CV's, Wheel bearings, or something else? Help!
Old Dec 24, 2015 | 12:37 PM
BattleWagonActual's Avatar
So here goes. I have a 97 SR-5 5spd and recently noticed my CV clamps loose and the inner boot on the driver side leaking grease. Not a ton but, some. Decided to pull and rebuild the OEM rather than throw on my Napa that's been laying around as a trail spare.
Everything went very smoothly, no issues until I went to test drive it around the block. Made it a couple of minutes away when all of a sudden heard/felt a pop and grind sound for about 5-10 seconds (basically until I came to a stop.) Actually sounded like something dragging more than anything. Looked at everything, nothing looked/smelled out of the ordinary.
Made it back home with no repeat of sound, decided to investigate further and pulled the CV again. Even decided to swap for the NAPA that was still new sealed in box. Tightened everything down after the swap and went to test it out. Same result, a few miles down the road with no issue and out of nowhere a pop/grid sound, stopped and checked before heading home.
I am at a loss as to what the issue is. No noticeable play in the wheel bearing. All ball joints and tie Rod's are new. The CV was fully seated with the snap ring popping into place during the swap. I just recently did the passenger CV about a month ago with zero issues. Any thoughts or ideas would be much appreciated.
Old Dec 25, 2015 | 12:54 AM
wyoming9's Avatar
Red face
Noises can be hard to pin point while driving sometimes
How are the front pads ?? one of the dust shields vibrating ??
Could also be coming from the rear of the truck
Old Dec 25, 2015 | 04:28 AM
Terrys87's Avatar
I dont have much experience on your year of truck but I have had U-joints give me all kinds of headaches in the past that made me think it was everything else but the U-joints.
Old Dec 26, 2015 | 05:30 PM
sharrack's Avatar
Is it a noise when you turn or when your straight and the wheels are turning?
Whitemoneypit
20
Nov 1, 2015 10:20 AM
83
11
Oct 19, 2015 04:57 AM
Nuyota
Oct 12, 2015 11:03 PM
BIGDEERHUNTER
Oct 6, 2015 03:09 PM
crash813
Sep 27, 2015 07:15 AM
