4Runner Sunroof Module??
Old Aug 15, 2017 | 12:12 PM
fierohink's Avatar
I have a '99 LTD with a sunroof that doesn't work and has started to leak occasionally. I had a '97 LTD with a sunroof that worked very well. So before I crushed the '97 I took the sunroof. Today I started gutting the '99 to replace the sunroof only to find there is a module attached to the '97 that I don't have on the '99. '99 roof w/o module
'97 roof w/ module
Module close-up
Structurally the two roofs are the same. When I installed the '97 into the '99 and plugged it in (not the module just the motor) it works like a champ.
Does anybody know what the module is on the '97?
Old Aug 15, 2017 | 01:59 PM
wyoming9's Avatar
Red face
If the 97 Moon Roof Harness will plug into and work go for it
It just happens to use a relay mounted right at the window .
I have the EWD for 97 and 98 both use the relay
Maybe the one for the 99 has been moved to a different spot
