gasket install now getting multiple misfires on driver side block
- Rear Brakes Problem
- Best Spring/Strut choice
- Dumb Question But Where Does This Line Go.
- Replacing 1999 4runner Transmission with Salvage unit
- Bilstein 5100 Question
- multiple misfires
- 1990 pickup w/97' 5vzfe idle issues
- Brembo
- Front Brakes Dragging
- New 98 Tacoma
- Help Finding Transmission Oil Dipstick
- More problems!
- 4wd not engaging, is it a cv?
- Alternator output question - '98 4Runner
- 3.4 5vzfe price?
- Rear Dana 44 swap
- Transmission rattle
- TRD 160 degree thermostat
- battery light question
- 1999 4runner Won't Start
- 99 4Runner
- Replacement shocks
- Check valve
- Muffler hole
- Leaf Springs
- 98 Toyota 4runner problems
- Wheels for 231mm Tundra brake upgrade...
- ABS Ring Position on Shaft
- Truck has an odd miss I can't figure out
- 95 taco 5 speed hydraulic clutch prob
- '97 T4R Intermittently Dead
- Toyota Tacoma 3.4 TPS
- 95 T100 Head Gasket Repair
- eBay 4Runner Lower Control Arms with Pics
- power steering noise
- Looking at a 2.7 and 3.4
- 1998 4runner buying advice!!
- Knock sensors??
- moog 81041, 81043 rear coils
- P0500 and a flame thrower...
- Factory power antenna install on a 2001 double cab?
- No drill light bar?
- Full size 16" wheel used as spare tire
- Erratic Fuel Gauge in 98 4Runner
- 1996 TR4 @ 230k Maintenance concerns
- 2.7 clattering noise
- horrible noise on startup
- Tire selection with OME 881/890
- LED Trailer lights blowing fuse?
- toytec lift question
- Tuner for supercharger in Sacramento?
- 3rd gen possible efan conversion
- Upper control arm bushing lifespan
- 3rd Gen sways like there is a trailer, but there is no trailer
- Front engine bearing noise
- Newly supercharged with URD 7th injector
- Weird idle up
- Just supercharger an not starting
- 4wd ONLY works when vac lines reversed?
- Installed e-locker, it doesnt work. ABS wiring related? Please help
- Urd 7th injector vacum T fitting
- 3.4L swap, overheating, burp darn you.
- More secure spare tire mount
- P0125 and 2k+ idle
- I want to swap 3rd gen 4runner transmissions bu need accurate wiring diagrams
- 99 4runner 3.4 auto oil pressure specs?
- 99 4Runner V6 Misfire
- 01 4runner 2wd brake issue
- Air Circulation turns on and off quickly and repeatedly
- Anyone ever repaint body panels on their 4runner?
- potential valve damage due to broken timing belt on 1999 4 Runner
- Stumbling at WOT, and then dying.
- SC check valve cross reference PTR26-35042
- 99' 4 runner knock sensor HELP
- 3rd gen 4runner wont move when warmed up
- 4WD Not working
