PDA
View Full Version : 95.5-2004 Tacomas & 96-2002 4Runners
Pages : 1 2 3 4 5 [6] 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222
  1. Faulty brake booster or master cylinder?
  2. Diagnostic help- what happened??
  3. 1998 4Runner Defogger EWD
  4. What wire is this?
  5. What kind of oil do you run in your rig?
  6. Throttle body coolant hose routing?
  7. Good compression on New "Used 3.4l motor" Head gasket bad?
  8. Possible water leak, need help ASAP
  9. Toyota tis
  10. Replace A/C clutch bearing '99 tacoma Prerunner 2.7L
  11. 4wd ECU
  12. 96 4runner electrical problems
  13. Any pics/insight on how to make the wiring connections for Fog Light Rewire Mod?
  14. 4runner Vibration low speed
  15. stupid diff question
  16. Steering rack preload adjustment
  17. Anyone ever had the dreaded black death?
  18. Battery light at idle
  19. Clutch kit question for Toyota '97 3RZ-FE 4-cylinder engine with 5-speed W59 tranny
  20. Performance Radiator Question?
  21. Vsc trac lights on
  22. Passenger side seatbelts
  23. 00 Tacoma 4x4 Vacuum line routing
  24. #5 no injector pulse
  25. Convert '04 PreRunner to 4WD
  26. Oil around spark plugs
  27. thermostat housing
  28. 99 taco grill
  29. Slightly more aggressive Tires on 3rd Gen 4Runner - looking for advice.
  30. 2001 4Runner Check Engine light and rough idling. HELP!
  31. electric antenna
  32. 05 taco no cruise,
  33. 1” Body lift, stock suspension
  34. 2000 4Runner limited no reverse gear + P0755
  35. 99 4Runner,new motor acc belt won't Line up
  36. Maf code
  37. Throttling problem
  38. 95.5 Headlights wont dim
  39. what to buy
  40. Power Window Problem
  41. Fuel Trim and Mass Airflow Sensor readings for P0172
  42. Best fix for cracked airbox 3.4l
  43. 98 3.4l automatic. died when reversing
  44. Sputtering & Misfiring
  45. Seeking Smaller Emergency Brake Lever
  46. 4runner rear hatch compatibilty 99-02??
  47. 4x4 wont engauge
  48. How to Change Door Locking Behavior
  49. hood scoop insert
  50. what is cost to repair 4x4 actuator on 2000 forerunner limitet?
  51. 2000 4runner won't turn over until you move shifter up and down
  52. Federal vs. CA front exhaust pipe??
  53. Interchangeable parts from different years
  54. 2001 4 Runner Center Console Disconnect
  55. 95.5 won't start unless hit with starting fluid.
  56. Cx racing turbo kit
  57. Crank bolt
  58. Call me crazy...
  59. Aisan Throttle Body Tacoma 4Runner 4 Runner Tundra 2002-2004
  60. Front end noise
  61. Rear shocks and 2" lift
  62. A/C Belt Replacement--Belt won't come off
  63. 99 4Runner vibration at speeds over 60mph
  64. 2000 4Runner no start
  65. Getting a ticking noise from right front end.
  66. headlight issues
  67. Weird No Starter Juice After Battery Disconnect
  68. Issues with catalytic converter
  69. HELP: Are Toyota Truck lock cylinders compatible with First Gen Tacoma
  70. 22re vs 3.4 repair cost
  71. moisture under floor mats 2000 toyota tacoma
  72. Towing capability
  73. How did I get an A340e transmission that won't bolt to my 22r?
  74. My Starter just clicks
  75. yes or no? Will a Bad MAF sensor cause a no start?
  76. A/T Tempo Light intermittent brief flicker flash blink vehicle runs/shifts perfectly
  77. over heated
  78. Truck died while driving!! Still wont start..help please!
  79. Do I "need" the URD 7th injector kit w/ the Magnuson SuperCharger?
  80. 01 4Runner bad vibrations - pinion angle?
  81. HELP: 99 4runner transmission grinding only going into park
  82. 2010 tacoma door light
  83. crank-no start fixed-mmmmm?
  84. 80w90 transfer case/front diff
  85. 4Runner just died while driving down the road!
  86. 98 Tacoma 4x4
  87. 2000 Gauge Cluster Black to White 2001 swap
  88. Name this trim piece, please
  89. 98 Tacoma 4.10 ring and pinion
  90. What is the first year for airbags in a 4runner
  91. 3.4L Missfire on Cyl 1 & 2
  92. 1999 4runner intermittient starting issue
  93. Frame replacement!
  94. Severe misfire after valve adjustment
  95. Tacoma power window squeal
  96. 1996 kzn185 Hilux surf ecu pinouts with a manual transmission
  97. How broken is my truck? Should I fix it? How do I sell as salvage?
  98. Steering rack issues
  99. Water Bipass Question
  100. IAT Sensor Code on Tacoma w/Supercharged 3.4
  101. New 95 Tacoma questions
  102. Valve Tap?
  103. Tundra Brakes
  104. 4Runner Sunroof Module??
  105. t4r brazilian fan needs help!
  106. Please help me with my 3.4. I'm loosing my mind
  107. Noise after pinion seal replacement
  108. OEM radiator for 2002 4runner
  109. spare tire scuff guards
  110. Need some advice for rear coil springs
  111. 1999 Tacoma Rear Pinion Seal Leak
  112. 00 4runner limited engine immobilizer question
  113. Help me buy a 'new' 2000 4Runner
  114. Motor is coming out - what maintenance makes sense?
  115. Load capacity of roof racks
  116. Strange Pulsing Noise From Front End
  117. Air spring install on 1998 ltd
  118. Ecm
  119. Can't find same evaporator core
  120. Grab Handles
  121. Locked up drum brake adjuster
  122. Sounds like a diesel now
  123. 2000 2wd auto 3.4 4runner ENGINE ISSUES
  124. Engine hiccups and shut off on me
  125. ABS system
  126. Lifted Tacos! How long did your CV's last? Chime in!
  127. 2002 4runner ABS and TRAC engaging during normal driving
  128. NEED HELP I'm thinking ecu/ecm issues
  129. Resale Value on 1997 TR4 SR5
  130. Tailight not working
  131. Head gasket replacement
  132. Front engine question.
  133. 2004 4runner
  134. 01-04 Tacoma Service Manual Online
  135. Broken elocker actuator parts?
  136. changing 30 A fuse
  137. 4 runner no start
  138. P0171 2000 Toyota 4Runner 3.4 liter 5VZ-FE
  139. ABS Bleed
  140. A/C Recharge Issue
  141. Need Help, Possible Truck Purchase 95.5 Tacoma
  142. 3VZE (V6) engine idle speed
  143. '02 T4R with cracked head and strange piston damage, ideas?
  144. Excessive Heat from 4x4 shifter and console
  145. 4Runner
  146. How to unclog the a/c drain line??
  147. Broken captive weld nut in bed -help
  148. Electrical short?
  149. Wiring Connector Part Number
  150. TJM Bumper Winch Instllation?
  151. break diagram abs 2001 4runner liminted
  152. Transmission swap
  153. Transmission won't shift with lights on!
  154. A/C fuse keeps blowing when shifting
  155. rear view mirror
  156. Best bearing p/n & manufacturer for '97 Taco V6 idler in water/mud
  157. Radio Antenna Replacement 4 2002 4Runner SR5
  158. Misfiring Problems at 70 + mph
  159. 3.4L supercharger carb sticker?
  160. 3.4 trans replace with 4.0 trans
  161. '97 4Runner brake problems
  162. 2000 'runner needs struts/springs - recommendations?
  163. throttle issue
  164. Auto transmission failure? 3.4 v6, 4wd
  165. 5vz to 3rz guage swap
  166. 03 tacoma prerunner 2wd front wheel bearings
  167. 2004 Toyota Tacoma sr5 pre-runner AC issues
  168. 2004 4Runner V6 sport
  169. what type of oil should i use
  170. 3rd gen 3.4 wheel wobble, other issues (video)
  171. 2001 4runner 3.4 auto 99 taco 3.4 auto can I swap trannys?
  172. 02 tacoma transmission problem?
  173. 1997 tacoma hard starting
  174. 1997 4x4 Tacoma with r150 trans
  175. 2WD Prerunner Death Wobble
  176. No alarm system but when I open door horn sounds
  177. High idling
  178. Lift gate wiring
  179. Brush guard
  180. 97 4runner
  181. 97 4runner
  182. will softer springs dampen my ride to be more Lexus quality? 02 sr5 4wd 4runner
  183. Supercharger pulley Upgrade
  184. Toyota Emblem
  185. Engine swap issue
  186. 02 tacoma transmission problem?
  187. 2000 v6 auto trans replacement
  188. Double checking lift plan
  189. Interior Color Codes
  190. Vent Selector not working
  191. 97 4Runner thermostat help
  192. !995 Toyota Tacoma truck
  193. 3.4L timing marks!!!
  194. trans fluid for 2.4 rwd 03 tacoma
  195. Lots of issues 99 Tacoma 3.4L 4wd
  196. Tacoma 2.7 inconsistent missfire
  197. 4wd dash indicator light blinking 2004 4runner v6
  198. difference between gen 1 Taco and T100 front rotors
  199. Rattling when accelerating when the weather is warm
  200. Disabling VSC TRAC control
  201. Rattling when accelerating when the weather is warm
  202. rear axle shaft differences? help
  203. 97 Toyota 2.7 Timing chain
  204. 99 injector replacement questions
  205. '97 Taco 4WD Corrosion Resistant Brake Calipers
  206. 2.7 swap
  207. Toyota Tacoma 4wd actuator fix
  208. 97 4runner Air Conditioner Squeal
  209. ATF pouring out
  210. Just purchased Tacoma, did I buy a grenade? Please help
  211. Odd issue, intermittent puffs of smoke: 98 4runner, with the 3.4 5vzfe 5speed
  212. power window and locks
  213. Completely lost brakes while driving - master, or booster?
  214. Jam nut for outer TRE?
  215. Test fitting JDM field monitor on a '97 SR5
  216. 1995 tacoma 2.7
  217. What to look for
  218. 99' 4Runner Won't Go Above 20mph After Changing Transmission Fluid
  219. Rear diff lock engaged - should rear wheels spin freely when jacked up
  220. Waag
  221. Worth fixing? 2000 4Runner 2.7l 4-Cylinder
  222. 315/75r16 on 2000 Tundra
  223. Rag joint 95 gen1 tacoma 2x4
  224. Elocker axle, non elockler 3rd member
  225. 2001 4Runner SR5 difficult to get in and out of 4wd
  226. cargo area carpet wet
  227. Truck not starting - Clutch sensor maybe?
  228. brake pad wear
  229. 2000 O2 Sensor Pigtail
  230. '99 manual transmission in '01?
  231. 99 4runner limited rearend squirrly over bumps??????
  232. Tires, 255/70r15 anyone have pics on first gen?
  233. Loud noise when reversing in 4x4 under heavy load in 3rd Gen 4Runner
  234. Strawberry Milkshaked the 99. Yes Im still alive..
  235. 1999 Toyota 4runner 3.4l v6 115,000 miles and in great condition until next day.
  236. what doors fit 03 tacoma 4 door?
  237. 2002 tacoma trd 2.7 misfiring after warm up
  238. Long, Long cranks to start seem to be fixed.
  239. Sparkly rear differentail fluid '06 Tundra
  240. 2002 4Runner Advice Please
  241. Adding amp/sub BUT keeping factory H/U...how to bypass OEM silver amp?
  242. 01 Tacoma engine Standalone harness
  243. Steering issue / Drag Link adjust
  244. Rebuild or Buy Used Engine
  245. 2001 Tacoma TRD died rolling and wont start
  246. almost but not quite
  247. 04 tacoma turn over no spark
  248. 04 tacoma turn over no spark
  249. Speedometer Issue?
  250. Help me solve this 2000 4wd Taco repair mystery
