Elocker axle, non elockler 3rd member
Old May 7, 2017 | 03:37 PM
$4running$'s Avatar
Bent an axle, and unknowingly bought an elocker axle. My 3rd member doesnt bolt up....and way I can still make it work?
97 4runner 3.4 liter w/4.30's
Old May 7, 2017 | 04:28 PM
dropzone's Avatar
Fossilized
If you got the complete housing just swap the whole thing. If not I believe you need to notch part of the opening for the third to fit.
am at work so don't have done of time to search but somewhere in this thread https://www.yotatech.com/forums/f199...thread-229969/
toyotech559 has a great write up
something like this
Old May 7, 2017 | 04:54 PM
millball's Avatar
You have it backwards. He wants to put an ordinary 3rd member into an e-locker housing.
I don't think that it is possible without extraordinary measures.
Old May 7, 2017 | 05:11 PM
ZUK's Avatar
ZUK
I just overlayed a standard 8" paper gasket over an elocker gasket and it's pretty easy overall to make your 3rd fit the pattern of the elocker axle housing.....Just remove the 4 long studs on the right side(driver side)...push the 3rd in place over the remaining 7 studs and drill/tap the 2 holes (at the 2 o'clock and 4 o'clock positions) and you're home free. You'll have 9 out of 10 studs holding it in and that's "good enough"......The stud at the 3 oclock position is not desperately needed.
Seal it with a standard paper 8" gasket and probably use rtv for extra insurance.
Ken
Old May 7, 2017 | 05:28 PM
dropzone's Avatar
Fossilized
that's what i get for doing stuff with about 5 seconds to spare on my lunch break, but it sounds like it can be done with out too extraordinary measures on what Master Zuk says below
Originally Posted by ZUK
I just overlayed a standard 8" paper gasket over an elocker gasket and it's pretty easy overall to make your 3rd fit the pattern of the elocker axle housing.....Just remove the 4 long studs on the right side...push the 3rd in place and drill/tap the 2 holes (at the 2 o'clock and 4 o'clock positions) and you're home free. You'll have 9 out of 10 studs holding it in and that's "good enough"......The stud at the 3 oclock position is not desperately needed.
Ken
Old May 7, 2017 | 05:51 PM
millball's Avatar
Are the axle shafts the same length between e-locker and conventional??
Old May 8, 2017 | 11:46 AM
Jomoka's Avatar
Yes. We swapped a locker rear axle into my wife's '96, the passenger side axle shaft in that turned out to be bent, and she swapped in the axle shaft from her non-locker axle with no issues.
Old May 12, 2017 | 08:28 AM
legokcen's Avatar
I have an extra standard axle that I was going to convert to put my newly acquired locking into. Where are you? I'll trade if you're close enough.
Old May 12, 2017 | 10:10 AM
Charchee's Avatar
I figured somebody would hit you up for a trade.
Old May 13, 2017 | 04:55 AM
$4running$'s Avatar
After posting this I told the guy I bought the axle from that it didn't fit and got the same reply "As long as the 3rd member covers the hole, drill, tap, and bolt it up" Looks like this is going to be my first line of attack. Saves spending more money and having an axle kicking around.
Thanks for the advice guys. Wish me luck
Old May 13, 2017 | 04:21 PM
ZUK's Avatar
ZUK
Keep us posted on the progress....maybe snap a few pics. No luck about it. It will fit . Just get those 4 long studs out and check the fit.
Old May 27, 2017 | 02:40 PM
ZUK's Avatar
ZUK
Long story short....I will have a chance to check the fit of a V6 3rd into an elocker housing in a week or 2.....and will post pics
Old May 30, 2017 | 01:04 PM
Mauzer's Avatar
Awesome, this may be my solution as I have a spare non-elocker 3rd and need to send my elocker 3rd off for a regear!!!
Old May 30, 2017 | 10:46 PM
ZUK's Avatar
ZUK
Send your elocker to me for Nitro Gears
Just received the rusty 3rd......a little cleanup and I can test that V6 3rd into an elocker hole.
see this.... https://www.yotatech.com/forums/f152...l#post52366692
ZUK
takethetruck
60
Mar 29, 2019 01:47 PM
Calahantheman
Sep 6, 2018 11:26 AM
stranded1980
17
Jul 8, 2018 07:10 PM
tundup93
Engine Swaps
Apr 27, 2017 10:52 AM
