2002 4WD Manual Tranny and Tfr Case with ADD
Old 01-31-2016, 09:03 AM
Tacoham's Avatar
Cool 2002 4WD Manual Tranny and Tfr Case with ADD
When in 2WD, in addition to front wheels, two front axles and CV joints; exactly what other front wheel drive components are spinning while driving? I know I have Toyota's version of ADD (automatic differential disconnect) but I need to know what front wheel drive-train parts are still turning when in 2WD, especially the front drive shaft.
By the way, is ADD the same as CAD ("center axle disconnect")?
Thanks in advance for your help.
Old 02-01-2016, 08:14 AM
Malcolm99's Avatar
In 2wd only the front CV axles will rotate well rolling (unless you have manual hub locks off a Taco) the front drive shaft will not rotate until engaged at the transfer case and by the ADD, you should be able to spin the front driveshaft by hand.
Gizler00
01-14-2016 05:43 AM
MorphiasX
12-02-2015 10:00 AM
mtrdrms
11-11-2015 08:46 AM
wiseguymmiv
11-09-2015 12:22 PM
Quick Reply: 2002 4WD Manual Tranny and Tfr Case with ADD
